Question about HP Officejet 4355 All-In-One InkJet Printer
Scanning problem whenever i scan there has been some lines coming with print.what troubleshoot should i do.
    Problem Solver:
  • 7 Answers
Maybe you need to descreen, it is the setting on the scanner...
or maybe or scanner is in poor condition.
thank you
Posted on Jun 25, 2009
I have a brother mfc 240 printer. Lately whenever i use the auto feeder black vertical lines show up all over the paper. If i print by laying something on the glass it doesnt seem to do this. Also if i...
When you use the feeder to scan, the original is scanned across a small strip of glass on the left side, rather than using the long platen glass to scan. If you're only getting lines when you use the feeder, there is dirt or white-out or some other substance built up on that **** glass. Wiping it down with a dry lint-free cloth should probably do the trick, but if the lines are still there you might want to use a damp cloth.
Hope that helps!
Jun 29, 2010 | Brother MFC 240C All-In-One InkJet Printer
The printing function works, but whenever I try to scan something it comes out all black, and whenever I try to copy something, it comes out just gray without the text.
This is the problem with scanner. pl clean the scanner lamp and nearby mirrors. if the same problem retains pl replace the scanner lamp
Aug 09, 2009 | HP PSC 1610 All-In-One InkJet Printer
Whenever I scan a picture or document I get a line going down the middle of the page. When I print the same document the line prints down the page. THIS only happens on the scan not when I print from the...
first of all try to make a copy..when you make a copy if you get lines..then clean the scanner glass and the rollers..if its still the same..connect the printer directlu to the wall outlet and then check
Mar 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Error 6000 is shown!!!!!!!
whenever it try to copy scan or print by canon pixmamp150 printer it shows error 5?please give me a solution to solve this problem.pleeeeeeeeeez
ayman refaie
ayman_refaie@yahoo.com
Feb 19, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Error code:2,114,0
HI
I have Canon PIXMA MP210 printer but problem is that whenever i given comand for print or scan than computer show "Code: 2,114,0" this message therefor printer not print or scan. so please give me solution
Thanking you,
ayyub_thakur@hotmail.com
Dec 06, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Stripes on scanned photo
Do copies come out the same? How about when you print? If you get the stripes whenever the printer prints from the computer or copies, then you probably have a bad ink cartridge. If you get it only when you make copies or scan, then check for dirt on the scan glass. Clean it anyway with some commercial glass cleaner. See if that works.
Dec 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanner leaves three vertical lines on scanned page
A dirty glass base can cause ‘spots’ or blemishes to appear on your final printout. Additionally, if you had some sort of opaque liquid that may have transferred on to the glass base from a previous operation. But the majority of the unwanted vertical lines are generally caused by either a dirty or damaged print roller or faulty LEDs in the Scanner Module.
To separate one from the other you have to check the following:
Do you only see the lines with a Scan operation?
Do your print jobs print fine without any unwanted lines?
If you only see the unwanted lines during a Scan operation, then most likely you have a fault/dirty/obstructed LED module.
If you see the unwanted lines with all print operations (Scan, Print and Copy), then you most likely have a worn out, damaged or dirty Print Roller.
Hope this helps…
RojoSho
Sep 29, 2008 | Brother MFC-7820N Laser Printer
Facing copying problem from scanning section
Although you didn't specify the scanner model, this solution should work.
If the scanner has a top feeder, open it.
You will see a thin strip of glass, either to the left, or right of the large scanner glass.
There is most likely a small spec of ink, white out, etc on it.
Clean the strip glass with rubbing alcohol and the line should go away.
Apr 09, 2008 | Office Equipment & Supplies
HP Officejet 4355 All-In-One InkJet Printer Logo
82 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
