Question about HP Office Equipment & Supplies
Driver installation in my computer - HP Office Equipment & Supplies
    President:
  • 1,197 Answers
Kindly provide us ur scanner model number...... so that we might be able to help u
Posted on Jun 25, 2009
Singer future quartet embroidery machine. Computer says "USB device connected to the computer not recognized or has malfunctioned". I uninstalled and then reinstalled software with same outcome.
THE ANSWER YOU HAVE BEEN WAITING FOR!!!
Here is the official problem (straight from singer technical support). The drivers from Jungo are unsigned and windows no longer allows unsigned drivers to be installed. To install the drivers you have to change your computer settings to allow unsigned drivers to be installed and then install the software so the drivers install properly. Here are the steps I took.
1. Uninstall software
2. Restart computer
3. Temporarily allow unsigned drivers. A quick google search will give you directions on how to do this. (If you permanently allow unsigned drivers make sure to change that back after installation so you don't leave your computer vulnerable.)
4. Install the software. You will have to grant permission to all the drivers and software.
5. Install the software update on singer website for your machine
6. Turn on machine and start the software. It should work!
7. Restart computer. This resets your computer settings to block unsigned drivers from installing to protect your computer (if you permanently disabled drivers now is the time to block all unsigned drivers). Don't worry the software will still work since the drivers have already been installed!
If it still doesn't work contact singer technical support.
Dec 14, 2017 | Singer Sewing Machines
MP Navigator EX not installed
There are two possibilities. Maybe drivers does not support the operating system, or maybe the wrong drivers installed.
Solutions for possibilities drivers do not support OS
1. Download drivers from Canon Support & Download
2. Select Product category = Multifunctional Inkjet Printers
3. Product series = Pixma
4. Model = Pixma MP258
5. Document type = Drivers & Softwares, then click Find
6. Select OS = Example; Linux
How to install the the printer driver
Install the printer driver, then connect the USB to the computer. If the USB cable is plugged into the computer, then install the new driver, happens is the failure of drivers install process.
Solution to fix the drivers install error
1. Unplug the USB cable from the printer, to the computer.
2. Uninstall all software and drivers are already installed, then restart the computer.
3. Insert the Driver CD, do the install process. About a 90% of the install process, it would come the request "connect the printer to the computer".
4. Connect the USB cable, with a computer.
5. The computer will detect the printer, and install process will continue until completed. After the install is complete, the printer is ready to use.
Hope it helps
Nov 14, 2011 | Canon PIXMA Office Equipment & Supplies
Canon mp258 printer can not fine driver on my computer it only picked up the scander part
Possible causes of failure:
1. Error install driver process
How to install the correct driver canon
- Do not connect the printer to the computer. So, turn on the printer but do not connect the printer to the computer.
- Insert the driver CD and do the install process.
- At the time of the install process, it would appear the request connect the printer to the computer.
- Connect the printer to the computer. The computer will detect the printer, and install process will continue until completed.
- Then, press the START - Printers and Faxes - Right click the Canon MP258 series Printer - select Printing preferences - click Maintenance - Print head alignment - Align print head - OK - etc. Perform print head alignment until completion (approximately 3 times the heat print alignment). Print head alignment, to configure the printer and computer.
- After the print head alignment is completed, the printer is ready to use.
Install the wrong driver canon
- Connect the printer to the computer, then perform install process.
- Solution: disconnect the USB cable from the printer to the computer, then uninstall the drivers and applications that are already installed, then restart the computer.
- Repeat the process to install in the correct way.
2. Drivers don't support the operating system
If you need a Canon MP258 driver download here:
Canon Support and Download
- Follow the link
- Product category = Inkjet Multifunctional Printers
- Product series = PIXMA
- Model = PIXMA MP258
- Document type = Drivers & Software
- Click Find
- Select OS = example : Windows 7
- Download driver printer; MP250 series MP Driver Ver.1.04
- Download driver scanner; MP Navigator EX Ver. 3.04
I hope this information helps. Thank you for using FixYa!
Oct 07, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
There's no sound or audio in my desktop that problem start when the time i need to reformat my desktop computer
Your computer problem is caused by a missing sound driver. You have to reinstall your computer drivers by it's driver installation cd. if you don't have it or your computer or soundcard driver installation disk is missing. then do this.
Try to find out your motherboard or soundcard manufacturer. You can download the driver that your motherboards or soundcard needs . But if it is too expensive there, try to use driver magician , after installing, driver magician will automatically detect your computers missing or outdated drivers. All you have to do is to Click the all detected driver that driver magician has detected from your motherboard, it will automatically search the internet and download the driver that you have selected. Press save, then install. There you have it. Have a nice day.
Aug 22, 2011 | Computers & Internet
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
I don't know how install driver to positivo sim 1025, like a special manner to do it . I tried almost every manner , but work partially only , and if restart, don't have audio driver active
install chipset driver 1st then install then install graphics driver then install audio driver then other driver or install the chipset driver 1st then install other driver using device manager
Jan 11, 2010 | Computers & Internet
How I install sound driver in compaq3611au.all other driver softwares installed and working. I have all drivers of this model.Installed order Chipset driver,display,UAA audio,Audio driver then other...
Uninstall all audio driver and software.....
First Install chipset driver restart computer
Now run setup for audio driver
while installation a windows will appear for driver search for new found hardware>>>>here click cancel and proceed futher...
after the installation complete , restart computer once you will hear the logging off sound..
After restart computer it will again search for driver for new found hardware....here again click cancel.....
Oct 03, 2009 | HP Compaq Motherboard
My speakers are connected to the computer but wont work
Check to make sure that your drivers are installed to your computer.
  1. Access the drivers for your soundcard. These will be included with the soundcard on the installation CD-ROM. If the CD is no longer available, visit the soundcard manufacturer's website to download the correct drivers. Ensure that you select drivers specifically made for your model of soundcard and that the drivers are specific to the operating system. The download site will list the driver details. If the soundcard came pre-installed on the computer, drivers can also be obtained from the manufacturer's site.
  2. Begin the process of installation. If installing from a CD, insert the CD and follow the installation prompts. If installing from a downloaded program, extract the files to a temporary location on your hard drive. Run the Start, Install or .exe file associated with the driver to begin the installation.
  3. Click "Next" to start the installation. You may have to accept a terms-of-use agreement to install the drivers. Once the wizard has finished, it will display a message saying that installation is complete. If the wizard doesn't restart the computer automatically, reboot it yourself to ensure that the soundcard is configured properly.
Sep 24, 2009 | Logitech X-530 Computer Speakers
55 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
