Question about Garden
I think my son put the wrong gas into my power washer what do i do now -- it coughed, knocked and emitted a burning smell, it was diesel, i think
  • 174 Answers
Hello:
I would drain all the gas possible. Take out the spark plug(s). Spray some carb cleaner into the head. Spray some into the carb. Let it sit 10 minutes. Put the correct gas in. Replace plugs and try running it
Posted on Jun 25, 2009
I have my sons MG 231 Diesel tractor & need to put diesel in it but not sure which cap is for the diesel. I think the front cap if for water & the next one if for diesel? am I correct?
Get a stick or something and stick in one or the other tank. Diesel will smell like diesel and look oily. and the water side will seem watery not oily.
Mar 21, 2017 | Diesel Garden
I have a 90 series washer and I just changed the motor coupler. Now the washer emits a electrical burning smell. what can I do?
not proper fitting has been done so motor is jammed,,,not moved freely so the burning smell is from motor ,,,disamble & assemble properly,,,check brakes fitting also due to jammed motor
Mar 11, 2015 | Kenmore Washing Machines
If i have a diesel engine and my tank is 80 litre and put 70 litre diesel and 10 litre petrol in my tank what will happen to my diesel engine than
That depends on the amount added and the engine, yours would be 7 parts diesel to 1 part gas. I do not have the different effects on engines using different ratios of deisel to gas, I suspect the richer the mix ratio of gas to deisel, the more noticable the reactions will be. First off there are two immediate impacts of diesel fuel mixed with gasoline: the octane is lowered and the fuel vaporization is reduced. The lowered octane may cause the engine to knock. Some engines have knock sensors and the electronic controls that will adjust the timing and other engine conditions to try to control the knock. If the knock remains significant it can damage the engine by causing metal fatigue eventually leading to failure of critical parts like pistons, connecting rods, heads. Some very old engines (e.g. 1950's tractors) can accomodate lower octane, but the ones found in recent autos are normally running close to the knock threashold. The reduced volotitility caused by the added diesel will cause hard starting and will probably result in some unburnt hydrocarbons remaining in the exhaust gas from the engine; these may be reacted in the catalytic convertor causing it to overheat. A modern electronic controlled emission system controls the oxygen level in the exhaust gas going to the convertor so the significant increase in hydrocarbons with controlled oxygen may save the convertor, but will likely result in unburnt hydrocarbons exiting the exhaust. This will result in a smell and air pollution. Gas will also damage deisel fuel pumps as well.
Dec 15, 2013 | Cars & Trucks
Used the wrong gas
Open the gas fill door, remove the gas cap and smell the gas fill tube area. If it has a kerosene like smell then you may have filled it with diesel fuel. If so select your favorite garage to drain the tank and flush the fuel system to remove the diesel.
This vehicle should run on any type of gasoline so I suspect the fluid you put in was not gasoline.
Oct 16, 2013 | 2007 Ford Escape
There is a ticking/knocking noise coming from engine and the interior of car you can smell the diesel on ford fiesta 1.4dtci on 56 plate.
Have your valve clearance checked for that noise. As well as the diesel smell, fuel lines must be checked for
leaks. If your car is emitting heavy smoke, and it seems to loose power going uphill, your engine must
be due for overhauling. However, if your problem is just
knocking and diesel smell, valve clearance adjustment
and fuel line check up will correct the problem.
Sep 24, 2009 | 2007 Ford F
Please help my alfa is in limp mode no power back firing using lots of gas run out of petrol some time ago and i think the wrong gas was put in it auto electrician noted knock sensors showing up on his...
Wrong gas wouldn't screw it up that bad unless you put diesel in. Removing the battery shouldn't cause this either.
Check mass airflow sensor, O2 sensor, sparkplugs.
Do you have the twinspark 4 or the V6? If V6 check the timing to make sure one of your belts didn't skip a couple teeth.
Jun 13, 2009 | Alfa Romeo 156 Cars & Trucks
Gas smell in washer after gloves were washed
My Dad was a diesel mechanic and his clothes would be full of gas and diesel fuel and grease. My mother would use Oxydol powder and liquid Wisk and a little water, make a paste and put it on his clothes with a paint brush. They always came clean and our washer didn't smell either. This has been 30 years ago but I would think it would work today too. Get you some scented detergent or just the Wisk and try that with the clothes. Of course my Mom used HOT water and also she used sometimes,Arm&Hammer Washing Soda with the above by just adding it in the tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 27, 2009 | Kenmore Elite 45986 Front Load Washer
Strong Diesel Smell inside HJ Turbo Diesel Landcruiser
Since you didnt notice any change in the performance of your engine, ill presume there's nothing wrong with your fuel injectors.
look for moisture around your gas tank cap, the hose and clamps going down the tank, around the fuel gauge sending unit of your tank. have your fuel line checked from the tank to your fuel injection pump, give particular importance around the connections of your fuel filter, fuel pump, and the return hose from your fuel injection going back to your tank.
Diesel do emit strong hazardous odors that may stick on carpets inside your car.
Oct 11, 2008 | 1985 Toyota Land Cruiser
Garden Logo
73 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
