Question about D-Link Xtreme N DIR-655 Wireless Router
There is an Excellent signal but it's not connecting
There is an Excellent signal in my laptop from the dlink 655 router and it does connect but it i can't browse the internet nor i can do anything that is related to internet. i tried to setup dlink 655 with the configuration CD (automatic config) but nothing works..... i can't connect to the internet!!
please help..
  • 86 Answers
That´s because of the ip assignment you have to set the ip of the router in the same net work ip scale of you modem that connects you to your isp example if ip modem is 192.168.0.10 then the ip you must set on the wan port mustbe 192.168.0.100, also check that you are connecting the out of the modem to the wanport on the wireless router.
Hope it helps
Posted on Jun 25, 2009
My laptop is unable to connect through wifi even when the signal is excellent......then what I have to do?
Check the security setting in the router. You may need to add the laptop to a list in the router to allow a login.
Oct 17, 2014 | Computers & Internet
My wireless connection , says "Limited or no conectivity" I have excellent signal strength. This occured when i plugged in a second lap top with cable. Now only port 2 works and wireless is restricted. I...
Usually this is caused because the security settings on the laptop or PC do not match what is setup on the wireless router. Login to the wireless router and look at what is setup for security, WPA, WPA_PSK, etc, also the passphrase, it is case sensitive. The setup on your laptop must match.
Jun 22, 2010 | D-Link DIR-655 Wireless Router
I have a DLink Dir-655 router. It seems drop a lot.
try to configure your Internet connection settinngs and router cables
Jun 07, 2010 | Computers & Internet
Cannot connect via wireless to dlink 655. wired connection works fine. when i disconnect to go wireless the laptop sees the dlink but there is no internet connection. running Vista Home Premium. static...
You must manually configure the wireless settings. Go to Network and Sharing Center > Manage Wireless Networks. Remove all the listed network there. Then click Add > Add Network in Range > Select your signal > Type the security if you have and press connect. That should do it.
Sep 23, 2009 | D-Link Xtreme N DIR-655 Wireless Router
There is an excllent signal but i can't access internet
Call your neighbors who own the WI-FI and tell them to pay their internet bill or stop filtering you.
GL!
Aug 24, 2009 | D-Link Xtreme N DIR-655 Wireless Router
I am unable to connect to the internet with my dlink
Just connect my dlink 615 to a new dell computer on the vista page for the Network and internet the broadband connection is disconnected. What can I do to connect it? When I switch the dlink network back to the old computer everything works fine.
Aug 03, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Cannot connect to DLink DIR-655
The part below is all you need to look at, the rest is Ethernet which is your wired connection, ethernet card.
Here is what are causing your problems from what you gave me and basically your computer is not communicating with the router:
1)I don't see any IP address for your laptop so you can't get on the internet if you don't have an IP address, also, I don't see any gateway address. The gateway address is your router address, and that address is given to the router automatically from your Internet Service Provider.
So if your computer cannot see the gateway address then the gateway address (router) cannot give you an IP address to get on the Internet.
Your Wireless card looks ok, that is the physical address and if you were able to do the loopback then its working.
So on your laptop I would begin from the beginning. Go into network connections and delete the DLink connection if it is there. Then Start>control panel>Network connections>click wireless network connection>click change settings of the connection on the left window>click wireless network tab>make sure checkmark"use windows to configure my wireless network settings>click add a new network>TYPE IN THE SSID FOR THE NETWORK>ENTER WEP/WPA KEY>CLICK OK, then close and you should be connected.
You said other computers are able to access the internet thru the DLINK so it all points to your laptop not being configured correctly.
HOWEVER :)...I see alot of "Media disconnected in your list. Make sure all of the lights are working on the front of the router, if not check the cabling or call the ISP sometimes the problem is on their end. Hope this helps, keep me updated.
C:>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : HPdv7
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Atheros AR5009 802.11a/g/n WiFi Adapter
Physical Address. . . . . . . . . : 00-24-2B-12-FD-63
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
May 01, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Can't connect to my K-jam to my new DLink DIR-655 wifi router
Can't connect to my K-jam to my new DLink DIR-655...
Mar 11, 2009 | i-mate K-JAM Cellular Phone
Dir-655 router
Yes. Here's a link to the spec sheet:
http://www.dlink.com/products/resource.asp?pid=530&rid=2027&sec=0
What specific problem are you having?
Jan 31, 2008 | D-Link DI 514 Wireless Router (DI-514)
D-Link Xtreme N  DIR-655 Wireless Router Logo
376 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
