Question about Sharp XR-1S Multimedia Projector
Power supply indication is not seen-Sharp-xr-1s
There is no power supply indication seen. Non of the LEDSs' are on.We have checked with different power supply chords but the problem remain same
  • 66 Answers
Could be a blown fuse
Posted on Jun 25, 2009
  • eddie89104 Jan 22, 2011
    how do you replace the fuse?
The tv went black and the power light went out while watching tv
Dear Jbeck,
the symptom indicates that a power supply problem ..please check the power chord and the related power .if all it seems to be OK then you have to give it to a repairing shop .they will fix your power supply circuit inside your television. Thanks.
Jun 17, 2011 | Curtis Televison & Video
I have XA3021 altec lansing but the power cable missing. Anybody can help me to get a new one?
Hello
Its original line chord is of polorized plug type. You can use any type of power chord. Choose the best quality, and compactability to your Altec Lansings' AC socket. That is all. The line voltage and frequency will differ according to your native place. If you are from US/Canada or other Latin American countries, the supply voltage will be 120AC;60HZ and for Europe and United kngdom it will be 230AC;50Hz. This is the only difference, and it will not effect the used power chord at all. OK.
Mar 28, 2011 | Altec Lansing XA3021 Computer Speakers
Keeps rebooting
Hi, Please check if it is connected to a wall outlet or to a surge protector...If it is connected to a surge protector then connect it to a wall outlet.....
- If it is working then fine....If not then remove all the cartridges...disconnect the power chord from back of the printer and then from wall outlet......wait for 40 seconds then connect the power chord to wall outlet first and then to the back of the printer....
- If working fine then ok or else check adapter is warming or not......and check with different wall outlet and with different power supply....
- Now do the following re-sets :
A) Disconnect the power chord from the back of the printer
B) Press and hold # and 6
C) While holding these keys connect the power chord to the back of the printer and when you see that printer is warming up then release the keys.....
Or else replace the printer.
And also some of the electrical components used to build the logic board in the Cxxxx all in one printers about 2-3 years ago is failing. In my C6180 (with the same problem), there were 4 capacitors (see green cylinder shaped component in the attached - the bulge in the top indicates failure, and that this is the likely the cause) that I replaced (cost was about 60 cents!). If you are not comfortable doing some soldering yourself, you will have to find some help - it took me about 25 min to do the repair myself. Printer works great now.
Hope it helps..
Thanks for using fixya....
Oct 25, 2010 | HP Photosmart C5180 All-In-One InkJet...
My HP Photosmart C6180 All-In-One keeps restarting and won't power on. It cannot even be used as a photo copier nor does it allow for the computer to do anything to it as it has not been powered...
- Please check if it is connected to a wall outlet or to a surge protector...If it is connected to a surge protector then connect it to a wall outlet.....
Aug 10, 2010 | HP Photosmart C6180 All-In-One InkJet...
Trouble indicator came on after a power outage and
When was the last time the backup battery was checked? The trouble indicator could mean a weak or non-working battery. If the system is 12 years old, the battery should be changed.
Mar 07, 2010 | Air Purifiers
Power cord not working
Try unpluggin the power cord and check with battery.
Check whether battery is charging with the power chord on.
Try with a different wall socket.
If this does not help.
Try with a different power chord of the same kind and check whether it works.
If yes, the power chord is the ussue. Best would be to replace it.
else
Try your power chord in a laptop similar kind and check whether the other laptop works fine.
Try juggling the power cord and check whether it gives supply.If yes then check for AC adapter for any damages or cuts. If any is found the contact manufacturer for replacement.
else Main board is the issue.
But before this I would request you to go to the website and check for Updated BIOS and updates for chipset driver.
If any is available then download and install.
Check with your AC adapter if it works, Good, else I would request you to contact the manufacturer for a Main board issue.
They would replace the main board if under warranty.
Jul 22, 2009 | IBM ThinkPad T43 Notebook
My power supply just stopped working!
I too have a dell laptop that the power suppply died on as well.
Is it making any noise or is the indicator light turned on?
The internal electronic components wear out.
Unfortunetly are un repairable. I definetly have pulled one apart and tried to repair it but its not worth it as they mostly are all sealed now.
If the power indicator light is on use a multi meter to check the output on the laptop side of the plug carefully, Remember they still hold a decent amount of power.
If there is no output there are a few options you can follow,
a) Ebay ie dell d600 charger,
b) Local electronics stores,
c) Dell geniune.
d) or find a car travel adapter that you could use and buy a 12volt convertor to run from your mains wall plate.
HOpe this helps,
Cheers
Steve
Apr 01, 2009 | Dell Latitude D600 Notebook
Power supply cable
The power cable using is the normal 3 pin power chord used on computer.
U need to check the power chord and the wall socket...
Jul 24, 2008 | Toshiba DP80F Printer
Pulled the chord while the lamp was on. HP vp6310 does not light upanymore
One of the transistor on the power supply is blown. I can repace it.
Dec 07, 2007 | HP VP6310 Multimedia Projector
Sharp XR-1S Multimedia Projector Logo
227 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
