Question about Tecnik TKL9290 Front Load Washer / Dryer
Washing machine keeps stopping at the beginning of a cycle
Ever since I started using the dryer with very good results I have problems with the washing machine- Every time I start a cycle it stops before it reaches the next point and just freezes - the light is still on but doesn't move so I move it manually to the next point and it carries on to the end - sometimes it stops again & I have to move it along ...I don't know what else to do - I'm waiting for a plumber to call me back but he doesn't seem to be in any urgency....Please help!!!
  • cardiff Nov 05, 2007
    if left on its own it just stays on without advancing - the longer i left it was 12 hrs without moving at all....
    Problem Solver:
  • 14 Answers
If you leave it on its own, how long/will it ever, advance on its own?
Posted on Nov 05, 2007
  • Amanda217 Jan 14, 2011
    I have the same problem with mine - it needs manually progressing in the early stages of the programme, although it seems quite happy to work it's own way through latter stages. Any advice would be appreciated, please.
I have a whirlpool ultim as text care heavy duty super capacity plus washing machine. Will only go through one cycle..will stop and hum. What could be wrong?
if it stops at the beginning of the wash cycle , it could be a failed start/run capacitor for the motor
if it hums at the start of a rinse cycle it could be a problem water control solenoid
Humming in a machine is a frequency vibration caused when something that is supposed to move is not allowed to and the resultant frequency sets up a vibration in the unit
if under warranty , get in a technician for a warranty fix ---if not get in a technician to check it out and get a quote for repairs
Mar 21, 2016 | Whirlpool Washing Machines
My ariston washer dryer just keeps filling with water it's not a solenoid because it stops and starts it also won't pump out and it's not the pump because it starts at the beginning of the cycle
there is a pressure sensitive unit at the top of a small tube that when the pressure in the tube equals that set by the wash setting will shut off the tap and start the wash program
if it starts the program but the water keeps coming in , the problem will be in the water control valve at the machine end of the hose
Nov 26, 2015 | Washing Machines
Machine stopped working during use.
Hello! There is a trouble shooting guide for major appliances that frequently suggest parts and video links on youtube that diagnose your problem & instruct you how to repair your appliance. The site is called Make sure you have the model number before you begin since the instructions are model specific. Good luck.
Jun 21, 2015 | Candy CNW136 Front Load Washer/Dryer
Washer repeats entire cycle - does not stop at end of spin cycle.
It is possible that presence of moisture within the START button can trigger the cycle to continue as it keep the processor to continue the wash cycle,Hence you must remove the panel and board after disconnecting the wiring harness and use a hair dryer to warm off any presence of moisture on the panel and board. Do it with time to ensure there is no moisture within the panel.
I think this must solve the issue. Repeat the work many times as sometimes moisture and dirt together might form a conductive bond to trigger as a pressed on switch. If possible open panel to clean switch pad.
Jan 23, 2013 | Kenmore 2.1 cu. ft. Compact Portable...
Machine stops half way through program
One looses touch with all the codes available, but normally if washer stops mid cycle its due to a blocked or faulty drain pump. OR incomming water is to slow or defective inlet sensor. Switch off and start from the beginning. See if you can get machine to drain by moving the timer etc. If not, rectify pump problem. Take note where in the cycle the problem arises.
Jul 21, 2010 | Zanussi ZWD1680W Front Load Washer / Dryer
Maytag MDE9700AYW electric dryer doesn't stop in sensor dry mode.
The link below contains the service manual. Detailed Troubleshooting begins on page 10.
Good luck
MDE9700 Service Manual
Sep 22, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Washing machine begins the wash cycle going immediately to the agitate cycle, without filling up with water first.
water will not stop running into drum unless shut off at faucet does not happen all the time and wife can't find her rubber boots
Apr 26, 2009 | Washing Machines
Hi, my machine starts for a few seconds then stops and pause button wont stop flashing, have tried turning off and on but same thig keeps happenig, please help x
if it is a HE kind of machine it is supposed to stop and start a bunch of times at the beginning of the cleaning cycle. Did you wait for a while to see if it ends up running the cleaning cycle?
the new machines are kind of freaky the way they work.
Apr 09, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
Washing Machines Logo
196 people viewed this question
Top Tecnik Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
