Question about HP iPAQ HX2490 Pocket PC
HP Ipaq does not turn on
My ipaq 2595b model has not been used for over 1 year. recently tried to charge it - but it would not charge and would not switch on. what shall I do? Id hate to think its the battery thats gone..
Plug You Ipaq into A Power Supply Without a battery and then put in the battery and turn on
Posted on Jun 12, 2011
    Problem Solver:
  • 8 Answers
Ufortunately, the battery is likely the culprit.
You can try removing the battery overnight, then leave on charger for at least 12 hours.
These batteries generally require replacement every 1-3 years. They deteriorate quite rapidly if left unused/uncharged for extended periods of time (like a year!)
Posted on Jul 11, 2009
Have had a HP ipaq rx1950 for about 2 years and last month it has stopped charging the battery. I bought 3 batteries and each one does not charge. I put these batteries in another person's ipaq and...
its just 3 things.
1; battery
2: charge regulator on the device.
3: power pack
one is bad.
so its not battery, now its #2 or #3
seen the regulator is toasted
very common
why not buy as used spark same device, and mix part to get good
or ditch it and upgrade,
Mar 12, 2017 | HP iPAQ rx1950 Pocket PC
Cannot get past opening screen or turn off unit. Unit seems frozen
Did you try to flash the BIOS/firmware of your device?
1.) Go to the Master Index of BIOS, FIRMWARE, & DRIVER Updates,
2.) Select the appropriate hyperlink for your model. (in your case it's here http://mobilitytoday.com/forum/showthread.php?t=4846)
3.) Download the most recent BIOS version SoftPAQ (SP) for your Model of iPAQ.
4.) Press the POWER + iTASK + CONTACTS + RESET buttons at the same time so as to enter the FLASH Mode
5.) Make sure your USB connection to the Cradle is hooked-up.
6.) Place your iPAQ in the USB Cradle.
7.) Stop the MS ActiveSync session on your HOST PC: CTRL-ALT-DELETE > TASK MANAGER > PROCESSES.
8.) Hilight WESCOMM.EXE and select "End Process" button.
9.) Run the file you downloaded from HP in step 3.
10.) The iPAQ should now begin Flashing the iPAQ's ROM BIOS
Jan 11, 2008 | HP iPAQ HX4700 Pocket PC
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
My HP iPAQ hx4700 Pocket PC will not start up. It
Slider switches ok and pointing at the right place in the bottom?
1. Main battery possibly needs replacing.
2. Replace backup battery..
http://www.youtube.com/watch?v=cYwc_-ISnsA
Jul 13, 2009 | HP iPAQ HX4700 Pocket PC
Compaq iPAQ 3850 Not charging/turning on
Try this - don't give up Leave it charging, even if it takes three days. I sold one a few years ago on ebay and the buyer was insistent it wouldn't charge. Eventually it did start charging and there were no more problems.
Jan 24, 2009 | Compaq iPAQ H3850 Pocket PC
Charging pin of my ipaq damaged
hi
I can fix your sync&charge connector very fast in our lab.
you can send your device to us and we will charge you by paypal and return it to you in less than one week.
thanks
Gery
ipaq Lab
Nov 27, 2008 | HP iPAQ hw6515 Pocket PC
ITS BEEN A WHILE SINCE I USED MY IPAQ SO I CHARGED IT UP AND TRIED TO TURN IT ON. WHEN IT DID NOT TURN ON I TRIED TO RE BOOT IT BY PRESSING THE STYLUS IN THE SMALL HOLE IN THE BOTTOM OF THE IPAQ. THE...
a 13 year old relic of the past pulled out of the attic or found at a garage sale for 50 cents.?
hp has no support for this, its now a relic retired state there.
some have 2 batteries , one is soldered down. oops.
first google hit.
https://www.youtube.com/watch?v=OpGzA5Xl4J0
google finds then non HP manual , that HP deleted.
here free, give the new batt. 4 hours to charge.
https://www.manualslib.com/products/Hp-Rz1710-Ipaq-Pocket-Pc-2374427.html
RTM?
read page 27 , carefully and the gravity of these words
"Keep the battery charged.
The programs and files you install or create are stored in volatile RAM memory. If the battery
completely discharges, all user-installed programs and user data files
created will be erased and you will have to reinstall them. To prevent
losing valuable programs and files, keep the battery always charged.
Optionally, you can store a limited number of programs and files in the
iPAQ File Store folder so that if the battery completely discharges, they
will not be lost."
the store, is a NVram?, not flash. and the STORE has a battery
what is the chances of any 13year old battery still good.(zero?>)
see the coin cell here, it unplugs other models are soldered down.
1710-0bqeoaofrldpq4t1wllrhfnq-1-0.jpg why spend cash on old relics like this. and labor?
so you learned to day it has 2 batteries not 1
and learned it is 13 year old relic of the past, 100% useless in todays world. (buy notepad new for $50 at walfart)
Dec 19, 2017 | HP iPAQ RX1710 Pocket PC
New hp ipaq enterprise 210 won't start from mains
worst HP site on earth, but welcome!
never post email on any forum that be bad bad news.
why do that, erase that, want 1billion SPAM in one day
wow. that is scary, no?
like here
http://support.hp.com/us-en/product/HP-iPAQ-210-Enterprise-Handheld-series/3544499/model/3544500/
or here
http://h20564.www2.hp.com/hpsc/swd/public/readIndex?sp4ts.oid=3544500
your A/C walls mains,power pack is no good
it runs on battery
is proof.
in most cased. only real tests, tell real truth'
but you have no meters, or know how to dismantile
this device.
Mar 01, 2017 | HP iPAQ HX2490 Pocket PC
No life
There are a couple issues that could be going on here, so let's address them both:
1. Your iPAQ's battery could not be charged. Try charging the iPAQ on it's cradle for a couple hours and then try it.
2. Your iPAQ could have it's back light turned off meaning the screen is still displaying everything, but you just can't see it. Assuming the iPAQ is currently off, press the power button once ( to turn it on) then try holding down the power button for 5 seconds and see if the screen lights up.
Feb 01, 2008 | HP iPAQ RZ1710 Pocket PC
Ipaq h5555
I battery dead ? In some case, ipaq battery dead will not start. ================
Aug 05, 2007 | HP iPAQ H5555 Pocket PC
HP iPAQ HX2490 Pocket PC Logo
1,140 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
