Black & Decker Black and Decker Mm575 18" Mulching Lawn Hog Electric Lawn Mower Logo
J
JOHN KEALOHA Posted on May 31, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No start on a mm 1800 18"
Mm1800, corded mower
charles beach
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Black & Decker Master 1,917 Answers
  • Posted on Jun 06, 2014
charles beach
Level 3:
Renaissance:
Answers
1917
Questions
Helped
570405
Points
3010
Check the cord for cuts then check the safty engagement on the handle and make sure it disengages to cut thats about all you can do turn blade make sure turn freely not plug in after you will have to take it in
Can you start a push mower with an engine control cord? Kill cord
Not sure what you mean by 'engine control cord' in relation to a 'kill cord / kill switch'.
Mowers either have a pull cord to start it or electric start. Pulling the cord makes the engine turn over, it fires and runs.
The kill switch does the opposite, it cuts the power to the engine and stops it.
All questions need 'make model (what it is)'. With that we can find the manual on Google.
make model manual
Apr 11, 2023 • Garden
1helpful
Black and decker electric mower hums but blade does not turn. appears the brake is not releasing for the blade.
Something has the motor unable to turn. Do not turn on till you locate the source of the problem lest you burn it out.
1helpful
Why is my B&D MM1800 mower making sparks when it starts and stops?
check the spindle bearings for failure as they may be what is sending out the sparks
they do get water ih them and run dry and may have been on the way out but the hit did the most damage
Nov 03, 2015 • Garden
My MM1800 started to smoke?
Return it to the retailer for service. it presumably has a warranty that the supplier is obliged to honour. As long as they do not argue that you were somehow not using the device in the manner it was intended you should have no problems. The retailer should, in any case, contact the manufacturer for authorisation to repair or replace.
What might causeI my electric mower to slow down and speed up and the electric cord connection has overheated at the mower connection?
there is approximately one OME of resistance per foot of power cord. the power cord must be sized according to the amps drawn. if the cord is undersized the motor will not get enough power. the results are a hot cord and probably a hot plug. a loos plug will also over heat, you may need to replace the outlet in the wall as well, get a 12 AWG cord if you are using a 100 foot cord. I personally would never use a 14 AWG if I had a choose, but if the cord was 25 feet or less that would probably be ok. if you are still using the old cord or if the wall outlet is damaged this could cause the ossolating current.
1helpful
Neighbor mowed the extension cord and mower won't start
Check the cord has been properly replaced. Check circuit with a meter (NOT connected to mains) The live pin on plug should connect to live pin on motor switch etc. (need to take off cover on switch unit)
Cutting through the cord should not have damaged the mower.
Broken Cub Cadet
I dont own one or there but it is an easy repair. Find a wrench/socket that will fit the 3 or 4 bolts holding down the pull cord (recoil) cover and remove them and the cover. (Prob. a 10 mm socket) Then wrap a cord/narrow rope CLOCKWISE around the pulley 3-5 times and prepare mower to start as you normally would and pull the rope. Now you can cut your grass before it becomes unmanageable. Take the recoil to any small engine repair shop and have them replace the rope and then you can reinstall the recoil. In my area the charge $7-$10 for this.
May 20, 2013 • Garden
Trying to reg new b & d elect lawn mower mm1800
Go to this page and register it:
http://www.blackanddecker.com/ProductRegistration/Product-Registration_NEW.aspx
or this one:
http://www.blackanddecker.com/pages/my/prod/RegisterProduct.aspx
You have to sign up to complete registration.
Thanks for choosing FixYa,
Kelly
Aug 08, 2011 • Garden
Need to buy starter pull cord --- size??
take your cord with you and get something similar in size
Jul 22, 2009 • Garden
Blakc and Decker Lawn moser MM 875
unplug the extension cord for safety. then try turning the blade by your hand.if something is rubbing or hard to turn maybe the outring or out parts of the motor is broken.
Top Black & Decker Garden Experts
Thomas Perkins
Thomas Perkins
Mike Cairns
Mike Cairns
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
