Question about Car Audio & Video
I need to wire a taxi roof sign to my car fuse box in my 2003 vw passat
    Filmmaker:
    Uploaded 5 video answers.
  • 182 Answers
Go under the strering wheel and test ur auxilary with a power tester the one that turns on and off when u turn on and off ur key is the auxilary just tap the power wire there and the ground to metal and then everytime u turn ur car on the light will turn on and when u turn ur car off it turn off and when u have the key half open ur light will be on just like ur car stereo
Posted on Jun 28, 2009
How many fuse box has the 2002 vw passat 1.8 t
Arturo, Passat fuse/relay locations and alarm schematic. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Volkswagen Passat B5 FL 2000 2005 fuse box diagram Auto Genius
VW Passat B5 Guides
http://forums.vwvortex.com/showthread.php?3751731-Fuse-box-in-engine-compartment
Best images of 2003 VW Passat Relay Diagram
2002 passat alarm wiring schematic Google Search
Aug 21, 2016 | Cars & Trucks
My head lights and tail lights are out on my 2003 vw passat aw how do i fix the problem?
Look in owners manual it'll show fuse box and fuse locations for everything.
Nov 02, 2014 | 2003 Volkswagen Passat
On 2003 vw Passat my tail lights won't come on but
Think you need a repair shop or wiring diagrams
& vehicle experience
Sep 12, 2014 | 2003 Volkswagen Passat
Power windows and sunroof are not working as well as power locks will not stay locked. this happened after jumping the battery. any ideas of what the problems is? Already talked to a vw dealer and they...
The first thing you need to check is your fuses- it is not unusual to blow a fuse when jump-starting. Since all the power accessories (windows, roof, locks) went out together this is the best place to start. It has been a while since I worked on my Daughter's Passat, so I cannot remember if it is in the under-hood fuse panel, or the fuse panel inside the car.
If your fuses are OK, you can call VW-Parts, Inc. at (845) 254-6600. This is an after-market parts supply house in Fleischmanns, NY that deals only with VW's. Most times, they are happy to help with problems like this, and if it requires a part, they will have what you need for a good price.
Good Luck, and Thank You for using FixYa.
Apr 14, 2011 | 2003 Volkswagen Passat
Where is the fuse box on a 2003 VW Passat V6?
The fuse box on 2003 VW Passat V6 is placed on the driver's lateral side of the dashboard, door open. See pictures below:
The fuse box diagram is attached on the inner face of the plastic fuse box cover:
Please do rate my response. Thanks!
Feb 16, 2011 | 2003 Volkswagen Passat
When pressing the button to close the sun roof , it will not respond. Interior lights not working and cannot find the fuse box. It's a VW Passat 1996 wagon.
Hello myrnamoreno
The fuse block is located under the back seat. The dome light is on fuse #21 15amp, the rest of the
fuses and their functions are listed on the inside of the fuse block cover. Hope this helps.
Dec 27, 2010 | 1996 Volkswagen Passat
Where is VW Passat 2003 year, 2.8L Motor Fuse panel
Hi!!
The Fuse Box on the passenger compartment is located on the driver' side end of the Instrument Panel. To remove the cover just insert a flat screwdriver or similar tool to pop the cover. See the following pictures.
Nov 08, 2010 | 2003 Volkswagen Passat
2003 passat issues
Well, your local garage is correct. Most cars now a days have computers for everything. That is one computer that runs those things. But before you go into replacing an expensive motor, go through and get a wiring diagram from your local parts store, and then see where the wiring all have in common, this may only be the computer, but may be a fuse of some sort. hope that helps.
Jul 21, 2009 | 2003 Volkswagen Passat
Brake lights
Yes, check the fuses. It should tell you which it is on the fuse box cover. Or you could just pull all the fuses out. Also you may have a loose earth connection.
Apr 30, 2009 | 2003 Volkswagen Passat
Car Audio & Video Logo
165 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
