Question about Creda Ovens
What does ER08 mean
My cooker is switching off , and then ER08 comes up on clock what dose this mean.
Thanks,
David
  • 25 Answers
Hi, It indicates an overheated pcb board. This is a job for Creda as there are various causes and you could be buying expensive parts for nothing! :(
Posted on Jun 25, 2009
Is it an expensive job to replace the oven timer on my cooker?
I can do job for a lot less money or yes you can bypass timer, No Problem. David "The Famous Forry"
Oct 19, 2017 | Ovens
Stoves newhome manual
Yes it's possible to disconnect the clock but must be done by a professional repair man
Oct 10, 2017 | Ovens
Hi Our smeg oven model SNZ91MFX1 has stopped working, and the clock just says Fu 14. Any thoughts on what the fault message means?
did you find out what this meant? I have a smeg cooker which is saying the same and can't find any info about it. Many thanks.
Apr 27, 2011 | Smeg Ovens
Hi I I have a Fisher Paykel range cooker model no: OR90LDBGX1 The clock is not working, the display is not illuiminated & the oven lamp is not working. The main oven won't come on as will only work...
the power runs through the clock then to the oven so delayed cooking can be set, toy have one of two options easiest is to by pass the clock,the second is to replace clock
Oct 09, 2017 | Fisher and Paykel Ovens
Clock on cooker flashing
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
Apr 28, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Faulty timer function on Stoves 720 EF
To take off the front button panel.
First power off the cooker, then remove the three right control knobs - they are just push on and push off. There are flats on the spindles matching contours on the knobs to ensure thay go back correctly.
Lower the top oven/grill front. Under the front button panel there are three screws going upwards. One at each end and one in the middle. Remembering how they are installed, remove them. The panel will now be loose but it is held in postion by two or three lugs which are along the top inside edge of the panel. They, from what I remember, hook into the inner panels of the cooker. I think you have to lift the lower edge of the panel towards you, to overcome the upward bend of the lugs.
The buttons for the clock are purely push fit and if you want they can be removed using a thin bladed knife.
I have to say that if you want complete access to the clock, I think you will have to take out the complete oven from the unit and take the top off, so be warned. Instructions of how the cooker is mounted are in the instruction manual.
Putting the front panel back I found to be fiddily - ensuring the lugs are located correctly, especially the one by the clock doesn't always want to work. In the end I left that one not positioned correctly, so in effect the front panel is slightly out at the left hand end.
Best of luck!
Jan 28, 2009 | Stoves 720EF Electric Double Oven
Smeg oven ss336-5 not heating
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on Facebook please How to Video Tutorials on Domestic Appliances
Jan 21, 2009 | Smeg SE399X/5 Stainless Steel Electric...
CLOCK ON COOKER
You can down load the user instructions from Hotpoint web site.
In your browser bar type in---- hotpoint user manuals
Then in the drop down list click on------ hotpoint manuals and guides
In the search box type in your model number and down load instructions.
Plz rate my solution.
Thanks.
Jan 14, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Oven will not switch on
If there is an A only on the clock(no other digits) your clock has failed. Either replace , or can be bypassed. Oven won't work without clock set.
Dec 14, 2008 | Smeg SE250XUK Stainless Steel Electric...
How to light our gas cooker
Modern gas cookers use an electronic ignition switch rather than a pilot light to light the gas for cooking. This means you can light your gas cooker with the touch of one button instead of using several matches or a flint lighter. Of course, you still have the option to light the gas cooker by hand with matches or a flint lighter if the ignition switch does not work the first time.
1.Open the gas regulator valve by pushing it in and turning it to a low setting.
2.Push the ignition switch once.
3.If the gas cooker does not light on the first try, close the gas regulation valve for one minute by pushing in on it and turning it back to the "Off" position.
4.Open the gas regulation valve, set it a bit higher than you did on the first lighting attempt, and push the ignition switch again.
5.Light the gas with a match or a flint lighter if the gas cooker does not light when you push the ignition switch again.
Feb 23, 2008 | Ovens
Ovens Logo
638 people viewed this question
Top Creda Ovens Experts
Craig Butler
Craig Butler
Pcm2048
Andrew Taylor
Andrew Taylor
Are you a Creda Oven Expert? Answer questions, earn points and help others
