Question about Electric Lawn Mower
My Wolf electric lawn mower will start but cuts out after 30 seconds then after some minutes will start aagin. Have checked power is getting to motor and is fine. Also put multimeter across motor & that is fine. Have you any suggestions
  • 86 Answers
There may be a fault contact due to vibration check all the electrical wires and contacts if they are very well connected check corrosion point at contacts, use wd40 spray oil in the motor and contacts, there may be a fault in the carbon contacts to the rotor.
Hope it help
Posted on Jun 25, 2009
Fuse gets hot and burns out
Small Engine Troubleshooting - Jacks Small Engines
www.jackssmallengines.com/diy/small-engine-troubleshooting/
Mar 20, 2015 - Engine Will Not Crank; Cranks - Will Not Start; Runs Rough On Low ... Engine not running (After Hot Test); Stops on High Idle; Hot - Will Not ... Paint or oilburn off. .... I have a Honda self propelled lawn mower that will not stop right away ... ends puts the motor out of time change the fly wheel pin if it's not the ...
Electric Mower will not start, trips the breaker? - Instructables
www.instructables.com/.../Electric-Mower-will-not-start-trips...
Instructables
Dec 29, 2015 | Garden
Toro zero turn mower with Kawasaki 691v 24.0 horse motor starts cutting out and smoking after running for about 20 minutes.
Check the oil to make sure you don't have gas getting in your oil. If that's not a problem then you may have a leaking head gasket.
Sep 29, 2013 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
Neighbor mowed the extension cord and mower won't start
Check the cord has been properly replaced. Check circuit with a meter (NOT connected to mains) The live pin on plug should connect to live pin on motor switch etc. (need to take off cover on switch unit)
Cutting through the cord should not have damaged the mower.
Jul 13, 2013 | Electric Lawn Mower
Was cutting grassstopped for maybe three minuts then tried to start mower but it wouldnt . Refueld and a new plug got nothing but tired of pulling any suggestions
check for spark...if the mower runs for three minutes it might be failing because it looses spark as soon as the ignition module heats up.
If your mower cuts out and the spark check indicate no spark then you know you need a new module. While you are changing the module you can check for animal nesting in the cooling fins under the motor cover.
Its usually how lawn mower ignitions get baked in the first place. You cant see it from the outside....so you cant fault yourself for missing it.
good luck and be careful!
Jun 26, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Husqvarna 2009 Tractor Run 30 minutes, sputter, loses power, dies
hi it seems to me either a lack of compression when she is warm /hot /check tappets or a weak mixture /air leak on the inlet someware hope this is of some help merlinv12
Aug 20, 2009 | Parks Optical 13.5hp Briggs And Stratton...
My lawn mower doesn't start -all wires and cords are ok - and then sometimes it starts itself and when i move it it stops again. it was working perfectly fine one day and then the next....its gone it's a...
sometimes you get an internal break of the electric feed cable which shorts out with movement and gives problem that you are having , another fault with them is that the switch has a safety machanism in it which can cut power for up to twenty minutes before it will reset which is done by operating lever as you would normally ,occurs a lot with m/cs used with adittional extension cables,hope this helps
Mar 23, 2009 | Electric Lawn Mower
Mower won't start
13 to 15 amps electric or battery operated mower may runs slow when cutting thick grass. also recommended not to cut grass when it's wet & need very sharp blade to do the lawn. may overloading it, cutting grass too thick also draws too much power. check house breaker first.
Jun 11, 2008 | Black & Decker 19" Electric Lawnhog...
Electric Lawn Mower Logo
539 people viewed this question
Top Electric Garden Experts
Steve Oakes
dannydoesita
ray gallant
Are you an Electric Garden Expert? Answer questions, earn points and help others
