Question about Delta & Single Handle Shower Faucet
Delta single handle faucet. Hot or cold no in between.
I have a low end delta single handle faucet in my shower. It will only get hot or cold I cannot find a medium temperature. I have a tankless water heater installed and when I plumbed the house I ran 3/4 inch for hot water and 1/2 inch for cold. No problems with pressure but I am wondering if that could be the problem or is it a faulty faucet.
More info: I have the water heater set at 100 degrees
when I installed the faucet I of course didn't think I would need the manual or the package. a faucets a faucet right?....
  • truckertodd3 Jun 26, 2009
    it's 3/4 up to valve and reduced down into valve. I'm inexperienced and I listened to some people I maybe shouldn't have on the plumbing part. I'm leaning towards the mixing valve not working. Is there any way to adjust it or should I cut my losses and replace it with a better model?
  • 146 Answers
Well they should be same size but unless you getting more of one then other then sound like mixing valve is not mixing. do have 3/4 hook up to mixing valve? you only need 1/2" to valve.
Posted on Jun 26, 2009
  • paul sandouk
    paul sandouk Jun 26, 2009
    none that know of, most of them just mix and that it! i would take it back and try anther. and i would put at least a few feet of 1/2" before the valve. but i would get anther valve first. then try the other. paul
Why is my delta kitchen faucet hot cold backwards
The supplies are probably hooked up backwards. Hot to cold side and cold to hot side.
May 24, 2014 | Delta & Single Handle Shower Faucet
I just installed abrand new single handle delta shower faucet and the water does not get hot enough.
Many single-handle shower mixers have a hot limit, usually limiting the throw of the handle. You could go to the mfg's website (www.deltafaucet.com) & find instructions for adjusting it. Or, if you're handy, you could take off the handle & have a look; it shouldn't be too hard to see what's stopping the handle from turning more towards the hot side. Make changes in small increments & remember where you started.
Mar 01, 2011 | Delta & Single Handle Shower Faucet
Connecting shower faucet to water line. what are al lines for . This is a Delta faucet
You should only have two lines, one HOT and ONE cold, if your already using a delta, then that means whatever is already WELDED to inside the unit is DELTA as well. JUST KEEP IN MIND that if you intend to use something other than DELTA parts, you will NEED TO do welding work!! Just changed mine out and ran into the same issue as you.
Jan 26, 2011 | Delta & Single Handle Shower Faucet
Single-handle Glacier Bay shower faucet, hot/cold reversed
Hello. It sounds like your plumbing was installed wrong, with the hot and the cold supply lines reversed. If that is the case, those supply lines will have to be replumbed to make your faucet work properly. Often, if those lines are accessable, it is only a 20 minute job. Joe
Mar 18, 2010 | Delta & Single Handle Shower Faucet
I have a shower single handle faucet that is has
You should be able to remove the cylinder and rotate it 180 degrees and the re-install the handle to how you originally had it.
Jan 28, 2010 | Delta & Single Handle Shower Faucet
Water is not very hot.
First try adjusting the pressure balancing gear located right behind the handle. If you still do not have hot water I suggest to replace the cartridge.
Jan 13, 2010 | Delta & Single Handle Shower Faucet
No hot water flow from faucet/shower
change the cartridge it is bad or defective.
Jul 20, 2009 | Delta & Single Handle Shower Faucet
Delta & Single Handle Shower Faucet  Logo
1,056 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
