Question about Dell Inspiron 15 Laptop
Where is the memory card slot in my dell tower
    Top Expert:
  • Dell Master
  • 8,517 Answers
You may not have one fitted if you can not find one,it should be on the front of your tower
Posted on Apr 06, 2015
5 Suggested Answers
SOURCE:
tleeski
  • 29 Answers
SOURCE: can't find the memory card slot
Memory modules are accessed from the bottom of the unit by removing the screw on the door that is labeled by the letter 'M'.
Posted on May 25, 2009
  • 489 Answers
SOURCE: can't locate memory card slot for my cell phone's sandisk thing
This model does not have a memory card reader installed. If you need to access memory cards, you will need to obtain a PC Card for that purpose or a USB memory card reader that supports the card format you wish to use.
Posted on May 26, 2009
  • 12 Answers
SOURCE: Computer-challenged person can't find memory slot
HI richard i have dell 1525 does not power on .power switch and strip ok .charger ok .any idea to power on tell me deeply ok thanks
Posted on Nov 21, 2009
  • 733 Answers
SOURCE: how to use SDHC memory card on Dell inspiron.
you need to search if the driver is instaled,if not go to dell.com and download the driver and this should resolve your problem.
Posted on Nov 24, 2009
My tower keeps running and monitor says no signal on my Dell t5274
Turn off the computer and then take out all the memory from the computer. Reseat the memory into one of the slots and then turn the computer back on and see if the video comes back. If it doesn't then repeat this step for each memory stick in each slot one at a time.
If after trying all the memory and all the slots you still can't get video then the motherboard is bad and would need to be replace
Feb 04, 2012 | Dell Computers & Internet
When I plug in my compactflash memory card into the slot thing on my tower nothing happens. how do I get it to work?
You probably have multiple slots. and some memory cards will fit into other slots. usually the card type is listed under each slot. make sure you have it in the right one first. also there is usually a light that will change colors when it detects a card inserted. then windows should take care of the rest.
Nov 04, 2010 | Computers & Internet
Where is the pci graphics card slot for the dell dimenson 4500s?
The Motherboard Model for the Dell 4500s is 4T346, this has only two PCI Slots. it does not have AGP slot or a PCI-E slot for a Sperate VGA Card. Unless you have a old PCI VGA card, you have no option of upgrading your VGA. ( assuming you have a old PCI Vga card, chanced are the onboard VGA will have more memory than the old PCI VGA card)
May 08, 2010 | Dell Dimension 4500S PC Desktop
Where is the serial number for my computer?
Use the Service Tag number, or the Express Service Code, (ESC), which is on the white Service Tag, on the back of the computer tower.
You may also have a Service Tag label on the top of the computer, or up on the side of the tower.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&dl=false&l=en&s=gen&docid=DAD1AFE6F90145549F7AA300E6671E47&doclang=en&cs=#3
Copy and paste the above into your address bar, then press the Enter key.
By the way. The Maximum Amount of ram memory for EACH ram slot is 1GB, not 512MB, as Dell states.
TOTAL Maximum Amount of ram memory for the Dimension 2400 is 2GB.
(1GB in EACH ram slot. There are 2 ram slots)
Ram memory used is DDR at 333MHz, or also can be stated as PC2700.
The best Processor you can use is an Intel Pentium 4, 3.06GHz, with HT. (Hyperthreading Technology)
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Northwood_.28130.C2.A0nm.29
The best graphics card is an Nvidia GeForce 6200 O.C. (Overclocked edition), that has dual monitor ports. (256MB of graphics ram)
Yes, I know the processor, and graphics card are real old news, but so is the computer.
Anything I can help with?
Feb 04, 2010 | Dell Dimension 2400 PC Desktop
How do i install memory card in my dell computer dimensions
Here is a general video that should show the simple process. Don't be intimidated. It is a hard upgrade to screw up. There is only one type of slot you can put ram(memory) into so you will know if you are doing it correctly. Most ram slots are in the general area shown in the video on the largest board in the tower.
Sep 13, 2009 | Dell 6328C DIMENSION SYSTEM BOARD Computer...
NEED TO KNOW HOW OR WHERE TO ADD THE MEMORY CARDS IN MY DELL DIMENSION E521...HOW DO I OPEN THE TOWER
Hi There,
Should be very straight forward.
You can find full instructions here;
http://support.dell.com/support/edocs/systems/dimE521/en/SM_EN/index.htm
(this includes opening the cover!).
This model has 4 DDR2 slots and supports a maximum to 4Gb of RAM.
Regards,
MC
Aug 25, 2009 | Dell Dimension E521 PC Desktop
OptiPlex GX270 mini tower
Remove the 256mb memory and insert the 512mb memory in slot1 and see whether it works. Please note that the memory needs to be in pairs.
I think the GX260 is mini tower has two different moles
1) PC3200 compatible with memory - 184 Pin DDR3200 400MHz
2) PC2700 compatible with memory -184 Pin DDR2700 333MHz
Please enter the service tag on dell.com and find the manual and the right memory for your PC
All the best!
Dec 17, 2008 | Dell OptiPlex GX270 Small Mini-Tower...
Memory
Hi
OptiPlex GX270 can be small form-factor, small desktop or small mini-tower. The DIMM slots and therefore maximum memroy capacity depends on the form factor. Double check our OptiPlex GX270 and find memory info below.
Memory Type
333MHz (PC2700) or 400MHz (PC3200) DDR SDRAM
Memory connectors/DIMM Slots
small form-factor: 2
small desktop: 4
small mini-tower: 4
Memory capacities Supported
128MB, 256MB, 512MB, or 1GB non-ECC
Minimum memory
128 MB
Maximum memory
small form-factor: 2 GB
small desktop: 4 GB
small mini-tower: 4 GB
Mike
Apr 13, 2008 | Dell OptiPlex GX270 PC Desktop
Dell Inspiron 15 Laptop Logo
22 people viewed this question
Clive
Clive
Alun Cox
