Question about ASUS K8V-MX Motherboard
Disk boot failure insert system disk
I cant boot from cd for new xp installation.it shows a error message "disk boot failure insert system disk".i make 1& second boot device to cd ....i chage the prioroty of both hard disk and cd drive to master and slave.but it always shows the same message.(biostar board and amd sampron processor) .if i remove hard disk then it boot from cd drive otherwise the same message's showing. change the cable also same problem is the result
  • 92 Answers
Looks like your CD-ROM or DVD-ROM is damadged or flat cabel that connect it to Motherboard.
Replace it (Optical drive or flat cable) and you should be able to run from CD.
Best Regards.
If it helps, rate me !
Posted on Jun 25, 2009
  • 615 Answers
Is it recognises Hard disk or not?
reply
i will try to solve u r problem
I'm having this Dell Vostro 1510. Its not getting booted. When i try to boot it, It opens bios setting automatically with sometime beep sound coming. I tried to boot in safe mode, safe mode with...
insert the cd into the cd rom, when dell logo appears start tapping F12 it will give you the option to boot directly from cd.
also you can try system recovery if you have recovery partition with ctrl+F11.
Aug 06, 2011 | Dell Vostro 1510 Laptop
Disk boot failure
The computer isnt seeing your hard drive,make sure your hard drive is plugged in or the pins are set up for master on the back of the drive. If you have it on cs which is cable select it has to be on the end of your ribbon cable. Go into bios to make sure the boot is in the right order.
Feb 15, 2011 | HP Computers & Internet
When I switch on my pc,it tells me disk boot failure insert system disk and press enter. I have XP proffessional sp3 but only have a xp home disk.
If your computer has just been formatted, your computer might require you to insert the boot CD
to be able to run it. You might hence get the error message Disk Boot Failure- Insert disk and
press enter displayed on the screen every time you will try to run it. This might be linked
to:
* 1. The boot options not correctly set in BIOS
* 2. A non bootable CD is found in your CD drive
* 3. You do not possess any bootable device
* 4. You have installed a new hard disk
* 5. The hard disk is not properly plugged
* 6. Your system files have been infected
Get more help and information for Disk Boot Failure. Hope this helps you....
Jan 29, 2011 | Microsoft Computers & Internet
System restore disc 1 erased & overwrote hard drive. Second disc won't start. All i get is a lengthy paragraph that boils down to : MEDIA TEST FAILURE, CHECK CABLE. PXE M0F: EXITING PXE ROM.\r\n ...
Your computer is using the network-connection to try to connect a "network boot server", to try to load a bootable image across the network.
The 'MEDIA TEST FAILURE, CHECK CABLE' is the error-message when no "network boot server" responds to a "network boot request".
The 'EXITING PXE ROM' message is the exit from the P(re) (e)X(ecution) E(nvironment) part of the R(ead) O(nly) M(emory) inside your computer, since the "network boot" did not proceed.
So, insert "Restore Disk #1" and restart your computer, and FORCE it to "boot" from the CD-ROM device -- not from the disk-drive. When prompted, insert "Restore Disk #2" to continue the reinstallation of Windows. When prompted, remove the disk from the CD-ROM device, and restart your computer.
Note that it's also possible that your disk-drive is "dying" -- any attempts to install Windows on it have FAILED. Thus, any time to "boot" from those "not-written" files will cause problems.
Dec 28, 2010 | Toshiba Satellite P205D-S8804 Laptop
Issue in installing OS
OK. Well the error appears because the installation process doesn't recognize your hard drive device. And from the error I suppose it is a SATA HDD. You have two options: 1. Enter Bios, look for hard drive settings and change the mode from AHCI to Compatibility 2. Put the Motherboard CD into the optical device, insert a diskette, boot from the CD and select from the menu the option that is says something like "Sata drivers" or something like this. Restart the computer, insert the Windows XP CD and press F6 when it ask you if you want to install a new hard drive. Select to install the drivers from the diskette and continue the installation as normal
If you need further assistance, just leave a comment.
Apr 07, 2010 | Microsoft Windows XP Professional
Failure to bootup
This message means that the computer could not find the MBR (master boot record) & the most likely cause is a hard disk failure. To prove this obtain an installation disk of an operationg system, say Windows XP, place the disk in the drive, and while its booting up, press F2. From the menu set the boot order to... 1. CD rom drive. Save and exit. The machine will now begin to install the operating system to your hard drive. If you get the same message again, you have a hard drive failure and it will have to be rep-laced.
Apr 05, 2010 | Acer Aspire 3680 Laptop
I have windows xp professional and when I run my
If you get the error-message when you try to boot your computer, your disk-drive is either:
1. not connected to the motherboard
2. improperly connected to the motherboard
3. dead/dying, so that the Operating System files on the disk-drive *CANNOT* be read.
So, the computer tries to boot from an "alternative" device (either the 3.5-inch device or the CD-ROM device) -- if you don't have any media inserted into either device, you will get the error-message.
Oct 25, 2009 | Microsoft Windows XP Professional SP2 Full...
No harddrive detected, verifying dmi pool data, disk boot failure
Help on making a bootable XP install CD for including storage device drivers (such as SATA drivers that's not included in older XP CDs): http://rapidshare.com/files/211421782/nLite_Instructions_XP.pdf
Follow my brief instructions to make an updated XP CD.
May 15, 2009 | Acer Veriton 7500G PC Desktop
Disk boot failure prompt
hi, SInce u do not have a HDD u will need to boot up from cdrom, for that in the BIOS 2nd options,change the boot up sequence first to cdrom , second to any other disk.. let me know
Dec 17, 2007 | ASUS Intel 845 Chipset P4B (P4B WOA)...
System is no boot neither with cd-rom nor hard disk
Hi, Based of your post/description and assuming not hardware problem, you may have to set up the priority boot device in the BIOS to CD. This will tell your mb to look for a boot medium from the cd first. This is normally in the Advance Setup/1st Boot Device. Of course soon as installed, you have to boot from the HD next time. Good luck and kind regards.
Aug 14, 2007 | Intel Motherboard
ASUS K8V-MX Motherboard Logo
293 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
