Question about Ovens
Oven won't work after power cut.
Gas plates - electric oven. Since power went out I can not get oven to work. Has reset timing - tried everything - oven won't come on. Can't find manual anywhere - not even at shop. Can you please assist me.
  • Anonymous Mar 30, 2014
    we have a gas oven and an electric hob which is just about 2 years old. today the electric hob has stopped working and none of the hot plates will get warm
    I have a gas oven and an electric hob mounted in a worktop. Today for some reason I cannot get any of my hot plates to work in the electric hob
The power outage may have been a result of a power surge or included one. Check the surge protection, breakers or fuses, most likely found inside control panel. Of course turn power off to stove before opening up the panel. Breakers should be pushed all the way off before being pushed to the on position.
Posted on Nov 05, 2007
Good Afternoon Friend,
I see that your Frigidaire double oven, model# PLEB30T8CCB, is having trouble with the top oven not heating.
I suggest giving your double oven a hard reset by cutting the power at the circuit breaker for at least 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Turn the oven on to heat up, and if it does not, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
Jan 09, 2012 | Frigidaire 30 in. Electric Gallery Series...
We had a power cut yesterday and today my neff electric oven just shut down completely. The clock has also stopped working.
if you have power to oven but the clock is not working it sounds like overvoltage has damaged the clock if clock will reset and you can set the time oven will work.
Jun 03, 2010 | Neff B1421 Electric Single Oven
Maytag gas oven lock does not release
Unplugging it for a few minutes may reset it.
Sep 28, 2017 | Maytag MEW5530D Electric Single Oven
Circuitry may have gotten tripped during clean cycle. Oven will open and electronics work but neither element will heat.
baked control module for heating elements. if you have a volt meter, check for power when oven on, if no juice its the control element, if you do get juice then its the elements
May 28, 2009 | Whirlpool GBS277PRS Stainless Steel...
My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
I have a classique gas/electric oven and need to set the clock because of power cut. Oven was in house when purchased so have no manual. Think this is model 2320 SS although not certain as plate with info...
Cassique gas top & electric oven. Oven does not have usual temperatures but has 1 to about 20. What do these numbers relate to in terms of temperature
Mar 05, 2009 | Ovens
Nothing comes on
If the breaker won't reset, then you have a fault with your oven,probably an element blown.
If it does reset o/k, and still does not go, then I suspect that you have no power at the oven.
You will need to gain access to the cable entry at the rear of the oven and check the wiring and connections
Plz leave feedback.
Dec 10, 2008 | Kenmore 47783 Electric Single Oven
Electrolux EOG7330 gas cooker - electric timer fails?
Pull off bottom knob of oven shine torch down at 45degrees u will see a red plate turn off power suply and use a small screwdriver to push the plate turn power back on job done.PS Check all vents are clear to stop it over heating good luck.
Jul 18, 2008 | Electrolux EOG7330WN Gas Double Oven
Stoves Gas Oven
i am having the same problem but i have been told it is the cooler fan so i have ordered a new one,the fan unit requires running as it is linked to safety sensors the equal air preasure and if not equiled by the fan moter it cuts everything off and in my case it trips the mains power but may not in your case
Jul 07, 2008 | Stoves Premier 900GRa Gas Double Oven
Whirlpool oven accubake system
I have a whirlpool accubake wall oven. Half-way through baking a pie ,unknown to me, the oven went to the self-clean mode , the door locked and the pie started to burn. I tried to turn the oven off but it would not cut off. I immediately ran to the house's main power and turned off the oven breaker. I waited for a short time to let the oven cool enough to open the door and get the burned pie out, then went back to turn my breaker back on and the oven (even though in the off mode) started heating again with the bottom unit turning red again. I had to then go back and pull the power. We tried this several times trying to push the off button but the oven will not go off until we throw the breaker. Help please!
Jul 01, 2008 | Whirlpool RBS245PDS Electric Single Oven
Ovens Logo
1,197 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
