Question about Radio Communications
Mercedes e240 car radio
No error codes, the radio turns on, the preset stations work, the cd changer works, but no volume or sound. I can adjust the volume with the knob or on the steering wheel and see the bars adjust with no issues....there is a sound when Just no sound out of the speakers. Any ideas????
  • kano123 Nov 05, 2007
    i have a mercedes benz 240 e
Check on the capacitors or audio ic of your car stereo they maybe defective,
Posted on Dec 18, 2007
'09 Hyundai Veracruz with CD changer stuck in 'Disc Checking' error message, and radio stations not staying preset.
You have but one choice pull the unit out and send it in for repair, they do not sell parts or provide repair & troubleshooting information to the public, approved factory repair stations only.
Feb 06, 2018 | Cars & Trucks
Stuck CD in JBL 4 disc CD Changer / Navigation
before you press the cd on button keep holding the eject button while you press power on, I know this works for computers etc.
Feb 13, 2016 | 2013 Toyota Highlander
KD-R805 does not store clock settings
first of all you must be able to check out a few things like do you know how to set your clock for the kd-r805. if you can check to see if you set your clock and set your presets for radio station to be saved. set your clock and set all your station presets once done. Once you have done that turn off the car wait about 60 seconds then turn your car back on to power up the radio and see what happens to your clock and presets . if your clock and presets are not still saved this means that who ever did the radio install has the yellow memory wire connected to switch ignition and not constant battery wire from the factory harness. have someone fix it. If the clock and station presets are still save then it was that you don't know how to program the clock.. how to program your model radios clock .......
STEP 1 : TURN ON POWER TO RADIO
STEP 2 : PRESS AND HOLD MENU UNTIL THE MAIN MENU IS SHOW ON RADIO SCREEN PRESS AND TURN THE VOLUME KNOB TO MOVE THROUGH THE MENU ( YOU MUST CANCEL THE DEMO FIRST TO BE ABLE TO PROGRAM THE CLOCK).
STEP 3: TO SET THE CLOCK SELECT THE CLOCK IN THE MAIN MENU SETTING ROTATE THE VOLUME KNOB AND PRESS IT ONCE TO SELECT THE CLOCK SETTING.
STEP 4: ADJUST THE HOURS AND THEN PRESS THE VOLUME KNOB TO MOVE ON TO THE SECONDS .
STEP 5 : THEN SELECT 12HR OR 24HR TO BE DISPLAYED
STEP 6 : RETURN TO THE PREVIOUS MENU BY HITTING (BACK BUTTON)
STEP :7 TO EXIT SETUP OR MENU HIT THE (MENU BUTTON)
radiorepair@www.windowtintingin239.com
Oct 26, 2013 | Car Audio & Video
Cannot tune radio station manually. Only browse by band memory scan, help
Ok to set Manually Turn on radio Select Tuner select band. Press tuning mode button. The window should switch from preset to manual then tune up or down using the tuning preset time buttons left side/ top / Next to volume knob
Nov 03, 2010 | Teac EX-CD3 CD Shelf System
What channel do you set the radio to inorder to get audio from cd
88.7 , 89.1 I think. Give it a try if not then turn on the disc changer load the cd and once the cd begins to play hit scan on the radio and let the scan feature find the station for you, were ever it stops and u hear clear music then thats the station and just preset it on your preset keys.
Good luck and please rate and vote for me if I helped you. Thanks....
Jun 17, 2010 | Verge VFMMP3 10-Disc CD Changer
Radio no audio 1990 bmw 535i
What happens if you turn the VOLUME to MAXIMUM?
If still no sound , then suspect problem with the speaker , connections or wiring
If loud hissing etc. then speakers appear OK so suspect a radio fault
Jun 15, 2010 | 1990 BMW 5 Series
LG LX-M240 operating instructions: I cannot set the presets
Owner's Manual is PN 3834RH0020U
On pg13
1. Press TUNER/BAND to select AM or FM
(Leftmost rectangular button on left of volume knob)
2. Select station by using TUNING +/-
3. Press PROGRAM/MEMO on the remote
A preset number will appear.
4. Press PRESET +/- (or PRESET ^/v on remote) to
select the preset number you want.
5. Press PROGRAM/MEMO again. The statio is stored.
6. Repeat above for more stations.
Believe you can store up to 30 stations.
Stations on presets 1, 2 and 3 take longer to 'kick in' when listening to the radio
as they are the 'tens' prefix for the preset numbers. 4 - 9 'kick in' immediately.
Jul 01, 2009 | LG Audio Players & Recorders
Pioneer DEH 225 car radio instructio booklet
Actually, there a re a bunch of hits when you Google it.
Here's the answer I found straight from Pioneer:
If your car CD player is a 2006 model or newer:
  • With the ignition on and radio OFF,
  • Press and hold the MULTI-CONTROL button for 2 seconds
  • Rotate MULTI-CONTROL button until display reads CLOCK.
  • Push MULTI-CONTROL button up or down to adjust hour and minutes.
  • Press ESCAPE or SOURCE button to exit
If your car CD player is newer than 2000 but older than 2006:
  • With the ignition on and radio OFF, press and hold the FUNCTION button, until the display pops up, then release the button.
  • (If you do not have a function button, use the AUDIO button instead).
  • Press the FUNCTION button again until the clock shows on the display.
  • Press the UP and DOWN buttons to adjust the hours.
  • Press the LEFT and RIGHT arrows to move to the minutes.
  • Press the UP and DOWN to adjust the minutes.
    When you've completed all the steps, just press the SOURCE button to exit
If your car CD player is 1999 or older:
  • While holding down the CLOCK button, press the number preset button to set the hour.
  • While holding down the CLOCK button, press the number 2 preset button to set the minutes.
  • Pressing the respective buttons consecutively or continuously will advance the hour and minute.
For further assistance please consult your user manual.
Here are some other answers from around the web:
Hold down the source button till the unit switches off. Press thefunction button until it says clock. Use the tuner/volume controls tochange the time. Left/right switches between hour and minute. Up/downchanges the actual numbers.The website I'm including has all the old manuals on it if this doesnot work for you. Problem is, you may not know your model # so willhave to click through the links till you see a pic of one that lookslike yours. Hope this helps. I'm stoked that my clock is finally right!
turn the radio OFF with the car ON
then its easy to set the clock.
Most folks try to figure it out with the radio on
and it cant be done with the radio on,
Turn it off. Hold down "func" or "function" until something happens.
Then press the arrow keys still something else happens. When you're done, press "func" or "function" till nothing happens. Turn it on.
Dec 03, 2007 | Pioneer DEH-225 CD Changer
Volume, Display and FM stations missing?
This could be a bad ground on the radio, or you have serious circuit problems. if a fuse blew, the radio would not work at all. Check the installation first, replace the radio seconds. Good Luck
Jul 29, 2007 | Sony CDX-L420V CD Player
Radio Communications Logo
296 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
