Question about Epson LX-300+ II Matrix Printer
How to set half half size paper
1.i am printing a invoice
2. using tractor feeder
3.i want to print half size of A4
4.my paper got center tear option
5.after printing middle of the paper (tearing line ) should set to tear
  • Don  Farrell
    Don Farrell May 11, 2010
    How are you trying to control the printer? Are you using the front panel or printer control codes?
  • 1,606 Answers
Look for a latch on the right side tractor drive. This will unlock it so you can slide it sideways on its rail. Set it approximately where it should be, load the paper, then adjust it so you have a slight amount of tension across the paper. I think the rest is software.
Posted on Aug 28, 2009
When I copy to photo paper it reduces automatically, why
Print on special and custom-sized media
To print on special or custom-sized media (Windows)
1. Load the appropriate media. For more information, see Load media.
2. With a document open, click Print on the File menu, and then click Setup,
Properties, or Preferences.
3. Click the Paper/Features tab.
4. Select the media size from the Size is drop-down list.
To set a custom media size:
a. Click the Custom button.
b. Type a name for the new custom size.
c. In the Width and Height boxes, type the dimensions, and then click Save.
d. Click OK twice to close the properties or preferences dialog box. Open the
dialog box again.
e. Select the new custom size.
5. To select the media type:
a. Click More in the Type is drop-down list.
b. Click the desired media type, and then click OK.
6. Select the media source from the Source is drop-down list.
7. Change any other settings, and then click OK.
8. Print your document.
To print on special or custom-sized media (Mac OS)
2. On the File menu, click Page Setup.
Chapter 2
28 Use the device
3. Verify that the correct printer is selected.
4. Select the media size.
5. To set a custom media size:
a. Click Manage Custom Sizes in the Paper Size pull-down menu.
b. Click New and type a name for the size in the Paper Size Name box.
c. In the Width and Height boxes, type the dimensions and set the margins, if
desired.
d. Click Done or OK, and then click Save.
6. On the File menu, click Page Setup, and then select the new custom size.
7. Click OK.
8. On the File menu, click Print.
9. Open the Paper Handling panel.
10. Under Destination Paper Size, click the Scale to fit paper size button, and then
select the customized paper size.
11. Change any other desired settings, and then click OK or Print.
Print borderless
Borderless printing lets you print to the edges of certain media types and a range of
standard media sizes.
NOTE: Open the file in a software application and assign the image size. Make
sure the size corresponds to the media size on which you are printing the image.
You can also gain access to this feature from the Printing Shortcuts tab. Open
the printer driver, select the Printing Shortcuts tab, and select the printing
shortcut for this print job drop-down list.
NOTE: Borderless printing is not supported on plain media.
To print a borderless document (Windows)
2. Open the file that you want to print.
3. From the application, open the print driver:
a. Click File, and then click Print.
b. Click Properties or Setup.
4. Click the Paper/Quality tab.
5. Select the media size from the Size is drop-down list.
6. Select the Borderless Printing check box.
7. Select the media source from the Source is drop-down list.
8. Select the media type from the Type is drop-down list.
Print borderless 29
9. If you are printing photos, select Best from the Print Quality drop-down list.
Alternatively, select Maximum dpi, which provides up to 4800 x 1200 optimized
dpi* for optimum print quality.
*Up to 4800 x 1200 optimized dpi for color printing and 1200 input dpi. This setting
might temporarily use a large amount of hard disk space (400 MB or more) and will
print more slowly.
10. Change any other print settings, and then click OK.
11. Print the document.
12. If you printed on photo media with a tear-off tab, remove the tab to make the
document completely borderless.
Change settings from an application for current jobs (Windows)
To change the settings
1. Open the document that you want to print.
2. On the File menu, click Print, and then click Setup, Properties, or Preferences.
(Specific options may vary depending on the application that you are using.)
3. Change the settings that you want, and then click OK, Print, or a similar command.
Change default settings for all future jobs (Windows)
1. Click Start, point to Settings, and then click Printers or Printers and Faxes.
- Or -
Click Start, click Control Panel, and then double-click Printers.
2. Right-click the printer icon, and then click Properties, Document Defaults, or
Printing Preferences.
3. Change the settings that you want, and then click OK.
9. If you are printing photos, select Best from the Quality drop-down list.
dpi*.
print more slowly.
10. Select the media source. If you are printing on thick or photo media, select the
manual feed option.
11. Change any other print settings, and then click Print.
Nov 04, 2011 | HP J4680 Office Jet All-In-One Printer
Our printer is flashing Tractor1 tear. We are not able to print nor can we get this to quit flashing. I have tried turning it off and back on still having the same issue. Help?
