Question about Fuji FinePix A340 Digital Camera
Software driver problem
Our PC has stopped recognising the camera in the USB port - uninstalled and reinstalled software but still not working - anyone got any ideas
  • 1 more comment
  • Anonymous Nov 06, 2007
    have updated to home vista on pc any suggestions to how i can make software work
  • myzeus Mar 09, 2008
    I too cannot get FinePix Viewer to do anything, nor can I view the pics.
  • Anonymous Mar 10, 2008
    Continue to reinstall driver on my PC to take pics from camera, but screen repeatedly does not show up.
  • 75 Answers
Do any other devices connect successfully to that same USB port?
If no, try another USB port.
If yes, when you reinstalled your software, did you uninstall first? If not, see if you can. Once uninstalled, verify that the device is removed via Device Manager.
Once removed, if on XP or Vista, try to connect using the built in system drivers.
If this does not work, try reinstalling your drivers, but be sure to check for system prompts when you connect. If you do not respond to those prompts, the device will not mount.
Let me know how it turns out.
Posted on May 30, 2008
C910 Controller caused BSOD, now unrecognized camera
You have to update your BIOS from the PC manufacturing website. When they become outdated things randomly stop working. It is a KNOWN glitch.
Nov 24, 2012 | Logitech C910 Web Cam
CProblems onnecting Archos 700 after connecting 605 to PC
It is very possible the drivers conflict. You should try uninstalling everything to do with the one you don't want. Then install the drivers/software for the 700. Also what software are you using and what version?
Sep 21, 2008 | Archos AV700 Digital Media Player
First disconnect PC from power cable for 10 minutes (unplug).Disconnect player from USB. reinstall player software. Then connect back player, it should work.
Apr 20, 2008 | Audio Players & Recorders
I cannot connect my camera to my pc
At first connect your camera through USB port and install your Driver for your camera. Now you are able to connect camera with your pc
May 09, 2011 | Samsung Vimicro USB2.0 UVC PC Camera
Computer do not recognize kodak c703 and the transfer station is not working
I just had this problem with my D5000. I did a lot of troubleshooting to discover a Windows Code 19 error in device manager. To see whether this is your problem, go to Control Panel, select device manager. Your camera should be listed under cameras/imaging devices. If there is a yellow exclamation mark, disconnect your USB/transfer station. Using device manager uninstall the software drivers. Once uninstalled reconnect the camera and usb or transfer station. Drivers are on the camera. It should begin an automatic reinstall. When it says your hardware is successfully installed, you should be able to use the transfer station again. If not, and you got a disc with your station, then I suggest uninstalling all the software and reinstalling. Apparently in windows operating system, if the registry entry relating to that device is damaging, it will no longer recognise the device nor load the drivers. The only way to fix the registry is to uninstall the device and reinstall.
good luck
Mar 02, 2010 | Kodak EasyShare C703 Digital Camera
My printer has been working ok but now says usb device not recognised tried reinstalling software but still the same message
First you check the USB port is working or not. If no plz update/install the USB driver. if working properly so plz check the connectors which are connected in the computer and another side in the printer. After that uninstall the drivers and install software agin in your computer. I hpoe your problem will solved
Aug 13, 2009 | Lexmark X2550 All-In-One Printer
Canon 450D is not being recognised by my computer (I run xp 32-bit). When I turn on the camera, windows comes up with a "install new hardware" option. I have installed the EOS utility etc. but still the...
Both the Canon XT 350D and the XTi 400D are recognized by any PC with XP windows operative system. It seems you have to check your USB port or USB cable used to connect your cameras to the PC. Sometimes, the PC does not recognize a specific device connected to an USB port. Yopu can get into the System -device manager screen, and uninstall the USB port, and run the utility to recognize changes in the device manager. This will install the USB port driver again, and if it is a software issue the reason of the problem, then it will be fixed.
Also, you can check your cameras and USB cable in a different PC so you can confirm if they both work has should be.
Mar 26, 2009 | Canon EOS 450D Digital Camera
STOP: 0X0000007E Error
uninstall the camera software and remove the usb camera
to see if usb ports work after reboot. only if you have the camera software to reinstall in case its doesn't work.
May 12, 2017 | Intervideo MediaOne (BWC100108900060000)...
Installation issue
Normal 0 Try disconnecting the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Apr 21, 2008 | Microsoft LifeCam VX-6000 (68C-00001)...
Computer not recognising USB driver
OK, please reinstall the driver. If there is still a problem please advice. Arpi
Mar 18, 2007 | Sony DCR-DVD803E Pal DVD Camcorder
Fuji FinePix A340 Digital Camera Logo
83 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
