Question about HP EliteBook 2530p Notebook
Activate wi-fi - HP EliteBook 2530p Notebook
  • 92 Answers
Download drivers and software from HP Website.
Posted on Jun 25, 2009
How do I connect my Samsung Galaxy to BT broadband?
Are you trying to connect via wi-fi or via bluetooth? Typical hotspots are wi-fi, and that can be as easy as turning on wi-fi (in Settings, Wi-fi - see manual or quick setup brochure) then waiting for it to find an active hotspot and plugging in any necessary password. Bluetooth is much less common. Post more info and I'll try to help more.
Jul 18, 2014 | Samsung Galaxy Tab Tablet PC
Tip
Connect Amazon Echo to Wi-Fi
Echo device has needed an active Wi-Fi connection to speak, process command and more. You can connect your echo device with Wi-Fi by simple steps such as;
Go to Settings option from the left navigational panel.
Select your device and after select update Wi-Fi.
Try to press and hold action button when the light ring changes to an orange and Select Wi-Fi network, enter the password.
Also, Make sure enter password is right to connect to the network. If enter password is wrong, then shows the connection error.
on Mar 22, 2018 | Miscellaneous
Tip
Try to press and hold action button when the light ring changes to an orange and select Wi-Fi network, enter the password.
Also, Make sure enter password is right to connect to the network. If enter password is wrong, it shows connection error.
Receiving pictuer messages
I have had this same problem with Straight Talk before.
First, I would call them up because it would appears that sometimes, Straight Talk does not turn on the internet/picture messaging when doing the activations and they go amiss.
If you have wi-fi in your home or, if you are in a wi-fi hotspot, I would try sending a picture when you are own your own wi-fi or in a wi-fi hotspot. To do this, make sure your "Wi-fi" is turned "On" in the settings menu on your phone.
By having the "Wif-fi" turned to the on position, you can also save on your data usage by using your own wi-fi and various hotspots so you are not eating up your own data. I'm always surprised at how many people do not know this.
So check to see that "Wi-fi" is turned on in your settings and, send a picture over your wi-fi or a hotspot wi-fi. If you are able to send a picture over your wi-fi or hotspot wi-fi then you know that it's a problem with their network and at that point, I would cal Straight Talk and tell them that you are unable to send or receive pictures.
Jan 30, 2013 | straighttalk.com
Wifi will not connect
The below info is from user manual ... downloadable version @ www.pantech.com
Connectivity
This chapter introduces useful tips on how to connect to the
network available that enables applications of the phone to
run.
Using a Wi-Fi network
Connecting to a Wi-Fi network
1. Tap Settings from the applications menu.
2. Tap Wireless & networks > Wi-Fi settings.
3. Tap Wi-Fi to activate the technology.
4. Select and tap a network. You should enter the password
if the network is secured. indicates a secured Wi-Fi
network.
5. Tap Connect. Once the network is remembered, the phone
will automatically connect to it when in range.
Activating Wi-FI Connecting to a Wi-Fi
network
Note The icon next to each network indicates the strength of the
signal. For example, indicates the signal is poor while indicates
the signal is strong.
Using the Easy Setting
1. Tap on the top of the home screen and drag it down, or
press n in idle mode and tap Notifications.
2. Tap in Easy Setting. The icon turns red when the
function is on.
About network notifications
You are informed by default when a Wi-Fi network is available
around you. The message in the status bar indicates a
network is available. Tap Network notification in the Wi-Fi
settings if you do not want to be informed the availability of the
network.
Setting Wi-Fi networks
4. Tap Network notification if you want to know an open
network available.
5. Tap Automatic connection if you want the phone to
connect to Wi-Fi network automatically.
6. Tap WPS button connection if you want to establish a
new wireless connection using the Wi-Fi Protected Setup
(WPS). You should press WPS button on your Wi-Fi access
point within two minutes.
Searching for Wi-Fi networks
Jan 17, 2013 | Pantech Pocket
Tip
How to turn on Wi-Fi on my locked iPod
<p>The ability to connect to the Internet via Wi-Fi is an important feature of the iPod touch. With Wi-Fi, you can surf the Internet, check your e-mail and online games. But first make sure that the WiFi connection If your iPod is locked, you must unlock before you can change the connection settings. <br /> <p><br /> <p>1. Press the "Power" button in the upper right or the "Home" button on the iPod screen to activate the screen. <br /> <p><br /> <p>2. Slide the locking bar from left to right to unlock the device. If the password-protected your iPod, type the password. <br /> <p><br /> <p>3. Click the "Settings" app icon, and then click on "Wi-Fi in the Settings menu. <br /> <p><br /> <p>4. Turn on the Wi-Fi pressing the "On / Off" button in the upper right corner of the screen, then see the available networks. Click a network to connect. If the network is password protected, enter the correct password and click "Join" to activate the Wi-Fi on your device. <br />
on Jul 21, 2011 | Computers & Internet
How to activate wifi of myphone tw8?
In order to work (both when registering and dialing), your iPhone will need to make a data connection to the RingFree servers. Wi-Fi, though not always available, of course, is your best choice.
To enable Wi-Fi on your iPhone:
  1. Go to the Home screen by pressing the Home button or by unlocking your phone.
  2. Touch the settings incon
  3. Look to the right of the Wi-Fi icon. If a Wi-Fi network is listed, you're all set. Otherwise, select the Wi-Fi icon.
  4. If Wi-Fi is "OFF", touch the Wi-Fi toggle to turn on Wi-Fi.
  5. Then select a network (if one is available) from the list that appears on the iPhone.
  6. When connected via Wi-Fi, you'll see a striped upside-down triangle to the right of your service provider's name on the upper-left corner of the iPhone. If there is no network available, you'll have to use the EDGE network.
i hope it will help you for further query feel free to contact.....waiting forward for your reply.....
Aug 09, 2011 | Cell Phones
How do you activate nintendo wi-fi connection
The DS Lite doesn't have built in Wi-Fi. Some games have Wi-Fi built into them, and they have to be activated from within the game itself.
The DSi and newer have built in Wi-Fi. www.nintendo.com has a guide on how to activate it on them.
Good luck,
Mark
Apr 01, 2011 | Nintendo DS Lite Console
Wi fi button
Look carefully on your "Function" keys example, F1, F2, F3 to F12 that are located above your keyboard. On each function keys, there is an icon. One of those is wi-fi. Find which function key has the wi-fi icon then find key to activate those functions. It is called "Fn" key (located in the bottom of your keyboard near "Ctrl" or "Alt"). Now press and hold "Fn" + "F#" then release. This should turn on your wi-fi. On mine, I have wi-fi on "F8" so I would press "Fn" + "F8".
Jan 12, 2010 | Computers & Internet
Cannot get ipod touch to connect to wireless network
Many Wi-Fi issues can be resolved by doing the following:
Basic troubleshooting
  • Tap Settings > Wi-Fi and turn Wi-Fi off and then on again.
  • Verify that you are in range of your Wi-Fi router or base station.
  • Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on.
  • Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet.
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
HP EliteBook 2530p Notebook Logo
172 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
