Mokomi mike only works
If i have mouthpiece right up to my mouth surely this should be able to pick up sound better can you advise please
    Problem Solver:
  • 11 Answers
Adjust the mouthpiece when you are speaking also volume
Posted on Nov 10, 2007
X3 mouthpiece not working
check c2104 - L2130 - L2131
r2120 - c2100 inside your phone, there may be a problem with the ic locating your mouthpiece
Sep 24, 2010 | Nokia X3 Cell Phone
Only had my LG Neon GT365 for a few weeks and already have a problem where the person I'm calling cannot hear me. Is this a common issue with this model? Is there an easy fix?
It is not a common problem with this kind of phone, maybe the phone drop from you or you sat on the phone, anyway, the problem is that the mouth piece on your phone is malfunctioning that is why people call or people that calls you barely hear you.
All you need to do is to replace the mouth piece of your phone and you will see that after the replacement of the mouth piece, anybody that call you or people you call will hear you clearly.
Just change the mouth piece as advice and you will see that the problem is solve. meanwhile, you can be using hands free pending the time you will replace the mouth piece.
Take care
Aug 09, 2010 | LG Neon GT365 Cell Phone
I can hear callers talking, can make calls, and can hear the person I've called but they cannot hear me. And the voice recorder does not pick up my voice. Any ideas on how to correct this?
The problem with your phone is that the mouth piece on your phone is bad that is why people you call or people that calls you cannot hear you.
All you need to do is to replace the mouthpiece on your phone, after you have change the mouthpiece, you will see that people you call or that calls you can hear you while talking.
All you need do is just to replace the mouth piece of your phone and you see that people will start hearing you when you talk on the phone.
Take care.
Jun 01, 2010 | LG CF360 Cell Phone
People ringin me i can hear them they cant hear me
Hello
The mouthpiece of your phone has either shifted from its original position or it is faulty.
Open your phone and set the mouth piece so that it is in line with the mouthpiece hole of your phone casing,
Close the phone and test it if it works. If it doesn't then the mouth piece of your phone should be changed.
Thank you for visiting fixya
Mar 03, 2010 | Nokia 6300 Cellular Phone
When i call out the person im calling cant hear me, but i can hear them clearly.
Hello!!
The problem is from your mouth piece.
I am guessing you accidentally dropped your phone or hit it on something and that has made the mouthpiece to shift from its original position
What you should do is to open your phone,look at the bottom part of the phone,that is the part you normally speak through,you will see the mouth piece.
Try shifting it so it aligns with the mouthpiece hole on the case of your phone.
Fix the casing back properly then test if it works, i am sure it will
If you cant do this yourself please give it to somebody with experience to do it for you
Good luck
Feb 20, 2010 | Samsung SGH-D900 Cellular Phone
They can't hear me
this is a mouthpiece problem from your phone.
Loose the phone and read the mouthpiece with a meter. Or clean the phone board where the mouthpiece contacts.
If this does not work, it means you have to change the mouthpiece.
You can use a earphone to receive and make calls for the main time, till you change your mouthpiece.
Best regards.
Feb 18, 2010 | LG Zafiro MG810D Cellular Phone
Speaker on phone not working. I can hear the person ringing me but they can't hear me, can you please advise how i can fix this issue?
The problem is from your phone's mouthpiece, you need to replace it. Better still you could get a earphone for you phone, pending the time you fix your mouthpiece.
Take care
Nov 20, 2009 | Sony Ericsson Cyber-shot C702 Cellular...
How do u put on the mouth piece and make a sound?
If you are talking about a single reed instrument such as a saxophone this is how you proceed. First you have to moisten the reed using water or your own saliva. You can do this by placing it in your mouth and rubbing both sides of it with your tongue. Take particular care not to damage the tip of the reed. Take the mouthpiece in one hand and lay the reed on the flat part of the mouthpiece with the thinnest part of the reed towards the tip of the mouthpiece flatside down. The tip of the mouthpiece is the opposite end of the mouthpiece from the one that you put on the instrument. You can't mistake the two. The end that goes on the instrument is like the opening of a tube. With the reed laying flat on the mouthpiece gently slide the ligature ( clamp with one or two screws ) over the end of the mouthpiece and the reed. Take care once more not to damage the end of the reed. Line the very tip of the reed up with the very tip of the mouthpiece leaving a sliver of the mouthpiece showing. Holding the reed in position move the ligature along the reed and mouthpiece so that it is covering the bark part of the cane reed about 1/8 to 1/4 inches from where the bare part of the reed starts. Some mouthpieces have a guide line marked on them. Once the ligature is positioned you can tighten the screws. Do not overtighten them. They just need to be snug enough to secure the reed in position. The reed should be in the position I described in order to speak or vibrate easily. Now you can slightly fold your bottom lip over your bottom teeth and insert the mouthpiece and reed into your mouth. Your top lip should not be folded over your top teeth. Your top teeth should rest on the top of the mouthpiece and your bottom lip should provide a cushion between your bottom teeth and the reed. You should have as much pressure applied between your top and bottom teeth so that someone cannot easily pull the mouthpiece out of your mouth. You will learn how much pressure to apply to affect intonation and produce a good sound with practice. Now with the mouthpiece in your mouth you can blow through it to produce a sound. Your mouth should provide an airtight seal around the mouthpiece if you followed my directions. You can steady the mouthpiece with your hand while try to get a sound. If all you produce is a sqwawk that shouldn't discourage you. What you are trying to do is make a piece of wood vibrate in a controlled manner using breath pressure and your jaw muscles to control the vibration. Do not use too much pressure or the reed will be clamped shut at the tip and not be able to vibrate. You should have at least an inch between your bottom lip and the ligature as to how much mouthpiece should be in your mouth. Once you can consistently make a sound then you can proceed to putting the mouthpiece on the gooseneck with the gooseneck properly installed in the saxophone. You should rub a little cork grease on the cork of the gooseneck before putting the mouthpiece on it. The distance that the mouthpiece goes on determines the tuning. Your lip pressure also affects the tuning but a lot less in comparison. You can vary your lip pressure rhythmically to produce vibrato. Most sax players now hardly use vibrato or use a slow shallow controlled vibrato on notes at the end of phrases. Another thing to note is that to start with you should use about a number 2 reed unless your mouth is particularly sensitive and then I wouldn't go anything less than a 1 1/2 for a little while until you get used to the vibrating sensation and the feeling of your bottom lip between the reed and your bottom teeth. Hope this helps. By the way I have been playing since 1963 and I hope you enjoy it as much as I have.
Aug 24, 2009 | Rico Tenor Sax Reeds Box of 10
Plantronics CS60 - People I call say I sound too soft or distant
1. Check the configuration dial on the left hand side of the base to see if another setting works better. The recommended setting for most phones is 1.
2. Make sure your speaking (transmit) level is not too low. First, try increasing the volume on the telephone. Secondly, the master transmit controls are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting. You can fine tune this setting with the Plus (+) and minus (-) buttons on the back of the base that are above and below the picture of the microphone.
3. Double check the battery has a full charge.
To check the charge, press down on the headset into the base station to ensure it is in the base in the correct position.
The Amber Charge light on the base will flash while charging and will stay solid amber when fully charged.
3 hours = full charge
Jun 23, 2009 | Plantronics CS60 Professional Headset
Computers & Internet Logo
212 people viewed this question
David Payne
David Payne
