Question about Samsung SGH-D900 Cellular Phone
Charging My mobile is stating it is charging and the battery bar is moving indicating this but the phine is not plugged into the charger?What might this be?
    Sergeant:
  • 316 Answers
Check where the charger plugs into the phone i have a feeling that there may be some damage done there.
if this is the case a service centre is you next port of call.
Posted on Nov 06, 2007
Batteries wont charge
You would need a voltmeter to check the charger in order to see if it is charging the batteries. New batteries if purchased from a reputable outfit will have a nominal charge and should work initially in order to test the scooter. Depending on the model check for blown fuses and disconnected wires on the battery boxes, connections, plugs and charging circuits including the wall outlet. The display on the scooter will indicate the state of charge and the key switch should work and give an initial indication that the scooter is on. If you provide make and model I can respond with more specific information.
Mar 23, 2014 | Health & Beauty
Do I switch my scooter on or off when charging ? What does the first yellow bar (above red line) mean when it is flashing. Thank-you .
Scooter should be in the off position when charging, if the yellow bar is flashing during charger, this means the scooter is in inhibit state, Which means it cannot be driven because the charger is plugged in.
Aug 30, 2011 | Ctm 3 Wheel Power Mobility Scooter Hs125r...
We have bought a battery charger HB 1206S DC6V - 12V 6AMP, but it does not state what is the state of charge do the lightes go out when it has reached changed state or light up please help
Product Detail Model No.: HB-1206S
The item is used for charging 6V-12V lead-acid batteries
Max Charging Current: 6A
AC Power Input: 64W
Output: 6/12V DC 3. 52A
Batteries Capacities: 15AHR-80AHR
Unit Packing: Colorful box
Dimension: 18cm x 10cm x 20cm
G. W. / N. W.: 1. 85KG/1. 75KG
Certifications: GS, CE, BS, ROHS, SAA
Main functions:
(1) The HB-1206S battery charger has the features of convenient operations, reliable safety and high performance.
(2) During charging, if turn up overload, the battery charger will keep itself at normal current and normal voltage with its self-automatic protecting function.
(3) If being short circuit, the battery charger will switch off itself, and turn normal after one or two minutes.
(4) The output current of the battery charger is very stationary, so it can protect the battery charger very well. It only costs 3 or 4 hours to fully charge the batteries.
(5) Indication of charging: the battery charger has 6 pilot lamps. The more pilot lamps shining, the less electric quantity is. The charging process finishes when all the pilot lamps go out.
(6) The battery charger can be switched between 6V and 12V, so it can charge for 6V and 12V accumulators. You can select 6V or 12V according to your own needs.
(7)The operations are very convenient: Put the red clip to the positive pole of the accumulator which indicated "+", and put the black clip to the negative pole of the accumulator which indicated "-", then plug in power source, the accumulator will be charged.
Aug 02, 2011 | GPS
I'm borrowing a Jet 3 Ultra from the local Am. Legion for my Mom to use. They know nothing about it except they were told it had a new battery. I plug it in and all the LED's light up with the...
The batteries need charging and when you plug in the charger and the power is on the lights wil flash indicating that the charger is plugged in. Now look at the rear of the chair near where the charger cord plugs into the chair and you should see a voltmeter. With the charger plugged in the voltmeter will indicate about 5-6 amps and after charging overnight the voltmeter should be reading 0 amps. If when you plug in the charger cord and the voltmeter indicates 0 amps then I would suspect that the charger is not working or that the fuse is blown in the charger circuit. The only way to see if the batteries charge would be to borrow or find an offboard charger that will plug into the charger port located under the front of the joystick and after charging for 10-12 hours see if the battery level lights show full charge Hope this helps
Jun 25, 2011 | Pride Used Mobility Jet 3 Power Wheel...
My samsung cell phone gives no indication when charging so I donot know whether is charged or not.The problem is the charger or the mobile phone?It indicates only the bar which requires charging but when I...
There are 3 solutions to your problem.
1) You need to replace your phone's battery, or
2) You need to replace your charger. (If you have a car charger, try it to determine if your home charger is the problem) or
3) you need to have the charging plug on your phone repaired; it will need to be sent in for service.
Feb 01, 2010 | Samsung SCH-u340 Cellular Phone
No display to indicate battery is charging Nokia E63
to confirm that the phone is charging, switch on the mobile and charge or turn on the mobile when it is charging.if it doesn't works then try with some other charger,still same there is some problem with the battery r the connection point.check with the vendor.they will definitely assist u.
Aug 19, 2009 | Nokia Cell Phones
Upon power up, 3 red LEDs flashing rapidly continously, no power.
The control systems on power mobility equipment have a "prevent" circuit that immobilizes the equipment while it is plugged into a charger, so folks won't take off with it plugged into the wall outlet. When you turn it on when plugged into a charger, the display will flash constantly, or sweep constantly, depending on the manufacturer. This is normal. Your off-board charger should have a red light to indicate power to the charger, and another light for the charge status. Yellowish means it is charging, when it turns green, you are fully charged. If the status light is green all the time, that is an indication that the charger is not functioning properly, or that the batteries are below a chargeable state. Check charger output, which should be 26-28 volts dc, and each battery should show at least a 12 volt reading, but around 13.5 volts with a full charge. If one or both of the batteries drops below 12 volts after a short period of time, it's time for a fresh pair. Fully charge new ones before using the chair.
May 31, 2009 | Pride New Jazzy 600 Power Wheelchair by...
How do you know when its fully charged?
You can either charge it by connecting it with a usb lead to your computer (which takes ages) or by plugging in a mini-USB style charger, which come with many mobile phones.
While it is charging, the battery indicator will animate, with the battery contents moving, as if the battery is 'filling', much like a mobile phone does. When the charge is complete the animation will stop, and the battery indicator will simply look full.
If you are charging through your computer the indicator will be in the top right of the screen. If you are using a charger the whole screen background will be black, with a large battery in the middle, and nothing else on the screen.
Mar 08, 2009 | Philips SA3025/37 Flash MP3 Player
Batteries are charged, scooter won't move, no power to display
It is impossible to overcharge with the Pride charger. When the battery is full, it will stop charging and check about oncew a miute to maintain the charge.
Now, when you plug in the key (looks like an audio headset jack) does the battery meter indicate a full charge? Also, the scooter will not move if its in free wheel mode, and it will not move if the charger is plugged in. Beyond these first steps, you will need a voltage meter to troubleshoot.
Jan 18, 2009 | Pride Mobility Products Go-Go Elite...
Battery Charging, Nuvi 35
Charge the unit over night, Plug in the AC charger and you should see a lightning bolt over the battery bar graph display.
With the charger plugged in, gently press and hold the on/off power until the screen goes black and displays the text "Charging battery". After a few seconds, the screen will go black to conserve power. At any time, you can press the screen and it will light up saying its still charging.
If you let it go over night, when you touch the screen, it will say Charging Complete and you can then remove the charger. You should have full green bars on the battery indicator.
- Jim
SHARCNET-USA
Dec 20, 2008 | Garmin Nuvi 350 Car GPS Receiver
Samsung SGH-D900 Cellular Phone Logo
26 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
