Question about Sony Ericsson Walkman W810i Cellular Phone
White screen switched off phone removed battery and sim replaced turned phone back on, but still just a white screen.
    Brigadier General:
  • 7,752 Answers
Re: white screen
Reflash the phone with it's original firmware that should fix the problem.
Posted on Dec 21, 2007
0 characters
3 Points
Pls how can i flash my nokia N95
No matter what network your Nokia N95 phone currently runs on, you can unlock it---or "flash" it---to run on any GSM network. You will only be able to use your unlocked Nokia N95 phone on networks that use SIM cards---such as T-Mobile and AT&T---and not on CDMA networks such as Sprint and Verizon, which do not provide SIM cards.
Read more: How to Flash a Nokia N95
Unlocking the Handset
Remove the back cover and the battery from your cell phone. Locate a silver sticker with a bar code on it. Take note of the 15-digit IMEI number printed on it. At this time, also remove the SIM card and write down the numbers printed on the back of it. The SIM card is the small, white data chip in the silver cradle right next to the sticker. You will need these numbers to obtain your Nokia unlock code.
Request a Nokia N95 unlock code from your service provider. If they cannot provide you with an unlock code, you can buy one online.
Replace the SIM card, battery and cover. Fully charge your handset.
Turn on your handset and type "#PW+".
Enter the unlock code given from your phone company or website. Make sure you dial the number exactly as it was given to you. If you dial this number incorrectly three times, you will be permanently locked out of your handset.
Dial "+1#". At this point, the screen on your Nokia N95 should read "SIM Restriction Off."
Inserting SIM Card
Switch your handset off and remove the back cover and battery.
Remove the SIM card.
Insert the new SIM card into the SIM card slot. Now that the phone has been unlocked, this can be a SIM card from any U.S. service provider that uses SIM cards.
Replace the back cover and battery and switch the cell phone on. The screen should now read the name of the new service provider
Nov 30, 2011 | Nokia N95 Cellular Phone
My lg envy front screen stays white i dont know what to do
Try to follow these steps:
  1. Turn off your phone. If not possible, just remove the battery and skip step 2.
  2. Remove the battery.
  3. Wait for at least 5 minutes to make sure there's no power in the phone anymore.
  4. Remove the Sim card and other cards like Micro SD or similiar
  5. Put the battery back in. (not the Sim or others)
  6. Try to start your phone.
If your phone still doesn't boot, this might be caused by some errors in the firmware of the phone, or hardware errors. Contact LG or a Cellphone servicepoint.
My LG phone fell in the water once and the screen was stuck white too.
Dec 20, 2010 | LG enV3 VX9200 Cell Phone
Samsung SGH-a727: LCD display is blank (white) on the left 20% of the screen. The rest of the screen is very faded with vertical streaks through it. What's up? It hasn't been dropped or otherwise damaged.
The screen of your phone as started malfunctioning.
It is possible that you hit it on a hard surface. all the same, it also possible that the screen is not well tighten to the panel of your phone.
Get a torx 6 screw driver, switch off the phone,remove the battery cover of your phone,the battery and sim card. turn the phone over and remove the front casing of your phone, use the torx 6 screw driver to tighten up all the screws on the screen to the panel very well and couple back yor phone.
Put back the sim and battery and switch on, if the screen did not still display, it means the screen of your phone is bad.
The problem is the screen, the screen is faulty and will need to be replace if you want it to display back as you use to have it.
All you will need to do is to get a get a brand new screen on your phone and i advice you go with the phone in other to get the exact screen and a working screen.
Take care.
May 03, 2010 | Samsung SGH-a727 Cellular Phone
My nokia 5800 has frozen on the nokia screen with white backgroun
The same thing was happening to my phone. I removed the battery, sim card, and memory card. I then replaced the battery an turned the phone on and it loaded to the main screen. I turned the phone back off and put back in the memory card and sim card and then it worked. Hope this helps.
Nov 18, 2009 | Nokia 5800 XpressMusic Smartphone
The phone turns on then the screen goes white
Hi Friend,
The problem may be because any software my got hanged or any virus may create this problem so kindly check it out.
Or you may try the below steps,
1.Switch off the mobile
2.Remove the battery,sim card and the memory card
3.Hold the Switch ON/OFF button for 20 to 30 sec's
4.Now Replace the battery and the Sim card
5.After it has Switched ON,replace the Memory Card.
Check and revert back
Thanks and revert back
Jul 31, 2009 | Nokia 6500 Slide Cellular Phone
I have nokia n70..till yesterday it was working got switched coz its battery went when i was chargin tried to switch it on..but the screen is nly white no display,its makind beep...
Power cycle the phone. Here's what you need to do:
1. Remove the battery.
2. Remove the SIM card and the memory card.
3. Give for about 5 minutes and then put everything back.
4. Turn the phone ON.
If the problem still the same, you need to bring it to the Nokia Care Center for possible firmware upgrade.
Have a great day!
May 23, 2009 | Nokia N70 Cellular Phone
I lost the phone and when I found it the battery was dead. After a little bit of charging the phone would only come up with a white screen that says "SGH-T339" but wont go past that.
My step son had the same issue. I removed both the SIM card and memory card from the phone before turning it back on. Once the phone got past the "SGH-T339" screen it tells you to install the SIM card. Remove the battery and install SIM card and turn phone back on. It has worked ever since.
Dec 09, 2008 | Samsung SGH-T339 Cellular Phone
My k610i just white screen
Try tehse steps
1. Switch off and switch it back on ,
2. Switch off and take out battery , when battery is out , press power on button for 30 secs and then out battery back again and switch on the mobile. This process is known as releasing flee power.
3. If still does not work, check whether the SIM is properly connected, take out SIM and put it back again and then check.
f still does not work then contact , the phone manufacturer, phone has to be reset or its not loading up properly and says inactive SIM , u can also contact the people whom u pay for the phone bills and check whether SIM is active or not
Feb 21, 2008 | Sony Ericsson K610i Cellular Phone
Nokia N95 Wont start up properly
hi to all u wot r having the same problem i email nokia last night they got bk to me with this messege and it workis so do this
• Turn the phone off.
• Remove the battery, SIM card and memory card for at least 15 minutes.
• Reassemble and turn the phone on.
Then, monitor the functionality of your phone.
If your phone is not responding, try to recover the device by formatting it manually:
• Press and hold these keys: [3], call and [*].
• Press the power button for 1 second.
• Continue to hold [3], call and [*] until you hear the start-up tone.
and it works i can use my n95 agen now so give it a tri
Jan 29, 2008 | Nokia N95 Cellular Phone
White screen on my phone sony w550i
Hi this is a almost normal anomaly with sony ericssons - they get the "white screen of death" on a regular basis - on my w550 back in the day - exactly the same thing happened - after reflashing a few times it was back to normal - we are sony ericsson experts if you need it done
Jan 22, 2008 | Sony Ericsson W550i Cellular Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Jose Cada
Jose Cada
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
