Question about Tunturi E30 Ergonomic Exercise Bike
How to set timer on display panel on exercise bike. Model is track 001 silverline.Just bought it secondhand Thank you
How do I get an exercise bike display to work ?
We would be happy to help, what type of bike do you have? If you have the model and serial number we can narrow the search to the problem even better :)
Aug 10, 2015 | Exercise & Fitness
52144 turns on and off by itself
It's probably been set to a timer. Go to your steup menu and find timer or something that sounds like that and set it to default or erase any timer that has been set up. If you bought it secondhand it was probably place on there as a means to secure the house by letting robbers think people were home. Just a thought good luck.
May 08, 2015 | Televison & Video
I cant seem to get the timer to do anything on my excercise bike
The display (timer) needs to be connected to a sensor on the bike.
Make sure the display is plugged into a cable coming out of the bike.
If it's plugged in and still doesn't work, then contact the manufacturer.
It could be,
1. a bad display. (possibly a broken PCB connection)
2. a bad sensor inside of the bike. They typically use a Reed switch.
3. a broken connection in the cable or connector
4. the magnet fell out of its location.
You can get a replacement monitor from the manufacturer. If this doesn't solve the problem then it's either the sensor or the connection.
You can also place a continuity tester across the 2 contacts of the connector that plugs into the display. The continuity tester should flash when you pedal the bike.
Here's a link where you can purchase a continuity tester.
http://www.amazon.com/Extech-ET40-HD-Continuity-Tester/dp/B0025PK724
You can also pickup a continuity tester at any auto parts store.
Apr 27, 2015 | Body Sculpture Bc1510 Exercise Bike
Need manual
http://content.costco.com/images/Content/Misc/PDF/666802_UserManual.pdf
Feb 25, 2013 | FreeMotion 330R Recumbent Exercise Bike
I lost the instruction guide for my exercise bike. Can anyone help me?
I don't knowwhat make or model of exercise bike you have but here is a link to a site thathas a lot of different manuals. Just look through the alphabetical list. http://fitness.manualsonline.com/manuals/device/exercise_bike.htmlIf yours isn'tthere, contact the company you bought your bike from and they should be able tohelp.
Jul 30, 2012 | Exercise & Fitness
Bought used. Didn't get instruction manual so can't use the exercise bike to its fullest. Is there a way to obtain a manual? Thank you.
look up the manufacturer on the internet and write to them or you may find their contact information and ask them for one. No one can help you if they don't know what kind of exercise bike or model.
Sep 21, 2010 | Cycling
What is the proper proceidure to set exercise timer on a briggs generator model # 01938 and what year was this model manufactured? thank you
http://www.homegeneratorsystems.com/service_support/manuals/index.cfm?rd=1
This link will take you to their site where you can download their manual.
Setting Exercise Timer
The Home Standby Generator is equipped with an exercise
timer that will start and exercise the system once every
seven days. During this exercise period, the unit runs for
approximately 20 minutes and then shuts down. Electrical
load transfer DOES NOT occur during the exercise cycle
(unless an utility power outage occurs).
A switch on the control panel is labeled “Set Exercise”
(depicted on page 10).The specific day and the specific time
of day this switch is pressed is programmed into the
control board memory.This date and time is then used to
automatically initiate the system exercise cycle.
To perform the Set Exercise procedure:
1. Choose the day and time you want your Home
Standby Generator to exercise.
2. On that day and time, set the AUTO/OFF/MANUAL
switch to OFF.
3. Press and hold down the “Set Exercise” switch for two
seconds.
4. Set the AUTO/OFF/MANUAL switch to AUTO.“Set
Exercise” is complete.
For example, if you press the “Set Exercise” switch on
Sunday morning at 10:00 AM, the unit will run an exercise
cycle the following Sunday at 10:00 AM (+/- 1/2 hour).
NOTE: “Set Exercise” will only work if the unit is in the
Automatic mode and this exact procedure is followed.The
exerciser does not need to be re-set if the 15 Amp fuse is
removed or changed.The exerciser will need to be re-set if
the 12 Volt DC battery is disconnected.
If you want to change the day and time the unit exercises,
simply perform the “Set Exercise” procedure at the exact
weekday and time you want it to take place.
• To prevent possible injury that might be caused by such sudden
starts, always set the AUTO/OFF/MANUAL switch to OFF.
• Remove the 15 Amp fuse before working on or around the
generator or transfer switch.
Nov 12, 2009 | Briggs & Stratton 12,000 Watt Bi Fuel...
Need Manual for Vital Fitness Exercise Bike RB26S
I have a manual for this model. I can not tell you how to find one, I have looked all over the net for additional info. on this model and can't find anything. Would be glad to scan and send you a copy if you still need it.
May 20, 2009 | Sport & Outdoor - Others
Wanted instructions for a Reebok RB1000 Exercise Bike.
If manufacturer and google are of no help, ask them. I guess they have the Reebok RB1000 manual for download on their site.
May 15, 2009 | Reebok Exercise & Fitness
Tunturi E30 Ergonomic Exercise Bike Logo
Top Tunturi Cycling Experts
Marvin
Marvin
Handyman
Tom Chichester
Are you a Tunturi Cycling Expert? Answer questions, earn points and help others
