Question about Big Green Egg Grilling
Big green egg does not heat above 600
Big green egg no longer heats above 600; thermometer has been checked and is working fine - can anyone help
  • stuart_take Jul 23, 2009
    Thanks to both - problem solned by taking the device apart and clearing all of the vents / holes.
Make sure your vents are not blocked. also if the coals have been wet and are not fully try they will not heat up over 600.
Posted on Jul 23, 2009
    Problem Solver:
  • 9 Answers
I'm not sure why you would want your BGE to go above 600 but here goes. Are you using a full load of hardwood lump charcoal (to the top of the fire ring...lump because it burns hotter)? Do you have the draft door and the daisy wheel wide open (may even want to remove the daisy wheel)?
Posted on Jul 07, 2009
LOST INSTRUCTIONS FOR BIG GREEN EGG THERMOMETER DUAL PROBE ET-734
Try Googling (Big Green Egg)(model)(manual) without parens.
Jul 02, 2017 | Big Green Egg Grilling
Looking for a big green egg replacement thermometer
There are a bunch of options on Amazon.com.
Apr 12, 2016 | Big Green Egg Grilling
How are you supposed to heat up the green egg
There are you tube videos. I temporarily take daisy vent cap off top of egg, open bottom vent door wide open, light lump coal 2-3 spots with a loof lighter (from ace hardware) and then close lid. I have one section of galvanized dryer vent from Lowes that I stick on top which accelerates preheating of egg. Once the temp gets to 500, I remove the section of vent by grabbing it with a glove or hotpad. Wait a minute or two for smoke to die down. Place daisy back on top and close bottom vent door down to 1/2" and close daisy 1/2 on top and this should drop temp to 175-250. Use fine adjustments 1/6-1/8" until desired temp is reached. Your food can go on at any time after removing dryer vent. Just burp lid by slightly lifting to allow any heat burst to escape. I also have a gas conversion that works awesome. I just add a small smoke ox over burner that provides enough smoke on front end of cooking process. Advice- keep the butts and ribs on for 6 hours.
May 01, 2014 | Big Green Egg Extra Large - XLHD...
Will not get hotter than 250F
Temperatures on the Big Green Egg are controlled by opening or partially closing, the dampers on the bottom side of the grill and the top of the grill lid. The more open, the more air gets to the coals and heats the up. Partially closing the dampers lowers the temp.
Keep in mind, the grill thermometer may be faulty. Try setting an oven thermometer (like the kind used in a regular kitchen oven, that sits on the oven rack) on top if the grill grates, when you're preheating the grill with the lid closed.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!
Jul 04, 2011 | Big Green Egg Grilling
When my green egg gets to temp over 600 the lid becomes lose and falls off when you lift it. I've already broke one. Why is this
It sounds like a problem with the hinge springs, rather than the lid. One will usually break before you realize it has. Then the second one goes, before you realize it. And it's usually when you have the Egg heated to a high temperature. You should also check the steel band around the egg, that is part of the hinge system to make sure it has not been overtightened or is to loose.
The folks at Big Green Egg take this sort of thing seriously and are devoted to their customers. You should also contact them about this issue.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
May 23, 2011 | Big Green Egg Large All-in-One Grill /...
Can you over heat the egg to the point that it is very difficult to open?
I have never heard of that happening. But, the lid of a Big Green Egg is heavy and some times the hinge springs either snap or get weak. Which makes it very difficult to open. But, sealing itself shut, because of high heat, I don't think so.
Mar 28, 2011 | Big Green Egg Grilling
Interior surface of big green egg is flaking off. what cause and what fix. thanks
hello. Eventually the heat and moisture take a toll. Remove all of the flaking with a wire brush then prime and paint it with the special high temperature grill primer and paint now plentiful at home depot, lowes, and many hardware stores. Enjoy your grilling.
Mar 21, 2010 | Big Green Egg Large All-in-One Grill /...
Need heating element for oven of 1950's Frigidaire by GM stove
Fixya is unable to identify parts sources.
Jan 23, 2018 | Ovens
Grilling Logo
441 people viewed this question
Top Big Green Egg Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Johnathan Lence
Johnathan Lence
Are you a Big Green Egg Grilling Expert? Answer questions, earn points and help others