The "Tractor 1 Tear" message is not a error as such, this is an information message showing the printer is set to the front tractor feed (tractor 1) if you press the button directly under "Tear" the printer should move the paper to the tear possition.
If the pritner is not printing I would recomend checking the following;
  1. Ensure the printer is set to "ONLINE" press the button you should see ONLINE TRACTOR 1 TEAR on the display
  2. Ensure the printer is loaded with paper, press the button under "Tear" the printer should move the paper forward if it is loaded into Tractor 1.
  3. If you are not using Tractor 1, ensure you select the paper path you are using within the menu and move the paper selection lever.
  4. Observer the LCD display for any errors that may be seen when print jobs are sent.
  5. Try printing a menu print on the printer this will identify if the printer will print, the menu can be printed in the following way.
    -Power the printer ON holding down the button, keep the setup button held down whilst the printer initializes.
    -When the printer has finished initializing ensure the printer is OFFLINE
    -Press and release the button to enter the MENU
    -Press the button under "MENU" on the LCD display
    -Press the button under "PRINT" on the LCD display
    The printer should print a menu settings page, if this prints OK the most likely causes for the problem are;
  1. The computer system is not sending jobs to the printer (check the correct printer is selected on the computer system)
  2. Connectivity problem (check cabling, IP Addresses etc)
  3. The wrong printer driver is being used
Mar 04, 2011 | Tally T2240/24 Matrix Printer
Hello sir, how to take print on A4 page? please help me
Hi The A4 paper size is an internationally used paper format. Although not often used in America, it is by far the most commonly and widely circulated paper size. At 8 1/4 inches by 11 3/4 inches, it is similar though not quite identical to the American standard U.S. letter size, which is 8 1/2 inches by 11 inches. Because of its ubiquity, all printers and programs have the ability to handle the size, and getting a printer to print to it is a matter of adjusting the settings.Put the A4 sized paper into the automatic feeder in the printer. You may have to adjust the tray guides to fit the paper in snugly. Close the tray firmly when finished.
  • Step 2.Set the printer to register the A4 sized paper inside the the tray. This varies from printer to printer but generally involves going into the print menu, scrolling to the automatic feeder and designating the tray as an A4 tray.Step 3.Select "File" and then "Page setup" in the program you are using.Step 4.lick on the drop down menumag-glass_10x10.gif next to paper size and choose "A4.Step 5.Select "File" and then "Print." Click the "Print Summary" button to ensure the file is set to print to the A4 size.
  • Step 6.Press "Print" to print the photograph.
  • Jul 31, 2010 | Toshiba e-Studio163 Copier
    Paper won't feed
    Inside of the machine is dirty.
    If the inside of the machine is dirty, the printed paper may be smudged.
    Follow the steps described below to clean the inside of the machine.
    1. Ensure that the machine is turned on and there is no paper loaded in the Auto Sheet Feeder.
    2. Place A4/Letter-sized plain paper in landscape orientation, horizontally fold it in half.
    3. Unfold the paper, and load the paper in the Auto Sheet Feeder with the inverted-V edge down.
    4. Select <Bottom plate cleaning> from <Maintenance>.
    5. Select <Yes> on the Bottom plate cleaning confirmation screen and then press [OK].
    Paper will be ejected.
    If protrusions inside the machine are stained, wipe ink off the protrusions using a swab or such like.
    * Important
    Before cleaning, be sure to turn OFF the machine.
    Paper feed roller is dirty.
    Follow the steps described below to clean the paper feed rollers.
    1. Ensure that the machine is turned ON and there is no paper loaded in the machine.
    2. Select <Roller cleaning> from <Maintenance>.
    3. Select <Yes> on the Roller cleaning confirmation screen and then press [OK].
    The paper feed roller will rotate as it cleans.
    4. Repeat this operation twice.
    5. Load three or more sheets of A4/Letter-sized plain paper lengthways in the Auto Sheet Feeder.
    6. Select <Roller cleaning> from <Maintenance>.
    7. Select <Yes> on the Roller cleaning confirmation screen and then press [OK].
    The paper that is loaded in the machine will feed through the machine and be ejected.
    8. Repeat Steps 5 to 7 three times.
    Inappropriate paper type is used.
    Check to see if the paper you are printing on is too thick. See Paper Types You Cannot Use.
    Note that smudging may occur at the top and bottom edges of the paper when using Borderless Printing. Ensure that the paper you are using is compatible with Borderless Printing.
    Thick paper is used.
    When printing on thick paper, set the Paper Thickness Lever to the right.
