Question about Microsoft Windows Vista Ultimate Edition
Wh it was not so popular
I am bougt new vista software it has doing very slow always
  • 173 Answers
Re: wh it was not so popular
Hey dude may be u r machine configuration low
it should be.
1.pentum 4 ..2.4ghz or higher
2. 512 mb ram or higher...
i f u dont have this configuration u r pc work slow
i advice u to update u r pc or use win xp operating system will be better man...
hope it is solved.......
Was this solution helpful? Show your Appreciation by rating it:
pls vote for me man..
best regards & best of luck..
Posted on Nov 05, 2007
0 characters
3 Points
Try testing the system (if a Dell or HP, there will be diagnostics available in the BIOS or during boot up). If everything passes the diagnostics, then you can either provide more details on when its slow, how its slow, when it started being slow, what may have happened prior to it being slow (dropped, updates, new software, antivirus, etc.), OR back up all your software and files and use the PC Restore to reinstall/restore to factory condition.
Aug 16, 2010 | Microsoft Windows? Vista Home Premium...
Software work to slow and it shot down
Software Installation : Installing more and more software can make the computer slow down. The reasons for that are that installation of a software will make entries in registry and that is somewhat bad. The software may be running in the startup. The software will install various files on the computer and an overloaded hard disk makes the computer slow.
Free up disk space : Try to keep your hard disk space free. You’ll always notice that a computer with free space on hard disk will always run much faster than the one which is loaded with extra stuff.
* Remove Unwanted Items From Startup : Well, if you’ll remove the unwanted softwares from the startup then your computer will boot up much faster and the memory (RAM) will also remain free and thus that will again result in better computing experience
Run hard disk maintenance utilities : Always run the utilities like Disk Defragmentation or Disk checking utilities regularly, around once in 2 weeks
Run Registry Cleaner : Right, this one is related to first tip. In case you’ve already installed and uninstalled various softwares before reading this tutorial then you can go ahead and run various registry cleaning softwares
Oct 14, 2009 | Operating Systems
Vista is slow
The slowness of Vista depends on the components that you have for the computer. Did you buy your computer with Win Vista installed? If you upgraded your computer from XP to Vista, you have to make sure that it is covered by the system requirements of Vista.
If you have a brand new computer with Vista installed in it, then there could be a little glitch on the program. I've used different kinds of Vista (Home Premium, Vista Business and Vista Ultimate) but none of them worked slow. If that's a brand new computer, I would suggest to contact the manufacturer or the reseller.
Have a great day!
Sep 07, 2009 | Microsoft Windows Vista Home Premium with...
Windows vista runs very slow on start up, waht i do?
hey anand,
Follow the steps in the link:
I would also recommend doing a scan using free software like superantispyware as slow pc can also mean infection of various kinds.
Rate if fixed
Feb 25, 2009 | Microsoft Windows Vista Ultimate Edition
I have 2GB memory should i go for 4GB on Vista Ultimate
well your board should be able to handle up to 8 gigs of ddr2 sdram. should have four memory ports. the more memory the better. don't know what processor you are using but if it's relatively new then shouldn't be any problems. vista is slow as it is so anything you can do to speed it up will help. oh it is always better not to mix and match brands, speeds etc when it comes to memory. if you expand be sure to purchase what you are already using or buy all new ones. will drastically reduce the potential for problems.
I hope this helped
Dec 22, 2008 | Microsoft Operating Systems
Cant save dvd to computer!
you need what is called "dvd rip" software, it does for DVD's what music rippers do for music CD's
There are quite a good few free one out there.
Follow this link for a full run down on what programs you need and how to do it,
Dec 11, 2008 | Microsoft Windows Vista Home Premium with...
Windows vista
Windows Vista is the new operative system distributed from Microsoft, following the previous release of Windows XP.
An operative system is the interface between the user (you ) and the computer, that allows you to manage computer hardware resources and peripheral, and manage processes (software) running on your computer.
From the user point of view The operative syste is the environment where you run applications, manage connected devices, storing files and starting and stopping programs.
Vista is the latest OS released from Microsoft. It has a powerful interface, but it can be slow running on old computers. On vista you can also have some compatibility problem when you try to install old devices built for XP, such as printers, scanners etc.
See here
Windows Vista home page
Sep 11, 2008 | Microsoft Windows Vista Ultimate Edition
Maybe a virus
is it the internet that runs slow or everything? either way, go to the following site:
click on the link that says "Scan Now. Its Free!" it will do an online virus scan of your computer, and this should get rid of any viruses you have. You may have to install Java for it to work. If so, it should provide a link to install it. If it doesnt, google "java software" and download the software. it may also be a RAM problem (not enough computer memory) but thats probably not as likely if your computer is new. Also, you can go the task manager and delete all of the processes that you think arent needed (such as itunes, etc. make sure that your user name is under the user name column for each one you are deleting, and DO NOT delete the "explorer" process or any system processes). And this may speed up your computer as well.
Aug 08, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
49 people viewed this question
Top Microsoft Operating Systems Experts
Brian Sullivan
Brian Sullivan
Scott Fryer
Alex Krenvalk
Are you a Microsoft Operating System Expert? Answer questions, earn points and help others
