Question about Olympus Stylus 730 Digital Camera
Picture error My Stylus 730 screen shows "picture error" (xD) which I cannot remove. The picture icon (top right) no longer seems to function. Grateful for your advice
  • edward_kelly Jun 26, 2009
    Confusion compounded. I removed all pix. Only one of my new shots would then display as neither the playback button nor the playback facility on menu page would work!
  • edward_kelly Jun 27, 2009
    A mite insulting. The camera clearly would operate at all if the card was wrongly installed!
  • 2,200 Answers
I would suggest that you first restore the default settings on the camera to see if this resolves the issue.
To do this press reset to display the reset confirmation screen then select YES and press ok/function.
Do this first and let me know if this resolves the issue. If not I will further troubleshoot the error codes for you.
Posted on Jun 27, 2009
  • Radio Code Pro
    Radio Code Pro Jun 27, 2009
    The picture error message usually means that there is a problem with the selected picture and it cannot be played back. The image file itself is damaged. There may well be a problem with the memory card.
    You can try formatting the memory card to resolve this but remember that formatting the card will erase any photographs on it and leave it blank.
    To format the card select POWER OFF - remove and reinsert your card and then press the OK/FUNCTION. Select FORMAT then YES and press OK/FUNCTION again. All data on the card will be erased but it should be functional again.
    Let me know how you get on.
    If this resolves your problem, please rate my answer accordingly.
    Thanks
    Sergeant:
  • 353 Answers
Try pushing the xd card in to release it
you may have the card in upside down, then you will have to use tweezers to pull it out
Posted on Jun 26, 2009
    Genius:
  • 1,847 Answers
This is a memory card issue.
If you are able to view all the images up to that point this error means that image is corrupt. try to delete the image before the image itself and the one after and see if you can then view all the images,, if nothing works then you should format the card.
Still no go replace the memory card.
Thanks
Kindly rate the answer
Kevin
Posted on Jun 25, 2009
Hi my problem with my A340 is that when i switch
is the lens cover on? or the shutter could be stuck.
Sep 29, 2014 | Cameras
Hi EPSON STYLUS 1290 'Communication Error has occurred' Green light and red light (the one above the paper symbol) are flashing alternatively. Unable to run any utilities. Please let...
Turn the printer off and unplug it from the wall. Press and hold the power button for sixty seconds. Check the paper supply and make sure all papers are uniform and tightly in the incoming tray. Turn the printer on and check the print que on your pc to make sure there are not unprinted documents stuck in the que preventing normal function. If there are documents in the print que you will see a printer icon (picture) on the bottom right side of the screen on your pc near the clock area. Sometimes there is an arrow in this arrow which needs to be clicked on with your mouse to expand and see all icons. Click the arrow and if you see a picture of a printer or Icon, right click with your mouse on top of it and choose open all printers. If there are documents in this area, click on one and choose delete until all are gone. Then try printing again. This should solve your issue.
Sep 14, 2011 | Epson Stylus Photo 1290 InkJet Printer
How to remove write protect from olympus xd card
You don't state whether you've tried using the tiny switch located on the xD card to unlock it.
If it is already in the unlocked position then push it fully to the locked position and then fully back again.
If this does not work then please report back for additional options.
Feb 22, 2010 | Cameras
Olympus c-730, does it support xD-Picture cards greater than 128M
The problem is that the largest xD card that your camera can support is an M or H 512mb card. The 1gb or 2gb cards are not compatible. The firmware in the camera cannot support memory storage with that capacity. The camera came out before those cards did and there no plans to upgrade the camera to allow those types of cards to be supported.
Feb 08, 2009 | Olympus Camedia C-730 Digital Camera
Olympus 850sw- write protect and picture error
Sounds as if the memory card has corrupted data on it now. You will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup Menu - right arrow to Format- Press Ok. You will see format yes or no. Choose Yes and press ok. This will clear the write protect and picture error messages and the card can be used again.
Dec 29, 2008 | Olympus Stylus 850SW Digital Camera
Memory Card Deleting Photos After A Certain Amount Of Time??
I've have xD cards that I thought I deleted the photos, but they showed up on the Xd card when i put it in the card reader to download another set of pics. I think it happened because I used the card in 2 different cameras (thus, the cam each saved pics in their own different formats).
Jun 22, 2008 | Olympus Stylus 730 Digital Camera
Xd ! picture error
I'm having the same problem with mine. I'm trying some data recovery programs right now. PhotoSalvage works great for Macs.
Sep 04, 2007 | Olympus FE-230 Digital Camera
A non-Olympus brand xD-Picture Card
Yes, however the Olympus brand xD-Picture Card offers the ability to use the Panorama function.
Sep 04, 2005 | Olympus Camedia C-730 Digital Camera
Saved images to the internal memory or to the optional xD-Picture Card
The internal memory and the xD-Picture Card cannot be used at the same time. When the card is inserted the internal memory is disabled. When you want to use the internal memory, remove the xD Picture Card. The LCD display will indicate that images are saved to internal memory by displaying [IN] in the lower right corner of the screen. When using the xD-Picture Card the camera’s LCD will display [xD] in the lower right corner of the screen. These indicators are displayed just above the number of available frames.
Aug 31, 2005 | Olympus D-545 Zoom Digital Camera
Saved images
The internal memory and the xD Picture Card cannot be used at the same time. When the card is inserted the internal memory is disabled. When you want to use the internal memory, remove the xD Picture Card. The LCD display will indicate that images are saved to internal memory by displaying [IN] in the lower right corner of the screen. When using the xD Picture Card the camera’s LCD will display [xD] in the lower right corner of the screen. These indicators are displayed just above the number of available frames.
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Olympus Stylus 730 Digital Camera Logo
74 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
