Showing an error F04 how do i fix it?
SOURCE: panasonic deck ag dv2000 gives error code f09
Your vcr seems to use the K Mech. F04 Means that the mechanism locks unloading.
The cause of which might be the loading motor timing.
F09 means No serial clock linking IC2004, IC7005 and IC7701.
SOURCE: Panasonic VCR NV-HD642 - F04 Error
You sound like you have a K Deck Model. If this is the case F04 means that the mechanism locks during unloading.
The apparent cause of this is the Load Motor timing.
SOURCE: I have a panasonic NV-HD620
You appear to have a K Mech model. F04 means the mechanism locks unloading. The cause of this is the Load Motor timing.
SOURCE: Tape is stuck in VCR NV-SD230A with errror code F04
F04 is a loading issue. You can attempt to retrieve the tape, but this will not fix the F04 code.
If you do not have any experience with these machines, submit to a workshop for a quote, then decide if you wish to have it fixed by them or not.
Acccording to some technical notes, F04 means 'stop during unloading'. Either way it is not a user-fixable deal.
SOURCE: for nv sd300 i have error f04, what is the problem
You have a Pansonic K-Deck if you search on the web you will find information on it. But F04 means the mechanism is locking up unloading. This being caused by the load motor timing.
