Question about Evenflo Jenny Lind Crib
Can't find the hardware - lock in Vietnam
I need the automatic locked for the door when slide up to closed and push to open then the door slide down.
I got sample from EU but can't find it in VN market.
In this case, if some one know any suppliers from Europe or USA with seller in VN pls help to let me know.
Thanks alot for your helpful.
I don't know how to attach a picture into here ?
    Problem Solver:
  • 7 Answers
I'm betting your crib is one of the ones that is recalled for that drop-side trigger lock that is supposed to move the side of the crib up and down. If so, they will send you the correct parts to fix that problem for free. Look here:http://www.deltacribrecall.com/
Also here is a website www.productsamerica.com that sells crib replacement products.
I'm guessing there wouldn't be a problem shipping to Vietnam.
Posted on Jun 30, 2009
  • galenseigne Jun 30, 2009
    I wanted to add the phone number for the Delta crib recall: 1-800-816-5304.
Why would automatic sliding door not pop out unless you pull handle?
Sometimes the lock on the handle from the interior gets stuck half way in/ out. Check its position. Mine does this periodically and then won't close, keeps opening. Also verify child safety close switch is in correct position.
May 01, 2014 | 2006 Toyota Sienna
We opened the door, now door won't close. The closer rod is locked open
Turn the screw in the end of the shaft (on the door end) counterclockwise to release all the pressure.Once it closes or slams shut, use that screw to adjust the closing speed. Other problem could be the stay open lock (the metal piece that slides along the shaft) could be all the way out keeping the door from closing. If it is just push on the door a bit then slide the lock plate all the way back to the end of the shaft, and the door will close.
Dec 21, 2013 | Wright Products Tap-N-Go White Screen and...
2000 Toyota Sienna power sliding door is jammed shut. Any solution?
Open the inside panel of the door by popping off the little white clips holding it on. The cable connected to the inside release button is either caught on something or has come lose. Check out this video - https://www.youtube.com/watch?v=MkC2OiOiE_U
Jun 10, 2017 | 2000 Toyota Sienna
My 2002 town & Country Rear sliding door wont close
You need to change the locking mechanism on the door,not the theft lock that you push down by the window,the lock that keeps thew door shut.I dont know why it wouldnt lock,it must be a factory defect,that worn out before its time..
Jul 29, 2009 | 2006 Pontiac Montana SV6
Looking for fuse to shut down automatic locks
If the locks actuate while driving, usually it's due to the door pin switches that need a slight adjustment. As you drive and go over bumps or turns the body or doors flex slightle and the switch sees the door as open then closed and tells the body computer to lock doors again. Check for the black pin switch on door post near door catch and with a small flat blade screwdriver, pull the center cap of the plunger out about 1/8 inch from the black push in part and close door which will adjust the plunger again to correct depth.
Jan 16, 2009 | 2001 Chrysler Sebring
I WHANT TO RESET MY MASTER LOCK , WHAT STEPS I HAVE TO FOLLOW?
Instructions:
Opening the key storage
compartment door
1. Open shutter door to reveal the dials
and the release button
2. Rotate dials to the current combination
(if the lock is new, the combination is set
at the factory to 0-0-0-0)
3. Press down on the release button
to open the door
4. Pull the door fully open
5. Add or remove keys
6. Close compartment door
7. Scramble the combination dials to lock
the door and conceal your combination (A)
8. Close the shutter door (B)
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
(see instructions above)
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
7. Close the shutter door (B)
To hang shackle model
2. Push the shackle release lever to the left
to open shackle
3. Pull the shackle up and out of the lock
4. Place shackle around door knob or other object
5. Close shackle to lock
6. Close the compartment door
Reminder:
(A) The release button will open the lock
until you scramble the dials
(B) Keep the shutter door closed to increase
weather resistance and to conceal the
dials from view
Mar 05, 2008 | Master Lock 5400d: Portable Select Access...
Evenflo Jenny Lind Crib Logo
112 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
Dennis Crouse
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
