Question about Lomographic Colorsplash Flash for 35MM Cameras Flash
My color splash flash doesn't work anymore, and its not the batteries...what can i do?
Remote control doesn't work anymore
First thing is the check the batteries and the battery contacts
Oct 28, 2012 | LG 47LG50 47 in. LCD HDTV
Doesn't start anymore
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.If this doesn't do it please reply to this post and we'll go on from there.
Apr 18, 2012 | Texas Instruments TI-84 Plus Calculator
After moving, my Philips HDTV doesn't show normal picture anymore. I can hear the sound but all it shows is many different color at once shifting down just the top of the screen (and it will do this...
The tv have a colors wheel design into it tv.The tv is now having grinding noises or colors pattern mess up or tv flashes of Black&White within the color picture.Mean the tv colors wheel disc it is worn out and it is not spinning inside it motor axis anymore.If u are not mechanically incline,don't tries to change the colors wheel by ur self,will cost u more problems,than it worth trying to save some money by trying to do the job ur self.Hire a bonded tv Tech.to do the job.The tv part and the labors should cost u about $500.
Jun 14, 2011 | Philips 50PL9126D/37B 50" DLP TV
My gameboy color game, Pokemon Crystal, recently had its internal battery die, and will not save anymore. Is there anywhere I can ship it to get it fixed for a reasonable price?
Well you can buy a new gamepack then like that from lukie games then.
It doesn't take much electricity to power the clock and memory to a satisfactory extent, but you are dealing with a small battery and a long period of time. After 5-7 years, the battery is expected to die. When the time comes for you (or if it already has), rather than getting a whole extra copy of the game (which is likely to be used, and its battery may not have much time left either, forcing you to repeat the process all over), it's possible to replace the save battery and start fresh. In this topic, I hope to explain how, and enable the reader to perform the operation on their own. So you could replace the battery inside of the gamepack too.
Jan 13, 2010 | Nintendo Game Boy Color Console
My color splash flash doesn't fire any more...any way to fix it? only use it twice. I may have screwed it up cos I left my batteries in them for months that I didn't use.
I have fixed more strobes with a pencil eraser than I can count. Chances are the battery contacts are green and need to be cleaned you can try this with a pencil eraser. Be careful not to break any of these contacts...if they have been exposed to a leaky battery for long they are very fragile.
Oct 25, 2009 | Lomographic Colorsplash Flash for 35MM...
Battery seems to not charge anymore
you can contact Acer via their website and they will direct you to a local provider or they will send you a replacement.
Jul 15, 2009 | Acer Aspire 5920 AS5920 Notebook
Olympus 1030 sw -Flash doesn´t work anymore
Have you tried to reset the camera to the factory defaults? To do this: have the camera in shooting mode - go to Menu - left arrow to reset - press ok - Highlight Yes and press ok. This will reset the camera to factory settings. See if flash works now.
Feb 11, 2009 | Olympus Mju 725 SW Digital Camera
Picture is all different flashing colors
Maybe you put magnet near to your TV or something that can produce magnetism.... if not the deguassing system is not functioning anymore. .. bring your unit to near service in your place.
Apr 30, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Lomographic Colorsplash Flash for 35MM Cameras Flash Logo
128 people viewed this question
Top Lomo Cameras Experts
Are you a Lomo Camera Expert? Answer questions, earn points and help others
