Question about Intel DG31PR Motherboard
P4 ht processor can be used on dg31pr - Intel DG31PR Motherboard
    Problem Solver:
  • 15 Answers
Hey,
It is compatible.
Astitwa
Posted on Jun 25, 2009
Yes it is compatible GD31PR
p4 LGA Process
Dual Core
Posted on Jan 25, 2010
Go Intel site and find Processor compatibility. I found It is Compatible
Posted on Jun 28, 2009
Aopen ux915g
Yes. Any Intel Pentium 4 processor will fit fine. That said A P4 processor is fast, but the Pentium D is much faster. The D stands for Dual Core. This means that they have two on die processor cores instead of just one, as the Pentium 4 does. Two processors also makes it better for "demanding" applications.
The Pentium D is better if you have a motherboard that will utilize the technology. As stated the Pentium D is Duel core. This is Intel's way of creating the closest environment of a true duel processor. The HT is for Hyper-Threading which acts like a zipper and allows several applications to process at the same time. The Pentium D will really make a difference when used with the new 64 bit operating system.
However, HT (Hyper-threading) P4, does have emulated Dual Core processing. In short, the processor makes the computer think its runing a dual core. The Pentium 4 also has a couple different levels, so if you are trying to make a comparison, make sure that you look carefully.
Although neither can match the power of an Athalon or an AMD x2 processor. If you are buying, get something with 64 bit processing. WAY faster and better for games and high graphic systems.
May 13, 2014 | Computers & Internet
Optiplex cpu upgrade
In my opinion the Celeron have been lower performing processors and lower cost. HERE is and article describing the differences between the Celeron and P4
May 08, 2012 | Dell OptiPlex 330 Desktop Desktop Computer...
How do you enable hyperthreading on msi 661fm
You will need to enter the BIOS by hitting delete key during POST.
Then navigate to tab System settings.
Locate the Hyperthreading field name and set it to enable.
Save setttting and exit.
Please take the time to rate my expertise, by rating this solution, its the thumbs up on the top right hand side of this solution.
Thanks
Nov 02, 2010 | MSI 661FM (ms-6540gbb-010) Barebone
I've a 2 processor 1) dualcore e2160 (1.8ghz) 2) p4 ht (3.0 ghz) any one tell me which one is the best
Here is a website where they have compared the two
http://www.maiconet.nl/
I would go with the e2160. and if possible overclock it.
http://www.tomshardware.com/forum/245468-29-e2160-overclock-success
Mar 11, 2010 | Office Equipment & Supplies
I have an ASUS P5S800-VM Motherboard socket LGA775
To answer your question, yes it's possible.
I'm sure you wouldn't like it if I left it at that, so I'll explain a bit more.
It's about as simple as this: The processor you want to install into the motherboard is for an LGA 775 mobo such as yourself. Therefore, it should have no problems when you put it in.
Hope I was of assistance.
Nov 28, 2009 | ASUS P5S800-VM Motherboard
Intel(R) Pentium(R) 4 CPU 2.80GHz
The processor you are talking about is a single core processor capable of Hyper Threading. (HT).
When you allow hyperthreading in the BIOS, Windows will show 2 ghost processors in the device manager.
If you are authorized to acces the BIOS setup,,enter the setup and look for HT or hyperthreading. If you disable hyperthtreading in BIOS, you will only see one processor in device manager.
Besides, if it is a dual core the BIOS must know.
Look on the case of the computwr where the Windows logo apperas, you may find mentioned :With HT technology. It used to be a boasting/selling mantra.
Hope it helps.
Sep 08, 2009 | Computers & Internet
Hello , i have made update to my DG31PR bios , the new update version is 0066 ,,, after update the pc cant enter the windows and i have intel Pentium 4 processor 3.00GHz / 2m ,, after that i return the...
you have no need to update or upgrade your bios version anywhere if it work properly, but now if u have prob wid it,
1. try any other processor (P4, Dual Core, Core 2 Duo e.t.c)
2. reinstall any other version (0066 or 0052), just change the way of installation (this time install it from Floppy drive or other one, which is different to the 1st time u install from)
Jun 13, 2009 | Intel DG31PR Motherboard
looks like you limited to the p4 Prescott, this is a p4 list of the cpu support from asus. I also looked at their bios update page and found no bios improvement. if you can move to the 775 platform ,you can move from p4. otherwise, the p4's are still  good . I had the cpu that is the 2nd one down. 3.2ghz oc'd to 3.8ghz full time with a max of 4.0ghz on air[775 platform] quad-pumped gave me a 1001.3mhz FSB
Supports Intel Prescott CPU
P4-3.20E GHz (800 FSB, L2 cache:1MB, HT, 90nm)   ALL 1006 gogo.gif
P4-3.40 GHz (800 FSB, L2 cache:1MB, rev.G1)   ALL 1011 gogo.gif
P4-3.40 GHz (800 FSB, L2 cache:512KB, HT, D1)   ALL ALL gogo.gif
P4-3.40E GHz (800 FSB, L2 cache:1MB, HT, 90nm)   2.00 1006 gogo.gif
P4-3E GHz (800 FSB, L2 cache:1MB, HT, 90nm)
SEE 4 YOURSELF
http://valid.x86-secret.com/show_oc.php?id=156822
Oct 30, 2007 | ASUS P4P800 SE (890552603657) Motherboard
Intel DG31PR Motherboard Logo
162 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
