2 touch keys are reveresed
The @ key is where the " key is and visa versa
    Genius:
  • 1,341 Answers
You need to change your keyboard setting to solve this.
Posted on Jun 25, 2009
Taurus crankshaft pulley
Yes you need a 'Harmonic Balance Puller' If you mean the centre bolt that holds the harmonic balancer to the crank. No not reveresed. Can be removed by placing a socket on bolt head and using a long handle placed against chassis. Touch the starter key to loosen.
Oct 31, 2013 | Cars & Trucks
Immobilizer indicator stays on after start
Dale, did you ever find what is happening with your immobilizer light/charging issue? I have same problem. I think I started car too fast after sticking key in ignition. I turned key extremely fast.
Jul 13, 2012 | 2005 Kia Amanti
I have tried the fn f8 keys and still if it is showing on the projecter its not on the compter, and visa versa thanks
Usually you have to hit the F8 key 2 or 3 times in a row to see it change sequentially. The first time you hit F8 it will go to projector 2nd time you hit F8 it will display both on computer and Projector, Then you hit F8 a 3rd time and it will toggle it back to just the projector again. Good Luck and have a good day...HDTV GURU JAY.
Apr 21, 2011 | NEC Showcase Series HT1000 Multimedia...
Toshiba L500 - the @ and " are reversed
its normal, its not all keyboard that has there "@" on number 2. Even the latest HP laptops that are produced these days have their @ on the same position like yours. You will find @ at the right side of the key board, near later "L".
Its normal, there is nothing to worry about because its not a fault. Just try to get use with the new changes.
Take care.
May 25, 2010 | Toshiba Satellite L500 Series Notebook
In a 3.4L non-interference engine...if the push rods get reversed (short to long or visa versa), can the valves be damaged?
this is an interference engine design, as far as the push rods getting reveresed, never seen that happen so the rule is if u did this and then u put them right and the engione won't run or runs crapp... then you have bent the valves.
Mar 19, 2010 | 2001 Pontiac Aztek
Certain keys dont give the correct character when pressed.when @ is selected i get"""
Pressing alt + Shift toggles between American and English keyboard layout.
Give it a try...this should make your keboard revert back to normal.
Nov 16, 2009 | Dell 0Y3740 Keyboard
Is there a mute button I can use while on the phone
yes when you make a call hit the menu button and select mute and visa versa and when the call is taking place you can hit the left soft key button to mute hope this was helpful:)
Sep 15, 2009 | Samsung BlackJack II Smartphone
Ibm thinkpad keyboard. i type letters, numbers show up. fix?
With my IBM Thinkpad, I had to hold Shift+ScrLk to turn off Number Lock.
Mar 27, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
" is displayed when @ key is pressed and visa versa on my acer 2414 laptop.
You may have your keyboard set to Italian or Spanish configuration. The shift of the 2 is a quote mark on my Italian friend's laptop.
Sep 16, 2008 | Computers & Internet
Main Fuel Pump
Fuses mean short somewhere.Fuse is always live it feeds relay but in tank pump [ fuse#4or#6 i forget anyway visa versa ] is not live until this.Relay clicks once when key tuned to on and once more when key turned to crank engine it is under dash by glove box and loud enough for someone with ear at this spot to hear.In tank pump should not be live until engine starts to crank.
Aug 03, 2008 | 1984 Volvo 240 Series
Computers & Internet Logo
69 people viewed this question
Alun Cox
David Payne
David Payne
