Question about LG Heat cool Window Air Conditioner
Ac do not drop down the tempture of room.
Hi,my one ton ac trip friquently. its compresser off ratio is more than on ratio.
  • 3 Answers
I have the same problem. Sounds like the unit is stuck in "Dry Mode". Dry Mode runs the compressor for short intervals (like one minute at a time). Mine is only 2 months old and worked great until a few days ago.
Posted on Aug 11, 2009
Hi, I have a 2009 Husqvarna TE 250, spec states the engine as 12.9:1 compression ratio. The question I have, is what octane fuel rating is recommended for this bike? Thanks, Rob
91 or 95 octane is suitable for 9.5-10.5 ratios ( most engines)
for 12.9 you will find that it runs best on 98 octane
it may be good on 95 octane but generally the higher the compression ratio the higher octane rating
discuss the octane rating required with the bike service agent/service center
Apr 02, 2017 | Cars & Trucks
How much to 2 ton ac compresser pressure
depends on the gas, R22 60 psi minmum 410 110-130 psi pressure always the same for 2,4,etc tons the amount chenge
Dec 25, 2015 | Heating & Cooling
Bryant condenser not running.
Check that there's power available (open or tripped breaker or disconnect). If there's power available, check for 24-28 volts feeding the contactor coil. The low refrigerant cut-out may have tripped the 24v (leak). The pressure cut-out may have tripped (dirty condenser coil, inoperable condenser fan motor). If there's 24 volts at the contactor coil, check the capacitor before ohming the motor. A defective run capacitor will shut the compressor down.
Aug 27, 2013 | Bryant Legacy 16 Series 4.0 ton AC...
Compression ratio for husqvarna 455 rancher chainsaw
be careful check the compression on that engine it has a compression release valve on the side of the cylinder the release builds up with carbon and it sticks dropping the compression
Aug 27, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a Onida 1.5 Ton AC which works ok in the morning. It started tripping in the evening after 7pm, i know the voltage is low. Then I installed V guard vew 400 and then it started working properly for...
The VEW 400 I had purchased had some defect. VGuard replaced it with a new one, which works fine on 1.5T AC with C32 MCB both at the phase changer board and at the electric outlet connecting the AC.
The VGuard repair place is in Choolaimedu, Chennai half KM west off Nelson Manickam Road. Take the road opposite Bata show room on this road, you will find the VGuard service center.
That should solve the problem.
May 31, 2012 | Heating & Cooling
Hi there I have a model number for my carrier a/c unit. I need to find out the tonnage. 38ykc042300 Please any help I will be very greatful.
This is a 3 and 1/2 ton unit.
The 042 in the model number is the tonnage of your carrier unit.
AC tonnage is based on 12,000 btu per ton.
12,000.....1 ton
18,000.....1 and 1/2 ton
24,000.....2 ton
30,000.....2 and 1/2 ton
36,000.....3 ton
42,000.....3 and 1/2 ton
48,000.....4 ton
60,000.....5 ton.
There is no 4 and 1/2 ton unit.
Apr 09, 2011 | Heating & Cooling
Compresser is shorted out across the fields. I want to comfirm the compresser size before I replace it.
You need a niminal 3 ton compressor...the "36" in the model number gives you the 3 ton rating...36000 BTU @ 12000 BTU/ton = 3 ton...
So you need a 3 ton 240 volt single phase compressor...
heatman101
Aug 23, 2010 | Carrier 38CKC036 Air Conditioner
Wiring standard for Split AC 1.5 Ton
The factor that you have not included here is the distance from the power panel to the unit...if it is too far then you need to up gauge the wire to compensate for that... that could be why the electrician wanted to go to the 720 ga. wire.
heatman101
Apr 16, 2010 | Samsung AS18A6RB Air Conditioner
LG Heat cool Window Air Conditioner Logo
130 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