    This widens the gap between the FINE Cartridge and the paper. Try this maneuver if the printed surface is scratched.
    Media is curled.
    If all four corners or the printing surface of the paper is curled, the paper may become dirty or may not feed properly. Use the paper after correcting paper curl as follows.
    1. Place the printing surface face up (A), and cover it with a sheet of non-printing regular paper to avoid damaging the surface.
    2. Roll up the paper in the direction opposite to the paper curl as per the figure below.
    3. Check the printing paper to confirm if the paper curl is eliminated to within approximately 2 to 5mm / 0.08 to 0.2 in (B).
    It is recommended to print on curl-corrected paper one sheet at a time.
    The media type is not selected correctly in the printer driver.
    On the [Main] tab of the printer driver, ensure that the [Media Type] selected matches the paper loaded.
    In the [Print] dialog box of the printer driver, select [Quality & Media] from the pop-up menu, and then ensure that the [Media Type] selected matches the paper loaded.
    Paper is loaded incorrectly.
    Load in the portrait orientation regardless of the print direction of the Auto Sheet Feeder.
    Ensure that paper is loaded correctly. Slide the paper guides against the paper stack.
    Oct 18, 2009 | Canon Pixma MP500 All-In-One InkJet...
    The text of a document will not print. The
    Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
    For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
    Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
    IBM 1422 not feeding 8 1/2 x 11 paper through multipurpose feeder
    Go into the paper menu and set the multipurpose feeder paper size to letter. It will work if the paper size is set correctly for the MPF.
    Apr 30, 2009 | IBM Infoprint 1422 Laser Printer
    How to print picture using 10x15cm photo paper? usually the pictures printed only half
    Hi
    1) when you begin to print have you set the paper size to the size you require ?
    2) If not when you press print a grey box appears to comfirm printing yes!
    3) press properties top right of page
    4) open tab basic
    5) Alter paper size to correct size
    6) Also check your paper setting on the programme you are using to print from,
    7) Also that the orientation is correct "portrate or landscape"
    grandpaben
    Nov 24, 2008 | Brother DCP 115C All-In-One InkJet Printer
    Print job will not print from the manually feed tray unless I select the Go button for it to process
    Table 3-7. Paper Handling Menu
    Item Values Explanation
    ENVELOPE FEEDER
    SIZE=COM10
    For supported paper sizes
    see page 1-12.
    This item appears only when the
    optional envelope feeder is installed.
    Set the value to correspond with the
    envelope size currently loaded in the
    envelope feeder.
    ENVELOPE FEEDER
    TYPE=PLAIN
    For supported paper types
    see page 1-12.
    envelope type currently loaded in the
    envelope feeder.
    TRAY 1 MODE=
    FIRST
    FIRST
    CASSETTE
    Determine how the printer will use
    Tray 1.
    FIRST: If paper is loaded in Tray 1,
    the printer will pull paper from that
    tray first.
    CASSETTE: A paper size must be
    assigned to Tray 1 using the
    TRAY 1 SIZE option (the next item
    in this menu when TRAY 1
    MODE=CASSETTE). This allows Tray 1
    to be used as a reserved tray.
    TRAY 1 SIZE=
    LETTER
    see page 1-12.
    This item appears only when TRAY 1
    MODE= CASSETTE. Set the value to
    correspond with the paper size
    currently
    Mar 12, 2008 | HP LaserJet 4350 Printer
    PRINTING ON CUSTOM SIZE PAPER
    you need to change the page lenght on the printer. to do so...
    1. turn off printer
    2. press and hold the tear off button while turning on the printer
    3. a menu of the setting will be printed
    4. just follow the instruction
    5. you need to set the page lenght for tractor feeding to 8inchs
    turn off the printer it willsave the setting
    Jan 01, 2008 | Epson LX-300+ II Matrix Printer
    Paper size..
    In WIN98 with WordPerfect9 we had set up dot matrix printer Epson LQ1050 on which to print 8.5" wide by 5.5" long (half page) multipart invoices. In XP apparently MSFT changed this and there is no custom paper size in windows printers. Instead one must use the program's (Word Perfect) page setup where the page size can be entered. Problem is the Epson drivers have not been rewritten to incorporate this change. The optional paper sizes are builtin to the printer drivers. Some folks with the same situation as you have had success using the Forms menu in MS Fax to set different paper sizes. Third party programs such as FinePrint (www.fineprint.com) can also help with this. I hope you work it out ;]
    Apr 23, 2006 | Epson TM U210A Matrix Label Printer
    Epson LX-300+ II Matrix Printer Logo
    511 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
