Question about Toshiba 36A50 36" TV
How do i program my remote to control my volume on my sony sterio ?
    Problem Solver:
  • 10 Answers
Yo pandac is it a universal remote?
Posted on Jun 25, 2009
My remote is bad and need to increase the volume manually on Samsung ht-txq120 home theatre system
If your remote won't work at all, then you'll need to get a new remote from Samsung to control all functions. If however, everything works on the remote but the volume, keep the original for all other functions and just use a cheap universal remote programmed to the Samsung code to control the volume. I had the same thing happen on a Sony THIB remote for a HT. I used a Scientific Atlanta to turn it on and off, as well as control the volume, but retained the original remote so I could get at all other functions. If you have to buy a new Samsung remote or if you buy one of those high-dollar universal remotes that program a zillion functions it will cost you big. Fair warning.
Mar 17, 2016 | Samsung HT-TXQ120 Home Theater System...
Sony universal remote won't control the volume
http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMVZ320 Try the above Sony web site, where they have support, or call a Sony Dealer. http://store.sony.com/-cms-page.sony.authorized.dealer.list?XID=M:accessories:esupport
Nov 17, 2013 | Sony RM-VZ320 Remote Control
Motorola remote and sony home theater system code
you may need to set it up as two devices program a code for DVD to turn the unit on and off and a program and auxiliary code so that you can control the volume then you can teach the remote to use the auxiliary volume without having to press the aux button each time
Nov 10, 2013 | Sony BRAVIA Televison & Video
How to get my Sony HT-CT60 Sound Bar Home Theater programmed to my GCI Cable remote?
This worked for me, but I have a Comcast Motorola DVD-R:
These are the codes for your SONY SA-CT60 Audio Device. Follow the instructions below to program your remote.
silver_with_red_ok_button-lg.gif Most likely code: 30158
Others to try: 31758, 31759
To program your Comcast remote:
  1. Turn on the TV or other device that you would like to program.
  2. Press the TV button on your remote control.
    NOTE: If you would like to program your remote control to work with a DVD Player, VCR or Audio device press the AUX button.
  3. Press and hold Setup until the red light blinks twice, then release Setup.
  4. Enter the first code for your device listed above. If you perform this procedure correctly, the red light will blink twice.
    NOTE: If you enter an invalid code, the red light will display one long blink and exit the programming mode. Repeat steps 2 to 4 with a valid code.
  5. Aim the remote control at your device and press Power once (press the Play key for devices that don't have a POWER button). If the TV turns off, make sure that the VOL+/- and Mute buttons also work. If so, you're all set!
  6. If not, repeat these steps using the next manufacturer's code (you may need to try several codes to find the one that works).
Nov 24, 2012 | Sony Audio Players & Recorders
I'M INSTALLING A NEW REMOTE. IT CONTROLS THE SAT RECEIVER BUT NOT THE SONY TV. IT WILL NOT GIVE VOLUME CONTROL NOR TURN ON OR OFF THE TELEVISION. I'VE TRIED THE SONY CODES TO NO AVAIL. SUGGESTIONS?
rl_harris679
I have provided a link with instructions on how to program the new remote to your Sony TV. The link contains our different receivers. Select your receiver model, then a PDF document will open with the instructions for programming the remote to your TV. It begins with step 5. I hope this helps.
Programming the remote to TV:
http://www.dishnetwork.com/SupportSection/remote-setup
Sony TV codes: 500, 590, 000, 002, 073, 511, 514, 546, 550, 567, 578, 640, 670, 690, 758, 778
Ray Calo
DISH Network
Feb 19, 2011 | DISH Network IR Remote Control
Initial setup screen pops up at random times. The
The ability to control volume is often lost do to dirt or wear internal to the remote control. If that's the case then I would try a new remote. I universal one will give you the capacity to control volume, on/off and channel change. Try one of those (you need to program it for your individual model) and if that controls the volume you should replace your remote.
Concerning the spontaneous activation of your on screen display is also possibly coming from the remote. Put the remote in cardboard box or anything non translucent and see if that stops the problem. If it does stop it's the remote. If not your set will have to be seen by a professional electronics technician that hopefully is familiar with TV circuitry.
Apr 16, 2010 | Sony Televison & Video
Verizon FIOS remote buttons all work except Volume. Sony Trinitron WEGA remote has to be used. Volume is Fixed. Can something be done to control volume with the Verizon remote?
I had the same problem with a Sony Trinitron KV-32FS320 32" TV. I reset the remote to factory default.
  • Press and hold STB
  • While holding STB, press OK
  • Release both keys, wait for device keys to blink twice
  • Press 9-0-0. The STB key will blink three times
Then I reprogrammed the TV control.
  • Turn your television on
  • Press STB to enter Set Top Box mode
  • Press and hold TV
  • While holding TV, press OK
  • Press 1-1-2-7. This is one of the Sony TV codes
After this, the volume + and - worked to control the TV.
  • Program any other devices, such as DVD using procedure similar to above.
I hope this works for you.
Apr 25, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Program remote for sony ht-5100-d
Use your Directv remote. Use code 10812, remember to program it to change tv inputs also. then program the same remote to control volume on your Sony receiver. Go to the menu on the directv box and follow the onscreen instructions.
Apr 24, 2009 | Sony HT-5100D System
How to hook up my hook up the volume controls up
More info please. Does your sterio have a remote? What is the Make/model of your vehicle?
Jan 30, 2009 | Pioneer DEH-P6000 CD Player
Tv remote
Advent ADR-560 codes for a Sony TV are:
1002, 1218
Oct 20, 2008 | Recoton Advent Advent ADR-560 Remote...
Toshiba 36A50 36" TV Logo
64 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
