We are looking for USB Board of Pakon film scanner F-235
PLEASE, WHAT CAN I DO IF PAKON FILM SCANNER FP335 REFUSED TO SCAN WHEN THE DUST AND SCRACHED REMOVAL IS ON. BUT IF WE OFF IT THE SCANNER WILL SCAN BUT WITH STAINS
Posted on Jul 06, 2010
I have 3 F-235 scanner, they initialize ok, but when scan start it gives an error, I think this is becouse of the USB Board, do you know if someone could fix them.
Posted on Jul 31, 2009
  • ivancito Sep 24, 2010
    HI LEANC ineed the software of this escaner can u tell me how i can get it
    htnak you
Slide scanned has lines, color is off, and looks warped. What is wrong?
If this is an elderly device there's a high likelihood that theres a hardware fault in the unit, did it ever scan properly? If it did and now malfunctions I'd look at connectivity issues so try this unit on another computer and try another USB cable, and with other USB ports.
Jan 20, 2015 | Nikon Super Coolscan 5000 ED Film Scanner
I have a pakon scanner f 235 which read error code 235 ,what can i do to resolve that problem.
the drivers for the scanner might have been corrupted
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options plus you can troubleshoot hope this helps
Apr 08, 2011 | Computers & Internet
Our office has a Sharp AR-235 Digital Imager copy machine and a L1-00 error message has been popping up for the past few months. Just wondering what the problem is and how we can fix it? We had a...
L1-00 is the detection of the scanner in the home position.
Your scan rails may be dirty needing cleaned, maybe add some lubricant.
The scan home sensor may be intermittent, just not seeing the scanner head in the proper position.
You can try blowing it out with canned air, I am sure he cleaned that.
It is possible you have an intermittent connection between the scanner and processor board or a bad processor board.
If it is an off and on issue I would suspect the home sensor . Most of the time that problem is one where you go in and the issue is very obvious. Every now and then you have one that is difficult to nail down and can be a headache.
If you remove the glass and you dont find the scan assembly is hitting anything or is difficult to slide in certain spots, have him replace the scan home sensor and reseat all the connectors to the MCU board. The MCU is the Main Control Unit. Just a term used to describe the machine processing unit.
Feb 23, 2011 | Sharp AR-235 Copier
SCSI to USB conversion for Film Scanner
SCSI to USB converters are available, but I doubt they will be of much help for you, you'd still need a special driver for your scanner.
Windows 7 Professional, Enterprise, and Ultimate support "XP Mode", essentially a Windows XP environment running in a virtual machine. I'd try to get the SCSI interface card and scanner to run inside the VM as a workaround.
Feb 07, 2010 | Acer ScanWit 2720S Film Scanner
No option to scan Film Negatives
In order to see these options, you must have the Film Adapter Unit (FAU) attached to the scanner. The FAU is designed to scan in 35mm film, either positive or negative. The scanner has no options to scan in mounted 35mm slides.
Does the scanner work for scanning at all? If not, you may have a communication problem between the computer and the scanner, i.e., the computer doesn't know how the scanner is configured so it doesn't show the options. If it's a communication problem, check for any other USB devices that might interfere with communication. Especially, some printers seem to take over communications. Try disconnecting all other USB devices (except keyboard, mouse, etc.), reboot, and see if the situation corrects itself.
Also, try the online troubleshooting database for this model at this link.
Sep 30, 2008 | Canon CanoScan LiDE 600F Flatbed Scanner
Connecting an older Minolta Dimage Elite film scanner to a newer computer running Windows Vista
Paul you might want to see if VueScan http://www.hamrick.com/ supports this particular scanner. It often allows older scanners to work on newer computers as it bypasses the Twain drivers.
Jun 20, 2008 | Minolta Dimage Scan Dual II Film Scanner
Canon CanoScan5000/5000F - light bulb out
TheComp, I tried what you suggested, but no luck. The scanner is dead. The computer does not even read the scanner through the usb. I called Canon tech support. They tell me that this unit is not serviceable and offered a 20% discount to buy another Canon scanner. No thanks. I don't need another piece of electronic junk. I'll wait for a sale to buy another make. Thanks for your help.
Apr 10, 2008 | Canon CanoScan 5000F Flatbed Scanner
Scanner not working
hrm, i found out how to solve the issue. remove the film and do a calibration for the frame, now the scanner starts to calibrate, after a 30sec the program told me to put the film in and scan.
tadaaaaa..
Jan 13, 2008 | Canon CanoScan LiDE 500F Flatbed Scanner
USB cable from scanner to new Dell Optiplex 755
If you look carefully at the cable, you will notice it is a firewire cable (IEEE1394), not USB. You will need a firewire interface on your computer to use the Nikon scanner. It will not work with a USB port.
Jan 02, 2008 | Nikon Super Coolscan 4000 ED Film Scanner...
NIKON LS2000 SCANNER
this scan works with SCSI interface not provided by default in PC. So scan uses to come with SCSI board .. you need to install it into your PC .. yes
Nov 19, 2007 | Nikon LS 2000 Film Scanner
1,842 people viewed this question
k24674
jasbo
jasbo
