Question about Toshiba Satellite A135-S4427 Notebook
Screen minimizes when using the touch pad
When using the touch pad in normal serfing the net, the screen will minimize or when playing mahong games. It is very irritating.
Re: Screen minimizes when using the touch pad
If you touch the top right corner of the touchpad, it restores down the window you are currently in. The bottom right corner of the touchpad minimizes the window you are currently in. The bottom left corner of the touch pad brings up the start menu.
Posted on Nov 11, 2008
  • 689 Answers
You can disable touchpad menu options. Alternately you can use Fn+F9 keys to disable/enable briefly
please post if you need further assistance
Good Luck
Posted on Feb 08, 2008
0 characters
3 Points
Full screen minimizes on windows xp
Yvette Rodriguez,
I need a little more information on what you are describing. Please explain the process you are having with the Screen.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 22, 2014 | Dell Inspiron 1420 Laptop
Screen minimized
hit the auto adjust button on the screen
Apr 07, 2014 | Compaq Presario Notebook
Tried installing oovoo on my hp mini but i couldn't complete the installation because i could not click on the "next button" due to the screen size?...what do i do?
You can adjust the position of the info on the screen? Does it use a mouse? Touchpad? Touch? Adjust the size of the info? Say from 100% to 75%?Right click the page, any adjustments? Minimize?
Sep 23, 2013 | HP Mini 1000 XP Notebook
Touch screen issue
scan for any virus.
reconfigure the touch sensitivity in control panel.
above doesn't solve the problem, try reinstalling the operating system.
Apr 22, 2013 | PC Laptops
Resolution problem
I had this issue sometime ago on my inspiron.Apparently your graphics driver is the culprit here. I would advise that you download and install the latest driver and see if it resolves the issue.
click here to download the driver
Also please vote for fixya if you found this post helpful. It will only take a minute or two
Thanks for using Fixya.
Feb 08, 2009 | Dell Latitude D600 Notebook
Touchpad minimizes screen
Double check your settings for the touch pad. It could be set to do that under one of the settings. Or something internally could have gotten jogged or internally moved. If that is the case there isn't much you could do unless you got someone to look inside of it for you.
Nov 06, 2008 | Toshiba Satellite A105 Notebook
Broken touch screen glass
they've got screens for about $205 for the tx2500 and the tx1000 with easy to understand manuals on ebay at the following site:
Sep 23, 2008 | HP Pavilion TX1000Z 12.1" Touch Screen...
Maximizes & minimizes screen while scrolling or using pointer on Vista
change mouse out buy replacemnt goes under the plastic housing not to bad to change 20 bucks on ebay
Feb 02, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S4427 Notebook Logo
393 people viewed this question
Top Toshiba PC Laptops Experts
Brian Sullivan
Brian Sullivan
john smith
Are you a Toshiba PC Laptop Expert? Answer questions, earn points and help others
