Question about Car Audio & Video
Altecsc2100 i need a wiring diagram for altec sc2100
I need a wiring diagram fo computer speakers,Altec Lansing Multimedia FM501011854B
You mean the internal schematic, as in diagnosing / repairing a fault?
Google is your friend.
Look in images section of your browser after entering "altec lansing FM501011854B, schematic".
OEM's / Original Equipment Manufacturers as a rule usually don't post full circuit diagrams of their products on the web, to avoid competitors pirating their products.
But you may come across the schematic on a site that stocks service /repair manuals.
Otherwise search for Altec Lansing (Consumer Electronics) website.
Oct 13, 2017 | Audio Players & Recorders
Altec lansing 9 pin din schematic diagrama
try phone app called electrodroid its at google store free app showing pin diagrams ,that might help
Mar 25, 2016 | Altec Lansing Audio Players & Recorders
Need wiring diagram and what is the use the black pin?
I don't have a wiring diagram but the black pin is if your sound card supports 5.1 you would plug the black pin into the back hole on the sound card. If not, use the green pin (in the green hole) and the black pin would not be used.
Jun 18, 2010 | Altec Lansing AVS 500 Computer Speakers
Need wire diagram 4 altec lansing acs295 4 red connctor
I have the same speaker set. maybe we can help each other. My plugs are all fine but my sub is not connected to anything at all and I need to know were they must go on the pc board. Maybe we can trade some photos on the wiring diagram?
Mar 14, 2009 | Altec Lansing ACS 295 Computer Speakers
WIRING DIAGRAM
yo have wiring diagram :)
send your e-mail address to southener83@hotmail.com
Apr 24, 2008 | Altec Lansing VS2121 Computer Speakers
Need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
AVS500 altec lansing speakers
Here is the link to the product manual. Hope this helps. :}
http://www.altecmm.com/downloads/LAT/AVS500B%20manual.pdf
There is a wiring diagram in it.
Nov 23, 2007 | Altec Lansing 621 Computer Speakers
Wiring for Altec Lansing avs500
Hi, from a very old Altec ACS48 : Green - right speaker Red - left speaker Black - common, ground White, Yellow & another Black - power switch Orange - Led indicator Below is the pin layout
Jun 24, 2007 | Altec Lansing AVS 500 Computer Speakers
Car Audio & Video Logo
64 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
