SOURCE: 3 beeps and lights flash when I push the start button
The door is not compltely closing. Make sure to push it in hard around the clasp areas. If yours has a light, the light should turn off and on as you open and close the door.
SOURCE: keep getting 3 beeps and the lights come on while its beeping.
Mine has been beeping incessantly as well. Turned out that even though I was cleaning the filter after each load, there was still a ball of lint the size of a tennis ball that was blocking the lint sensor. To fix, I removed the screws from the plastic piece that holds the lint trap and slid it out (it won't come out entirely.) Then I used the mini attachments for my vacuum to remove the lint from the bottom of that space. Once I did that, the dryer has been working flawlessly.
SOURCE: It won't stop beeping all the time
When the Cycle Signal Control is ON (turn off) a signal will sound at the end of each cycle and
during the Press Saver setting (some models). The volume is adjustable on some
models.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: My Frigidaire FEQ1442ES1 dryer has started to beep
When I read to manual, it said it was the lint. I use a paint brush to brush the lint off and usually the beeping stops.
SOURCE: My Frigidaire FEQ1442ESO Dryer
Unplug it.
Remove the 2 screws on the back side to get the top off.
Slide the top off and take the 2 control panel screws off lift up the control panel and get he tech sheet out. Consult it to find out about them beeps. Use this LINK to access service videos for your machine.
Helpful?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
