Question about Intel D865GBF Motherboard
Intel D865GBF motherboard's onboard sound card is not giving signals to speakers . Sometimes only left speaker works but mostly none of them works. I tried many media players & many speakers. But while using sound-max wizard it shows signal in from the mic, so drivers are ok. I have updated the drivers too. What to do...?
  • 615 Answers
It is the problem with the back side motherboard sound port.
so u can purchase another sound card and install it. it cost about 6$ (Rs 300.00 )
If it helps RATE ME PLS
Posted on Jun 25, 2009
    Brigadier General:
  • 7,191 Answers
Looks as if either the speaker wires/pin are broken or the audio socket on the motherboard has been damaged. Try with other speakers or replace the audio jack.
I have lost my motherboard so now how can i download my sound driver for intel desktop board d865gbf
you might have to get a portable usb sound card if you mean dont have a sound card installed or
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or
control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 11, 2010 | Intel Desktop Board D865GBF (MBIND865GBF)...
No sound
check cmos if turned on or not if useing board if card make sure that in cmos tured off try new card
Mar 29, 2010 | Intel D865GBF Motherboard
I am not able to install sound driver. when i check in bios settings there is no sound option for disable and enable.
check under onboard chip. but if you motherboard doesn't have sound device most likely there is no option on it, if you plug a soundcard into your motherboard it will detect itself as your windows starts. there install the driver.
Sep 29, 2009 | Intel D865GBF Motherboard
Sound Quality Comparision
Slight difference.....The sound quality difference is observed.
You can find out the difference.In every motherboard on board sound is not so good.But in sound cards it is disigned specifically for sound.
if it helps
Pls RATE ME
Jun 25, 2009 | Intel D865GBF Motherboard
Intel D865GBF, having sound-max, is not giving signal to speakers. While using sound-max wizard mic input signals are shown, but there comes no sound in speakers while testing it...
Goto the your Start button, control settings, sound, click advanced, make sure your mic is not muted, and the proper input is selected(usb, or however you mic is connected.) Make sure you get levels here when talking or tapping the mic lightly. Sound max should work if this is set correctly.
Jun 24, 2009 | Intel D865GBF Motherboard
Speakers doesnt play
check the motherboard manual and see if it requires a jumper to enable the audio onboard ( if so get the jumper from your motherboard box and seat it on the correct jumpers in the correct position to enable onboard audio ( assuming its onboard audio that you are using ) If not then ensure your sound card is seated firmly and install the correct drivers ( for either the onboard audio or the dedicated sound card ) and then ensure that the speaker cables are connected to the correct connectors on the sound card ( whether onboard or not ) and make sure windows audio is not muted for any of the auxilary lines ie wave etc and if its realtek ensure that you have 2 speakers selected in the HD Control panel and not head phones.
May 08, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I cant play 5.1 chanel sound with motherbord ZX-I945LM4
hi im josh in cebu phils.friend try this solution of mine this will help you.
Let's look at the simple stuff first. Is the card installed properly in your system unit? Have you connected the audio cable from your sound card to your CD-ROM/DVD drive? Are speakers (or headphones) hooked up to the card? Are the speakers plugged in and turned on? (And are they plugged into the correct jack? You don't want to plug your speakers into your microphone jack!) Are you performing a task on your PC that actually produces sound? Is the volume turned up loud enough (both on your speakers and in Windows)?
Okay, now that the easy stuff is out of the way, let's turn to something more difficult. The most likely cause of no sound is some sort of conflict. One by one, change your card's DMA, IRQ, and port settings. (This might entail resetting some jumpers on the card itself, as well as making some software-based changes.)
This problem can also occur if you add a new sound card to a system that has sound capabilities built into the motherboard. You'll need to disable the onboard sound before the new sound card can work. good luck
Mar 05, 2009 | Intel D850MV Motherboard
Mother board speaker drives not working
You can try looking for the motherboard sound drivers upload , it will be quicker to get a temp job and buy another I found
Jan 12, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
What is the maximum onboard VGA support from Intel D865GBF?
This board supports uses Intel Extreme Graphics 2 for its onboard video memory but even Intels site does not explain how much memory it has or if it shares RAM for video memory. Your manual can be found here
http://www.intel.com/support/motherboards/desktop/d865gbf/sb/cs-008983.htm
May 12, 2008 | Intel D865GBF Motherboard
Onboard Audio Problem
Make sure you have the jack plugged all the way in.
Also, try a different set of headphones/speakers.
Feb 28, 2008 | Intel DG965RY Motherboard
Intel D865GBF Motherboard Logo
353 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
