Question about NAD 5 x 50W Grey AV Receiver - T744
How to get sound from ps3 from digital out put
I cant get sound out from the amp using a ditgital cable to my ps3 all the ps3 settings are correct. any settings i should change on the amp? or other advise?
    Problem Solver:
  • 4 Answers
Since I don't know what type of amp you have, you may have to delegate the connection on the back of the amp in it's settings. My Onkyo is that way, check your owners manual, if you don't have one, you can google the model number and find one online usually in a PDF. Hope that helps. I know the settings in the PS3 have to be set to Digital out, I own a PS3 and have run in to it, but since you stated all the settings are correct...
Posted on Jun 25, 2009
I have hooked up the PS3 to my TV with the component cable. The audio is connected to a Denon digital audio device using an optical cable. I cannot get the sound to work, even though I have set up the...
I can't give you the exact steps without knowing the model of Denon receiver you are using, but usually you need to go into the setup of the AV receiver or amp and tell it to associate the digital audio input # you've plugged the PS3 into with a specific 'source'. The optical inputs will be associated by default to CD or DVD or CBL, but you usually need to go into the amps setup to specify exactly how you want it to use it.
I hope that helps.
Dec 19, 2009 | Sony Playstation 3 (PS3) Console
I cant get my ps3 to play threw my sony surrond system period the tv is a sony too i have all the hdmi cables hooked up why wont ps3 play on the surround?
You can't get audio from HDMI cables. You have to connect the regular AV cables into your sound system first or you can use the digital output from the PS3 into your sound system if you've got the right cables. You'll also have to configure this through the audio settings. This should solve your problem. Let me know if it doesn't.
Feb 18, 2009 | Sony Playstation 3 (PS3) Console
Sound skipping while playing Blu Ray
HI, make sure the audio out put on the ps3 is set to hdmi and set to stream dolby digital,aac, dts, etc,then set audio input on your 696 to hdmi,also check that audio out for hdmi is set to off in the hardware menu on your amp,if you still have problems use the optical out on the ps3 as the ps3 does not out put hd master audio or dolby true hd only pcm, you will still get dolby digital.
hope this helps.
CABLE GUY.
Feb 08, 2009 | Onkyo TX-DS696 Receiver
No surround sound on ps3
Set the sound out put on ps3 to the optical out put then set sound on ps3 to give you dolby digital,dts,aac etc.
PS, do not set the hrtz range above 100 as this can damage your speakers.
hope this helps.
CABLE GUY.
Jan 05, 2009 | Onkyo HT-SR800 System
No dolby digital signal
Put your optical cables into the amp and not the tv,also make sure the ps3 audio is set to bitstream.
hope this helps.
CABLE GUY.
Jul 12, 2008 | Audio Players & Recorders
Install ps3 on avr-4306
PLUG THE STANDARD PS3 CABLE INTO PS3 THEN TO TV GO TO SET MENU FOR PS3 AND SET VIDEO OUT TO HDMI,PICTURE WILL GO OFF SO BE QUICK AND PUT HDMI CABLE INTO PS3 THEN TV,NOW SET AUDIO OUT PUT TO HDMI,THEN CONNECT TO AMP,IF YOU STILL GET NOTHING CHECK AMP SETTINGS IE INPUT SELECTION FOR HDMI.
HOPE THIS HELPS.
CABLE GUY.
Jun 18, 2008 | Denon AVR-4306 Receiver
Surround Sound from PS3
Are you getting any sound?
If your marantz amp is part of a home cinema system then depending how old it is will depend on if it will do it automatically.I have just bought a sony surround system and it detects the signal range ie it knows it is being transmitted in 5:1 surround.If you have an old system you may have to do this manually, this should not be diffecult there should be a sound setting.
Jan 28, 2008 | Sony Playstation 3 (PS3) Console
Cant acess ps3 Xbar menu,still plays games
it sounds like you haven't set the display settings correctly. turn off your ps3 and try using the red,white,yellow cables (make sure everything is plugged in correctly). if you get a signal, then change the display settings to whatever connection you will use.
hope that helps
Jan 06, 2008 | Sony Playstation 3 (PS3) Console
Ps3 using digital optical and hdmi cables together
There is a conflict in the fact that HDMI gives you the digital surround sound without the need for the optical lead and when you allocate the optical for the sound thats when the conflict starts, you can only use one or the other.
Jul 31, 2007 | Sony Playstation 3 (PS3) Console
NAD 5 x 50W Grey AV Receiver - T744 Logo
278 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
