When hoovering with Dyson DC50 its never a sweet smell when picking up
Many things can make it smell bad wash filter top and lower in hot soapy water and rise well and dry well in sun
wash bin and all it's parts in hot soapy water and dry well
clean brush roll and check for any bad smells in head
could be from motor over heating or near to failing if above does not get rid of smell i would say it's the motor
SOURCE: Dyson DC07 burning smell.
sounds like it is on the way out this may be because 1, you need to clean the filter cos when its dirty it stop air from going around the motor witch makes it get hot and overheat 2, also if you allow the bin to get to full this will also stop the motor from geting air to it so a good clean on your filter and bin will allow air to the motor then no overheating should accur
SOURCE: dyson dc14 has no suction and burning smell
The guide suggest that you change the belt by putting it around the brush, through the plate, and then try to push it around the spindle, which has a space between it and the casing. I spent an hour trying to do this and couldn't get enough purchase to get the belt around the spindle. Instead I put it around the spindle first, and then through the plate, and then through a screwdriver to hold it in place. I then got the brush and put the band over the brush, rotating it until it went into the groove. I then reassembled. It worked, and I now realise how powerful that brush is. Hope it works.
SOURCE: After hoovering yesterday my dyson ball wont stand up right.
solved this today by folding the upright part back as far as it would go, and wiggling it a little. It clicked back into place.
SOURCE: Dyson DC07 keeps cutting out and smells of
does it smell like an electrical burning smell? sounds like your motor has went bad.
SOURCE: dyson smells of burning when
It sounds like the motor has overheated and has now been irrepairable damaged.
The motor has a built in over-current trip to protect itself (and you if it seriously overheated and caught fire). This normally automatically resets itself, however if the motor has just about had it, the moment it is switched on, it just trips again.
The primary cause of motors overheating is that the filters are not cleaned or replaced frequently enough. Dont be fooled by Dyson's "lifetime filters". They need to be regularly cleaned and replaced when necessary.
Replacement motors are avaible on eBay for about £25, however repalcing one requires good DIY skills and tools.
Have a look at www.dysonmedic.com and see if you feel you can tackle it yourself. If not, take it to a repair shop or call the Dyson helpline.
