Home | Printers | Why my canon ipmax 130...
Printers
Problem for Printers
Generic problem for all Printers
Why my canon ipmax 1300 printer always app...
By diazphi on Nov 05, 2007
I have cannon IPMax 1300, I tried to refilled my cartridge at the near ink station to save money but I found out that my printer will always alert low ink. What should I do enable the printer will appear at a normal status. I do believed that the cartridged was fulled after I refilled.
Hope anybody know this problem. I will rate your solution if proven to be useful.
Thank you.
Philip
Comments:
Nov 08, 2007
- Thank you for your suggestion Jackboy but it says It appears there are no printer repair kits available for your printer (canon ipmax1300).
Sorry I could not rate your comment solved.
Nov 23, 2007
- Guide of Reset IP1300 and IP1700 Procedure and step by step of reset Ink Tank Full Error at Printer Canon IP1300 and IP1700 First Step of Reset Hardware
  1. Extinguishes printer, then Lepas cable power Listrik.
  2. Compress and resistant of knob Power doesn’t be released.
  3. Resets cable Power, position of knob power still in compress.
  4. Applies middle finger to button Resume counted 2 times, position of knob power still be depressed.
  5. Discharges you the index finger from knob Power.
  6. You has finalized first phase for reset Ink Tank Full Error ( lamp power blinking).
Second Phase of Reset denan software tools
  1. Download of all files here Password : www.NGEdownload.com
  2. Implements iP1700_iP1300_ServiceToolexe
  3. At USB PORT select;chooses Port printer you.
  4. Knob click Lock Release
  5. Select;chooses ( centang) EEPROM CLEAR
  6. Provides zero paper for print. Then Clicked knob Test Pattern 1
  7. Completed Printer IP1300 and your IP1700 are normal returned.
Same Problem
Dec 08, 2008
-   We bought a new canon iP 1300 PIXMA printer about 1 or 2 months ago. Initially it printed good result. However, for about 2 weeks now no printing comes out. The alert message that it has low ink has been popping up every time we print.
Hope you can help us.
Thank you.
Paz-   pazfv
Best Solution
posted on Nov 05, 2007
Helpful)
jackboy
Rank: Wiz
Rating: 77%, 4370 votes
First understand the printer does not 'Read' the cartridge.
It cannot- It says low ink based on the number of sheets passed through the machine.
You need to figure our how to 'Reset' the counters.
Try www.fixyourownprinter.com- entr you camera make model
see what you get
Comments:
Nov 08, 2007
- You need to examine the Fixyuorownp irnter site more closeley
The repair Kit reference is an Advert.
Look for a Window where you can enter your printer make and model this then will lead to a forum page where the queston can be put.
If the cartridge has a chip fitted ,this needs to be zeroed.
There are devices to do this
Do a google for here is one such
http://www.reevoo.com/reviews/mpn/jr/jri_zapit
Nov 26, 2007
- Fix yourownprinter does rate this problem
In the field type you printer make and model number and persevere with your search.
Also get onto Canon support.
You do not of course tell them you are using third party inks
Simply relate the problem.
Was this helpful?
Yes
No
Popular Solutions for Printers
Questions and Unsolved Problems for Printers
Answer
which all in one printer is cheeper to uses
Answer
konika minolta 1600 magicolor
Answer
DesignJet 100 Plus. Black ink replaced, now it only works for about 12sec and beeps again for new... (More)
Answer
the print is not printing clearly after doing all cleans, change toners etc. it is not clean... (More)
Answer
I am having trouble printing on to card for xmas cards.It prints ok onordinary paper
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Printers:
Top Printer Experts
Rank: Guru Guru
Solutions: 712
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
