Question about Olivetti wireless All-In-One InkJet Printer
Print envelopes with Olivetti ANY WAY printer
In the past I was able to print on 23/11 cm envelopes by feeding the blank envelopes into the paper feed bin, standing up, and got satisfactory results.
now
the Olivetti ANY WAY printer refuses to accept the envelope (I've tried feeding one envelope , or a bunch, or new ones or old ones etc.) and an error notice appears on the computer screen and an "X" on the tiny screen on the printer.
has anyone encountered and overcome a similar difficulty? any advice would be much appreciated.
thank you HLG
PS: the printer feeds and prints A4 size paper without any problem.
2 Suggested Answers
  • 2692 Answers
SOURCE: printer will not print
No . Drivers available for your model are Win  NT, 3.0,9.0. Unless they have someone write a new driver for this old model is  will never work on Xp. sorry. Don't kill the messager for telling you the truth. No-one else will have any other answer for you.  I answered completely and honestly.
Posted on Mar 07, 2009
How to load evelopes HL 2140
Brother Hl 2140 Printing on thick paper, labels and envelopes 2
When the back output tray is pulled down, the printer has a straight paper path from the manual feed slot through to the back of the printer. Use this paper feed and output method when you want to print on thick paper, labels or envelopes.
Open the back cover
Open the manual feed slot cover.
Using both hands, slide the manual feed slot paper guides to the width of the paper that you are going to use.
Using both hands, put one piece of paper or one envelope in the manual feed slot until the front edge of the paper or envelope touches the paper feed roller. When you feel the machine pull in the paper, let go.
• Put the paper into the manual feed slot with the side to be printed face up.
• Make sure that the paper or envelope is straight and in the proper position on the manual feed slot. If it is not, the paper or the envelope may not be fed properly, resulting in a skewed printout or a paper jam.
• Do not put more than one piece of paper in the manual feed slot at any one time, as it may cause a jam.
• If you put any Media (paper, envelope and so on) in the manual feed slot before the printer is in the Ready state, the media may be ejected without being printed on.
Jul 18, 2011 | Brother HL 2140 Laser Printer
Paper size mismatch for A9 envelope (5.75x8.75)
Set the envelope size in the printer properties paper size list to A5 (5.83 x 8.27) which is only .08 inches wider than the short side of an A9 envelope (5.75 inches). The paper size sensor on the HP6520 printer must not be sensitive enough to tell the difference. I can print A9 envelopes just fine using the A5 setting.
Jan 20, 2010 | HP Photosmart C4580 All-in-One - InkJet...
How do you load an envelope in the printer?
Hi, Please follow these steps to load :-
1.Turn on your printer. Make sure it is in ready mode (green status light on) and it is not printing or running any other operations.
  1. 2.Determine whether your printer uses a top-feed or bottom-feed. Blank paper stands upright in a top-feeding printer and lays in a tray on a bottom-feeding printer.
    3.Load your envelope in portrait mode for envelopes that are 8.5 inches wide (standard paper size). Fold the flap down and place the envelope with the side to be printed on facing you. Load the envelope so that the side with the flap enters the printer first.
    4.Load your envelope in landscape mode for longer envelopes that cannot fit in lengthwise. Close the flap. Load the envelope so that the left side enters the printer first (the flap will be on your left).
    5.Set the paper guides. This guide is the sliding piece on your feed tray (it will usually be on the left). Slide it over so that the paper is held straight when it enters the printer.
    6.Set up your printing preferences. Go to "File > Page Setup" or access your printer’s properties page. Under orientation, select portrait or landscape mode depending on how you loaded your envelopes. If your printer has this option, select “Left” for bottom-feeding printers and "Right” for top-feeding printers
    7.Take a look at the "Print Preview" (usually found under "File" menu) and make sure everything looks good. Then print.
  2. Thanks!
Oct 02, 2009 | Office Equipment & Supplies
Smaller items will only feed crookedly into the printer document
Check to see if you are feeding the envelopes and 4x6 cards/photo paper correctly.
Both envelopes and 4x6 cards must be loaded and centered on the paper exit tray (not inside the paper input tray).
Printing envelopes:
  • Up to 15 envelopes can be loaded at a time.
  • The print side of the envelope faces down.
  • The envelopesare centered on the paper exit tray.
  • You print the envelopes with Landscape orientation.
Printing cards:
  • Up to 35 greeting cards, index cards, postcards, or photo cardscan be loaded at a time.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
For images on how to correctly load the paper, download your printer user's guide:
http://support.dell.com/support/edocs/systems/prn946/en/index.htm
Aug 16, 2009 | Dell 946 All-In-One InkJet Printer
I am unable to print an address on an envelope.... it comes out blank
It sounds like to paper setting is wrong. In the configuration you can set if the envelope in on the right side, left side or center of the paper feed. If it is set one way and you feed the envelope the other way the printer will print but on the wrong end of the feed area so nothing will be on the envelope. Try this, print an address label as you would on the envelope but just use a full sheet of paper. If it prints where you can see it, then feed the envelope on that side, or change the feed settings in your software to print on the other side. Office and most other programs have this setting. In MS word the orientation setting is on the envelope and label screen on the right side of the pop up box.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 03, 2009 | HP LaserJet 1020 Printer
Printing envelopes
you can replace the paper in the main tray with the envelopes. this is the only way unless you have a secondary paper tray or manual paper feed that does not override the main paper feed
Oct 03, 2008 | Lexmark Optra T610 Laser Printer
I have a hp 2849 all in one printer. When I print envelopes they print blank.
When you print an envelope, let the printer print on a regular sheet of paper to see if it's printing in an area not in line with the envelope.
This example is from Open Office. Microsoft is pretty much the same. What this is showing is the position of the envelop feeder so you know which one to select so that it can print correctly. The software must be set up correctly. The arrows show the path of the paper feed.
To find this in Office, click on TOOLS, LETTERS AND MAILINGS, ENVELOPES AND LABELS.
Click on the envelope in the FEED box.
This window will show the feed position of the envelope using an 8x11 as a point of reference.
Aug 04, 2008 | Office Equipment & Supplies
Brother dcp 7010 How to print envelopes
Use the manual feed slot to print or copy on labels,
envelopes or thicker paper.
Slide the paper guides to fit the paper
size.
Using both hands put the one sheet of
paper in the manual feed slot until you
feel the front edge of the paper touch the
paper feed roller.
Let go of the paper
when you feel the machine feed the
paper in a short distance.
May 16, 2008 | Office Equipment & Supplies
No longer prints envelopes from manual paper feed
you need to change driver configuration
very easy
elvis
Apr 01, 2008 | Brother HL-5240 Laser Printer
Printer has suddenly stopped printing envelopes
Just fixed it thanks to Lloyd at Lexmark.com Go to Technical Support > LIVE CHAT. To print envelopes all I needed was to check the print in "Black" only button. Under Quality make sure the Print Color images in Black box is checked, select Apply and OK.
Jan 16, 2008 | Lexmark X5150 All-In-One InkJet Printer
Olivetti wireless All-In-One InkJet Printer Logo
136 people viewed this question
Top Olivetti Office Equipment & Supplies Experts
James Cagle
James Cagle
Alun Cox
Are you an Olivetti Office Equipment and Supply Expert? Answer questions, earn points and help others
