Question about Philips Magnavox 13MT143S 13" TV
AV channel on magnavox tv
I just got a dvd player and I'm not able to get it to play because the TV doesn't display the AV channel. I had the channel when I purchased the TV the channel disappeared when I auto programed the channels on the TV. Can you help? Thank you!
  • Anonymous Mar 20, 2008
    i would like to use the inputs on the front of my teli, but there is not a way to find the av on the remote or television. is there a way to reset the remote?
    also, i tried channel one, and every other channel, and there are no tv/vcr buttons or av on the remote or tv and the menu has limited choices.
This worked for my 20" Philips Magnavox 20MT4405/17 TV, it might work for you as well. DISCLAIMER: This is just a solution that I pieced together information from various internet sources, as I could not find a free copy of the service manual to verify this. Furthermore, I am not a technician of any sort.
Enter your TV's service menu by pressing this sequence of buttons on your remote while the TV is on:
062596 Menu
Use the arrows on your remote to scroll down to "Options", push the right arrow to enter options.
Change the 7 options parameters in order to (write down the original values in case this does not solve):
OP1: 065
OP2: 215
OP3: 065
OP4: 162
OP5: 204
OP6: 201
OP7: 000
You need to enter all 3 digits for every number, even if there are zeroes. You use the numbers on the remote to do this.
Turn the TV off with the built in power button.
Unplug the TV for 10 seconds.
Plug the TV back in, turn it back on.
If this does not solve your problem, reset the values of the options in the service menu to the values you wrote down earlier because you have a different problem than what this fix works for.
Posted on Mar 18, 2010
  • 934 Answers
Lisa19,
You should have an "input" or "Source" button that woill allow you to cycle through the inputs available on that unit. Set the DVD up and play it / plugged into one the available in sources. Then cycle through the inputs till you locate it...
Some smaller TV's you can use the TV/VCR button to cycle through and still others will allow changing the channel below channel 2 to get there...
Bill
Posted on Nov 05, 2007
Can't change channel 3 to video for dvd playing - video won't come on to use with dvd player
I SUGGEST YOU USE AV CABLES( RCA ) AN CONNECT TO THE AV INPUT OF THE TV
Jun 20, 2013 | Panasonic CT-36D32 36" TV
I have a Durabrand TV and all I want to do is connect my DVD player to it. However, I can't find a channel on the TV that I can play it on. Do I need some kind of code?
DVD players are usually connected with TVs by using AV cable. Your tV will have AV input sockets at its rear side. After the interconnections have been done, select the input to TV to AV. The picture of the AV cable you need is attached.
Jun 08, 2012 | Durabrand Televison & Video
TV MODEL 2168B DISPLAYS DVD FILM IN BLACK/WHITE..WHY?
If it's connected via SCART, check the cable is connected both sides. If this doesn't fix the problem, try a different cable. If this still doesn't fix it, it will be a fault with your dvd player.
Jun 10, 2011 | Televison & Video
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
Jan 01, 2011 | Televison & Video
Can not play video in dvd/vcr player
Well yes whether it be a DVD/VCR it has to be played on the AV-Channel. If you don't have that yet just scan your tv via remote control, but do it manually because automatic skips the av channel. otherwise check that the video itself is not damaged
Mar 30, 2009 | Philips Magnavox DVD/VCR Dual Player
I have purchased a new DVD Player. Please help me connect to a TV with cable.
You need a Scart cable to connect the two. The instruction manual should tell you which port to connect to on the DVD (usually TV). The port on the TV should say AV in or similar . Sometimes you have to tune a TV channel to view the DVD but usually if you select AV on the TV it will play automatically.
Oct 08, 2008 | Televison & Video
Video channel
if your DVD player supports a HDMI cable a single cable is enough for both audio and video channel.
but both your player and TV must support HDMI.
Aug 12, 2008 | Samsung DVD-V4600 DVD Player/VCR
My philips dvd player has stopped playing CD's and DVD's and on the display screen it shows "root". i have had this DVD player for 16months. Can you help me?? cheers
Usually "ROOT" is an indication that the player has read the DVD.
ROOT means that the DVD is in the main menu screen.
Sounds like the DVD player is ok, but you may have a loose connection somewhere.
Check all of your AV connections between the TV and DVD.
Also make sure that the TV is set to the same AV channel as the connection you are using.
E.G. if you have connected the DVD to the AV 1 socket of the TV, make sure that the TV is set to channel AV 1.
Apr 29, 2008 | Televison & Video
Unable to locat and select the AV channel on new LCD HD TV
Hi, try switching your tv to channel 3 or 4 and see if that works- there should be a switch on the back of your DVD player beside the Coaxial Cable outputs-it will allow you to use Channel 3 or 4 as the default to play dvd's. I hope that helps-if more detail or wiring diagram is needed-please leave make and model numbers and i'll try to help.
Cheers and have a Happy Holiday Season!
Dec 21, 2007 | Televison & Video
Philips Magnavox 13MT143S 13" TV Logo
1,327 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
