Question about Onkyo TX-SR502 Receiver
Can I add the HDMI feature - Onkyo TX-SR502 Receiver
    President:
  • Onkyo Master
  • 1,114 Answers
No, any particular reason why? HDMI can be a can of worms! post a comment with the models of the product you are connecting and I can help you put it together the best way possible. Hope this helps
Posted on Jun 25, 2009
How do I turn off closed captioning in HDMI? I've turned it off in tv mode but it still is on. It's annoying
What's the HDMI source? You need to disable the CC on the cable box or DVD player. These are only two of the possible HDMI sources that will provide the captions directly.
Without knowing the source, I can't tell you how to disable the captions. For many devices, you'll need to enter the settings. (Some cable/IPTV boxes will need a passcode to enter the settings menu.) On my IPTV box, the CC option is tucked into the Hardware Settings under Audio. On some satellite TV boxes, I found that the closed captioning had to be turned on at the primary box and that would enable secondary boxes to also show the captions. (It was an annoying feature for a family with one hard-of-hearing guest. They didn't need closed captions on the primary box. The specifics of their set-up and service meant that the secondary box couldn't display captions directly.)
Please add a comment with the HDMI source for specific information on turning off the captions that you currently see on that source device.
Nov 27, 2017 | Televison & Video
Tip
USE YOUR LCD TV AS A COMPUTER MONITOR BY WAY OF HDMI.
To use your LCD TV as a monitor. look for a HDMI output on the computer and the TV. If you dont have a HDMI output on the computer, you will need to spend approx. $70 for video card and install it. I found "VisionTek Radeon HD 4350" to work fantastic.. Make sure your LCD TV has a HDMI INPUT. If not, you will need a newer TV. All thats needed now is a HDMI CABLE. The cable can be purchased anywhere computers are sold for between approx. $30 to $40. Depending on length. The cables can be found for much less ON-LINE. firefold.com has the cables for approx. $5. and they are the high quality gold plated cables. Now plug the cable into the computer and the TV and then using your tv remote, switch to HDMI and your tv is now a computer monitor. "Note"you may have to make adjustment on computer for display size and quality. My LCD TV is a 46" and the video card described above supports HD full screen. A wireless mouse and key board are a nice feature to add. If you like movies, you can get netflix and stream movies. there are many other sites for streaming and downloading. after doing this with my computer, i dont have a cable bill any more..I hope this tip helps.
on Dec 02, 2009 | Computers & Internet
How can I add the MLB tv app to my Philips smart tv, they don't have a market button or app.
The best solution in this case would be to add an external streaming device to an HDMI input on your TV. Much cheaper than replaceing your TV that does not feature the application.
Major League Baseball Roku MLB TV
You might see if when you are online if there is a software upgrade for your TV model that might upgrade the applications.
Apr 11, 2015 | Philips Televison & Video
XBOX 360 HDMI Problem green/purple screen
Try the following:
Reconnect your console and TV:
  1. Remove any devices placed between the console and the TV.
  2. Connect the HDMI cable from the back of your console directly into the HDMI port on your HDTV or monitor.
  3. If you're using an audio-only A/V cable, unplug this cable and then connect the HDMI cable from the back of the console directly into the HDMI port on your HDTV or monitor.Learn more about connecting your console to a TV.
Note If your HDTV has an image-enhancement feature or any kind of digital noise-reduction feature, turn this feature off. See your HDTV user manual for instructions.
Jan 24, 2014 | Microsoft Xbox 360 Console
Can I add a HDMI port to an older computer
*Yes you can by usin a video card withan HDMI port with it. However you need to check if the video card is compatible with your computer's motherboard :)
*You can also use DVI for alternative if HDMI is- not av-ailable-+
Jul 24, 2010 | Dell Dimension 8250 PC Desktop
My menu says dtv Currently unavailable. How do I use the HD feature on my Olevia LT32HV
Do you have a High Definition cable/satellite reciever or a Blu-Ray player? Does your tv have a HDMI input or component or DVi or all of those? Most newer HD components use the HDMI connection. The HDMI connection is a single cable that has both video and digital audio together. The component connection is a connector with three rca jacks that are red, green, and blue. Audio is connected seperately with this connection via red and green rca audio jacks or a digital audio connector. The last is a DVi connector that is found on computers. Some older HD tvs and components use this connection. There are adapters available to turn a DVi connection into a HDMI connection. So if your TV does not have a HDMI connection but your HD reciever does you can use and adapter but you will not have any audio this way without using a seperate connector for the audio.
Sep 16, 2009 | Syntax Olevia LT32HV 32 in. HD-Ready LCD...
I am attempting to connect a computer monitor to my bose lifestyle 38 system. The monitor has an HMDI input
I think that will be hard to do as I own an AV38 and there is no HDMI feature on my BOSE SYSTEM. I had to use the AV inlet. The AV48 DOES have the HDMI feature.( Unless you have a much later model AV38 that has the HDMI feature.
Jul 03, 2009 | Bose Lifestyle 38 System
Unable to play DTS-HD & True-HD
What do you hear? Do all other modes work ok?
If Audio Select (Page 44 and 98) is set to HDMI you will hear silence if no HDMI signal is present. I think AUTO is the best choice here.
On Page 98 of the manual it says a bunch of things concerning automatic signal detection and input selection.
Initial configuration D) INIT. CONFIG
Use this feature to select the settings of the audio input jack select, active decoders and extended surround when you tum on this unit.
Audio select AUDIO SELECT
Use this feature to designate the default audio input jack select setting (see page 44) for the input sources connected to the DIGITAL INPUT jacks when you tum on the power of this unit.
HDMI set E)HDMI SET
Use this feature to select the component to play back HDMI audio signals.
Support audio S. Audio
Use this feature to select whether to play back HDMI audio signals on this unit or on another HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = RX-V663
FUNCTION
Plays back HDMI audio signals on this unit. The HDMI audio signals input at the HDMI input jacks of this unit are not output to the HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = OTHER
HDMI component connected to the HDMI OUT jack.
NOTES
This unit transmits audio and video signals input at the HDMI input jacks to the HDMI out jack only when this unit is turned on even if "S.AUDIO" is set to "OTHER".
I'd look in these areas for specific guidance.
Apr 22, 2009 | Yamaha RX-V663 Receiver
Onkyo TX-SR502 Receiver Logo
126 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
