Question about Goodman GMS90703BXA Heater
Heater can ichange the air flow on the heater
  • Anonymous Mar 09, 2008
    I have a reedy heater pro 115. It turns on and runs for abuot 30 sec. and shuts down. I see a puff of smoke and i don't know what to do.
  • 1,420 Answers
Yes, look at the control board and follow a larger diameter red wire and see if it goes to the blower. Now follow the orange wire from the blower to the circuit board and swap wire locations with the red one. This will change the blower speed from Low to Medium Low. The Blue wire will give you Medium and may be too fast. The faster the blower goes, the cooler the air feels coming out of the registers. If your ductwork is undersized or your air filter is too restrictive, this will interfere with air flow and not deliver the necessary heat when you need it. Changing the blower speed is only a band-aid to bigger issues.
I hope this helps!
Posted on Nov 05, 2007
How do you bleed air out of 2002pontiac grand am 2.2 liter
Ensure the heater is switched onto full heating this could be where the air has got stuck you may need to drain half the water-fluid run the engine whilst filling the water back in & have the heater running blowing full set as hot outlet. should sort the problem. Cheers, Malcolm Campbell.
Apr 07, 2017 | 2002 Pontiac Grand Am
MY HEATER BLOW OUT COLD AIR ON MY 19999 CHEVY VENTURE
Hello, You need to open the two breeder valves and make sheer ur getting coolint throw ur hoses. And make sheer you have no air throw your lines.
Jan 27, 2014 | 1999 Chevrolet Venture
The heater in my 2002 dodge dak. 3.9 wont heat,it blows warm air, ichanged thermostat and flushed rad.Someone said try swiching water (heater) hoses.
check heat hoses going into fire wall to heater core should be hot when engine warm solution clogged hoses going to heater core
Oct 14, 2012 | 2002 Dodge Dakota Club Cab
The heater doesnt heat
Heater core plugged up, flush it from both directions until stops coming out.
No air coming through vents
There are 3 likely possibilities:
  1. Bad heater motor - a dead heater motor means no air flow
  2. Disconnected or hole in air flow hose - sometimes a vent hose will dislodge just enough to disrupt air flow. Check underneath the inside of the passenger compartment for any loose hose connections. You can also turn the heat (or vent) on HI and check the air flow hose for any pinholes that also could disrupt your air flow
  3. Bad Control Center - if the Control Center is bad, it won't trigger the heater motor to turn on and push air
Mar 30, 2012 | 2002 Jeep Grand Cherokee
I receive Lo H20 message at an air energy heat pump. Probable problems?
This is pretty common for LOW FLOW through the heater. Most of the time, homeowners turn the bypass the water away from the heater and this reduces the amount of water flowing through the heater. Check the bypass to ensure that you have enough water flowing through the heater.
There is nothing else that will throw this code unless the flow sensor is bad altogether.
Once you have inspected your bypass, and the code reappears, you will need to have the heater inspected and possibly change out the flow sensor.
Dec 07, 2010 | Jandy Air Energy Heat Pump - 100,000 Btus
I have ahayward H1001D1 above ground pool heater running on nat gas has worked for 3 seasons with no problems last week heater started to make banging sound as if it was rapid cycling ichanged filter...
If your external by-pass is closed almost all the way then it will be your internal by-pass. You find this assembly inside the water manifold at the side of the heater. Part should be about 70-80 bucks.
It is suppose to regulate the water flow so it has time to heat but not boil. Yours is probally missing the control disc and letting all the water flow past the heater so the water in the heater is boiling and that is the banging you hear. Good luck.
Sep 04, 2010 | Hayward Pool & Spa
Ihave an all pro 110 torpedo heater that doesnt ru ichanged all the filters the glow plug works and the eye tells it to shut off but no spray it does spray when i blow thru the hose from the outlet filter...
A small air pump is located on back of motor when sends compressed air into nozzle to lift fuel from tank. It sounds like the rotor portion of your pump is broken
Nov 13, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heater doesn't work. A/C works and air blows, but no heat. Flushed antifreeze and replaced thermostat already. Help.
There are 3 possible cases: 1- The Flap Divert air direction valve for air flowing through the heater core is not doing its job. 2- The heater core gets clogged up. 3- The valve to control amount of hot coolant flow to heater core gets stuck. Let's check if the water can flow to the heater core first, by disconnect the output hose from heater core while running the engine with heater set up at maximum level to see if coolant flowing out. Catch this coolant with a container to refill it back. This way you can eliminate # 2 and # 3. Good luck.
Sep 15, 2009 | Ford Taurus Cars & Trucks
2001 325 cranks no start
AS SILLY AS IT SOUNDS ITS YOUR MAX AIR FLOW METER,OR COULD EVEN BE A REALLY DIRTY AIR FILTER, SERIUOSLY BMW HAD MY CAR IN COULDNT FIX IT, MISSED THE FACT THE AIR FILTER WAS FILTHY AND NOT LETTING ENOUGH AIR THROUGH, ICHANGED IT AND IT STARTED FIRST TURN
Mar 24, 2009 | 2001 BMW 325
Goodman GMS90703BXA Heater Logo
161 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
