I BOUGHT A NEW AIR CONDITONER AND WENT TO INSTALL IT , AND THE RESET BUTTON KEEPS TRIPPING , WHAT IS WRONG WITH IT
SOURCE: Air conditioner line freezing up
Check to make sure the filter inside the air handler is clean and that no vents are closed or blocked by furnature or rugs. Check the air handler to see if the blower is operating. You could have a belt off, the door switch could be in the open position or something simple like that. If this checks out OK., you will need to have a technician check the charge
SOURCE: Air conditioner wont cool
the compressor has a capacitor that helps to start the compressor if the compressor does not reach the speed required to jump from the start coil to te continum work in about 10 sec the termic protector disconect the compressor for about 5 minutes but the blower or fan does work just blowing the air and that is not cold
SOURCE: Breaker keeps tripping
Your compressor could be going bad. You would need to check to amp draw on the the leads coming out of the compressor. There is a maximum rating listed on data plate. Something simple could be that your condenser the out side part of the unit is dirty. All you have to do is turn off the shut off switch out side, get a hose and some dish soap and wash the coils. Be careful with the water presssure not to bend the fins. Or some thing even a lot of techs look over is the breaker is bad.
SOURCE: reset air conditioner
This did it for me! Same procedure but its described a little more thoroughly here...
http://sci.tech-archive.net/Archive/sci.electronics.repair/2005-08/msg00472.html
SOURCE: Westpoint split air conditoner remote contol unit
I want to locate a Eolia West Point A/C remote
