Question about Goodman GDS80904BNA Open Flame Heater
Heater can i change the air flow on my heater and if so how
  • Anonymous Dec 15, 2007
    I have everything as I was told to connect to my new blue flame heater,and I have check and I know my heater is clean but I still have yellow tipping going on with no fumes sut or foul oders.some give me some advice please.
  • 1,420 Answers
On the blower, look for a Blue wire, Red wire and maybe an Orange wire. The Red wire is low spped, Orange is Med-Low and Blue is Medium. Look on the circuit board and see what colors are on "Park" and what color is on "Load" or "Line". Swap that wire to what ever speed you want. Remember that increased speed will make the air from the registers a little cooler.
Posted on Nov 06, 2007
Truck will only heat for a minute then quits
make sure hot water is flowing thru the heater core by feeling both hoses, in and out, both should be hot. if not, maybe the valve is not opening to allow the water to flow. If both hoses are hot then maybe the heater valves are not working and you are just bringing in cold outside air instead of the air flowing thru the heater core and providing heater air. Could also be a sensor in the heater that thinks it is a lot warmer than it really is.
Feb 17, 2015 | Cars & Trucks
I receive Lo H20 message at an air energy heat pump. Probable problems?
This is pretty common for LOW FLOW through the heater. Most of the time, homeowners turn the bypass the water away from the heater and this reduces the amount of water flowing through the heater. Check the bypass to ensure that you have enough water flowing through the heater.
There is nothing else that will throw this code unless the flow sensor is bad altogether.
Once you have inspected your bypass, and the code reappears, you will need to have the heater inspected and possibly change out the flow sensor.
Dec 07, 2010 | Jandy Air Energy Heat Pump - 100,000 Btus
My heater is blowing cold air ,i changed thermostat and heater core ,what else could i do,it on a 98 f 150
You need to have two things in order to have heat: hot coolant flowing through the heater core, and air flow through the core and into the vehicle. With the engine warmed up, feel both heater hoses where they connect to the heater core. They should both be hot. If not, then you need to find out why there is no coolant flow. If you have already replaced the core, then you probably have coolant flow. Next, check the HVAC doors to make sure they operate properly, particularly the blend door. If the door is not in the proper position, then you will not have airflow through the heater core and into the vehicle.
Aug 24, 2010 | Ford F-150 Cars & Trucks
I have a 1998 Dodge Dakota 5.2/ V8 4X4 and was told the Firestone service Rep that my water pump and thermastat were defective. I could smell coolant both outside and inside the truck. Also when the heater...
If the heater core isn't leaking it doesn't likely need changing. It sounds like you could have a problem with the heater control valve - a valve in one of the heater hoses that controls flow through the hose. If you smell coolant and see moisture on your windshield (inside) or have coolant leaking onto the floor - you might need the heater core replaced.
Jan 15, 2010 | 1998 Dodge Dakota
Where is the Air Flow switch on a Jandy LX natural gas pool heater? And how do you change it?
The air flow switch is in the upper panel on the inside of the heater. There are gray hoses plugged into it.
Aug 16, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
No hot air from heater, blower runs fine
The heater in your car depends upon a flow of hot coolant going through the heater core in order to get hot air into the car. If the heater core is partially plugged, it will restrict the flow. If you have a head gasket that is putting exhaust into the cooling system, it will eventually get into the heater core. When this happens there is no coolant in the heater core to make the air warm. If the water pump vanes have corroded away the result will be very poor coolant circulation causing the heater to not blow hot air. If your car is equipped with a heater control valve that is not functioning properly, the coolant flow will be restricted. One or a combination of these factors is likely the culprit in your case.
Since you state the 2 things you ruled out, that leaves only the water pump. Is the car running hot? The thermostat may be sticking as well... but im leaning toward the pump.
Jan 21, 2009 | 1994 Cadillac DeVille
1986 VW Golf heater blows cold air
if the car is not overheating, the thermostat is working fine.... replace or flush the heater core multiple times to try and eliminate sediment build-up.
Jan 14, 2009 | 1986 Volkswagen Golf
165 heater is making alot of smoke
Smoke is an indication of an improper air/fuel mixture, partially blocked nozzle or blocked air passages.
Kerosene must be atomized and mixed with the right amount of air to burn without smoke and odor.
You should consult your manual to have a guide to resolving the issue.
1. Make sure pump pressure is set accurate (5.6 p.s.i.). The pump controls the air/fuel mixture.
2. remove nozzle and clean with brush and compressed air. Also inspect rear of combustion chamber where air flows into and around the chamber to ensure proper air flow. Any materials that may be bent should be replaced. If not formed properly, the air flow through the heater changes as a result.
Dec 10, 2008 | Desa International (R165DT) Utility Heater
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
