When I turn the hob on, it has 'L' sign.
Tried the solution offered which says it is childlock, but doesn't work.
When I press the front two '+' signs for a few seconds, it then turns off or sometimes turns to 'E', 'R', 'O' and 'R' in the four flashing lights. It then automatically switches off.
When I switch it back on, it says 'L' signs again
I have only had this for 2 1/2 years so surprised if it is already breaking
i called up AEG customer service, and they said: Press the '-' and bottom right '+' sign and this should take off the childlock. So it looks like there manual was correct. It seems like in some cases you need to do this, or the method suggested in the other post
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for AEG 23 in. 6410KF-N Electric
the hot burner light remains on after it cools down. we get an error message when we try to use it...
(More)
the hot burner light remains on after it cools down. we get an error message when we try to use it and it continualy beeps until we clear it.
Stove is set for use with natural gas, but we use propane gas. Burners are turning black and burning...
(More)
Stove is set for use with natural gas, but we use propane gas. Burners are turning black and burning bottom of pans. Is there an insert for the burner to reduce the flame or regulate the air flow? If there is a need to replace the burners for another type?
i have to replace this item, but I do not know the aperture dimensions. Can you tell me what they...
(More)
i have to replace this item, but I do not know the aperture dimensions. Can you tell me what they are
