Question about Hayward H Series Pool & Spa Heater 200k Btu Propane Gas Milivolt Ignition H200p1
I have a Teledyn pool heater that the pilot will not light on. There is no gas running to the pilot when I go through the same start up as previous years. I saw one thread in troubleshooting say it is the thermocoupling, but that is not identified as a part in the manual.
  • bowerd Jun 26, 2009
    Your fix ideas for my pool heater hit the mark! The pilot line was plugged,so I blew it out with compressed air and it started right up. Thanks!
    Genius:
  • 1,341 Answers
This could be due to low gas pressure, inadequate air supply, or improper venting. Make sure gas is turned on; with propane, make sure the tank has fuel. Also check for water run-off from roof or sprinklers. Check to make sure the heater pilot tubing is intact and not clogged.
  1. Is the system switch on?
  2. Is the thermostat up to temperature?
  3. Is the pump running with a clean filter less than or equal to 16 psi on pressure gauge?
  4. Is the gas valve in the on position?
  5. Is the pilot lit?
  6. Is the gas supply valve open?
  7. Are all plumbing and filter valves open?
  8. If a bypass is installed, is it properly adjusted?
Posted on Jun 25, 2009
Why won't the pilot light stay lit?
You have a "pilot generator" that sits in the flame of the pilot light. This generates a low voltage output from the flame of the pilot light. This voltage goes to the gas valve and tells the valve that the pilot is lit and to keep the pilot gas line open.
In almost all cases replacing the pilot generator will resolve the issue . They run about $60-$75.
Other causes may be the gas valve itself or a short in the safety loop, in either case should be looked at by a pool tech.
Jul 10, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
How do i light my heater pilot light? My gas was turned off temporairly but is back on and I need to relight my pilot light.
Your pilot is a spark ignition so it will start itself. You will probally need to bleed the gas line to get it to start. Do this by opening the union outside the cabinet and turn the gas on till you can smell it. Shut the gas off and tighten the union up again and let the gas clear. Then start the gas and seeif it will light at that point.
Apr 24, 2010 | Hayward H Series Pool & Spa Heater 400k...
Pilot wont light //suspect corrosion, connections..
If your pilot assembly is corroded, you will have trouble lighting the pilot.
I would highly recommend replacing the pilot assembly. By doing this, you will have a new pilot generator that will be producing a larger amount of voltage to run the gas valve. Also, you will have a clean pilot tube and orifice so gas can run unobstructed.
Oct 21, 2009 | Hayward H Series Millivolt 250,000 Btu...
Do not know how to start pilot light
There should be instructions on the inside of the heater access door. Make sure you are comfortable working with gas heaters. Make sure the shutoff valve supplying gas to the heater is on. Turn the gas valve to "pilot", press and hold it while attempting to light the pilot. Once the pilot is lit, continue holding the gas valve knob down for about 30 seconds. The pilot should stay lit once you release the knob. If the pilot stay lit, turn the gas valve to "on". Replace the heater access door and make sure you have proper water flow and attempt to light the heater. If it will not light, or the pilot will not stay on, you will probably have to replace the pilot generator. It provides voltage to run the heater and after time it wears out and produces less and less voltage. A millivolt heater runs on less than one volt so any power loss can be a problem. If you are able, test the pilot generator with a multimeter to see if you are getting at least 500mv when the pilot is on. If not, you should replace the pilot generator or even the entire pilot assembly. Hope this helps...
Sep 27, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
Pool heater won't light
it is possible to light a pool heater with an ignition device,however it is not advisable.since your unit is calling for heat and the gas valve is opening,i suspect you have a faulty ignitor
Jul 21, 2009 | Hayward H Series Pool & Spa Heater 400k...
I have a natural gas pool heater. When I release
Replace the pilot generator. For a quote on the part, send us your heater make and model using the contact form at www.arrowpools.net
Jul 16, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Can't re-light the pilot light
THIS HEATER DO NOT HAVE A PILOT YOU MUST HAVE A DIFFERENT MODEL. DO YOU GAS? TURN KNOB TO PILOT PRESS. LIGTH PILOT WAIT FOR 60 SEC AND RELEASE IF STAY ON TURN KNOB TO ON. IF TURN OFF PILOT MUST BE REPLACE
Jun 20, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Pilot light is lit, but heater will not fire
Make sure thermostat is set higher than water temperature. Make sure pump is running and water is flowing through unit. If gas valve is not opening then flame sensor or gas valve is bad.
Jun 02, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Hayward H Series Pool & Spa Heater 200k Btu Propane Gas Milivolt Ignition H200p1 Logo
35 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
