Question about Apple iPhone 3G
How do you get the sim card out - Apple iPhone 3G
    Problem Solver:
  • 6 Answers
I always use a paperclip and it works like a charm. Just pushing it in and with a little pressure it pops open :)
Posted on Jun 25, 2009
I cut my sim card for another phone but now I want to put into my alcatel onetouch, not sure how to put it in. can you help me?
First, read the owner's manual and see which type of SIM card your phone accepts or is configured to make use of for it to operate
Sim cards come in 3 different shapes
1. Normal Sim card
2. Micro Sim card (mid way)
3. Nano Sim card (smallest)
There are SIm card adapters so you can use Micro Sim card in Normal Sim card only phones
There are Sim card adapters so you can use Nano Sim cards in either Micro Sim card or Normal Sim card phones.
**Photos are less than 500kb size so can't upload for you to sight please.
This device uses a Micro SIM card. Insert SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card (flat-edge-first) into the slot, with the gold contacts facing down. Replace the battery while ensuring the gold contacts are aligned. Replace the back cover. Remove SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card out of the slot.
Oct 08, 2017 | Alcatel Cell Phones
Tip
Phone displays "SIM card rejected" or "SIM card unaccepted".
The SIM (subscriber identity module) card is a small card inside your phone that establishes a network connection. The SIM card is provided by your operator or service provider. In most cases, they are the best source of assistance with SIM card problems. Your phone may display a SIM card error message if:
  • The SIM card is out of alignment. If the phone has recently been dropped, bumped, or opened, the SIM card may need adjusting. Follow the SIM card installation instructions in your user guide.
  • The PUK (Personal Unblocking Key) code is entered incorrectly multiple times. This can inactivate the SIM card. If inactivation appears to be permanent, contact your operator or service provider for a new SIM card.
  • You have recently changed service providers. In this case, either your SIM card or your phone may be configured for your previous operator and may require reconfiguring. It may also be that your phone is configured so that it cannot be used with a SIM card from a different operator or service provider. Please contact your current operator or service provider for assistance.
If none of the situations above apply and you continue to receive this error message, your SIM card may be damaged. Please contact your operator or service provider to have the SIM card tested and/or replaced. Or alternately, bring your phone to the nearest Nokia Care point for inspection
on Sep 12, 2010 | Cell Phones
Tip
SIM card Rejected ? orvSIM Card unaccepted?
The SIM card is the small card inside your phone that establishes the network connection. In almost all cases, your operator or service provider is the best source of assistance with SIM card problems.
  • You have recently changed service providers. In this case, either your SIM card or your phone may be configured for your previous operator and may require reconfiguring. Please contact your current operator or service provider for assistance.
on Mar 14, 2010 | Cell Phones
How to fit sim card to ipad
Insert the tip of the SIM eject tool or a straightened paper clip into the hole of the SIM card tray on the side of the iPad.
Press the SIM eject tool or paper clip firmly into the hole until the SIM tray ejects.
Remove the SIM card from the tray, if necessary, and place the other SIM card in the tray.
Push the SIM card tray back into the iPad.
http://www.bing.com/videos/search?q=how+to+fit+sim+card+to+ipad&mid=C532A5A729B9058B83CAC532A5A729B9058B83CA&view=detail&FORM=VIRE6
video insert micro sim card into Ipad
hope this helps
Sep 17, 2012 | Apple Ipad 2 Wi-fi Black 16 Gb Pc Tablet
When I switch On my phone it says "Sim card not valid". And its not taking the Sim Card. But without the sim card its perfect. My IMEI is 359849016183862. Please help me...
Hi, what might be the possible cause of the problem is either the Sim card your using on the phone or the Sim tray where the Sim card is inserted in the phone.
You can use the Sim card in another phone to be sure the Sim card is working properly.
After that, if the Sim card works,That means that Sim tray is damaged and will need to be replaced.
Have a nice day.
Sep 14, 2010 | Cell Phones
Sim card
How to correct sim card error / insert sim card
Procedure to follow
Step 1: Check the sim tray or sim seater to see if it it broken, if it is, replace it
Step 2: If the sim seater/tray is not broken, clean the entire terminal.
Step 3: If the sim seater/tray is not directly on the board, trace the broken led and solder it, or you replace the broken led with another sim tray.
Step 4: If it is still not working, change the battery and put a new battery, because a virus infected battery will always give such problem.
Step 5: Finally, if the problem still persist, then check the sim card and replace with another sim card if the former is bad because a bad sim card will always display such message as insert sim card or sim card error.
Take care
Apr 13, 2010 | O2 Samsung SGH-E250 Cellular Phone
How to put sim card to the iphone?
SIM card slot is in top of iPhone. From iPhone Manual:
If your SIM card was not preinstalled, you must install the SIM card before you can use iPhone.
Install the SIM card:
1 Insert the end of the SIM eject tool into the hole on the SIM tray.
Press firmly and push it straight in until the tray pops out. If you don’t have a SIM eject tool, you can use the end of a paper clip.
2 Pull out the SIM tray and place the SIM card in the tray. The angled corner of the SIM ensures that the card fits only the correct way in the tray.
3 With the tray aligned as shown, carefully replace the SIM tray containing the SIM card in iPhone.
Aug 11, 2009 | Apple iPhone Smartphone
Sim card
Sounds like phone is locked or firmware is bad
Mar 15, 2009 | Motorola Mobility RAZR V3
Sim card rejected
Try inserting the sim card in another phone. If it still doesn't work, the problem could really be with the sim card. Go to your service provider, and request for your sim card number transfered to another sim card. That is if you wanna keep the same number. You could request for another sim card if you'd like. Call your service provider.
Jun 27, 2008 | Lands Phones
Insert SIM Card
My phones displays the message Insert SIM Card even though it has the SIM Card.
Oct 30, 2006 | Nokia 3200
Apple iPhone 3G Logo
44 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
